Offline fossie
#1 Posted : 08 June 2020 14:53:12(UTC)
fossie
Dear All
My Marklin BR24 p/n 36242 has died.... No sounds, no movement no smoke and it shorts out my ecos 50200 when placed on the track. I have had several issues with it in the past. It has been back to Marklin twice and had the decoder replaced and a new Motor. I have opened it up and I believe the decoder has gone again. The model is now out of warranty and my question is will the Marklin 60975 msd/3 decoder be a suitable replacement. Will it fit in the tender and do the smoke etc... Or do you recommend another decoder.
Thanks for your help on this.
Andy
#2 Posted : 08 June 2020 19:10:38(UTC)
Hi Andy
I just had a similar problem with my BR 58 (37589) where the decoder did not drive the motor anymore (all the rest was fine, sound, functions, etc).
So I purchased a 60975 Sound decoder with a platine the get the decoder with the 21 MTC interface.
On Märklin's website I downloaded the sound project for my loco on my PC using Märklin's mDecoderTool3 and programmed it with my CS2.
It worked fine except for the Telex which was incorrectly set (I had to set it to negative level (Negativ Pegel). Now the loco works fine.
So I guess for your loco it should be the same:
- open mDecoderTool3 on your PC and download the Sound project for your loco (from its reference number): In your case select the m36 directory and then 36244 (BR 24). Normally it should be very close to your loco configuration.
- connect your CS2 with a memory stick to the PC and start programming (takes 40 mins)
- make sure your Telex is not permanently ON (it could be destroyed after a while)
Let me know if you have a problem
Offline fossie
#3 Posted : 08 June 2020 19:33:26(UTC)
fossie
Hi Jean
Thanks for the reply... Unfortunately I don't have a cs2 I have an ecos 50200. But the decoder should still work ok and as I understand it comes already programmed with steam sounds on it?.
Andy
#4 Posted : 08 June 2020 20:09:35(UTC)
Yes Andy
I think there is also an output for telex in the factory settings
Offline Johnvr
#5 Posted : 08 June 2020 22:38:22(UTC)
Johnvr
Hello Jean
I have a CS2 60215.
Is it possible for me to update my mSD3 Sound Decoders 60985 for the loco sounds which I want to select, for example the BR53, but without connecting the CS2 to the internet ?
For example, is it possible to load the sounds onto a USB memory stick downloaded from the Marklin website, and then insert my USB into the CS2 and update the sounds from there on my decoder ?
I'm a bit nervous to try it out for fear of choking up the CS2.
#6 Posted : 08 June 2020 23:34:43(UTC)
Hi John
IMO all MSD3 decoders are the same the only differences:
- sound programming (Electric, Diesel or steam)
- interface : 21 pin (MTC Platine), prewired (Kabelbaum) or with flexible PCB interface for lights
So any decoder may be programmed using the mDecoderTool3.
So you need to have your PC online to download any Sound project you wish and store it on your computer
In a second phase you need to connect your PC to your CS2 and program your decoder even in absence of Internet, using the mDecoderTool and a USB memory stick plugged on your CS2 before booting-up.
mDecoderTool3 will allow to select the stored sound project and during the programming phase it will:
1- transfer 4 files to the the USB memory
2- Program the decoder
3- Reset the decoder(don't touch your CS2 until programming is finished with the reset done
4- erase the files on the USB memory
Note: Sound projects are different for mSD2 and for mSD3 decoders: same sound, smaller capacity for mSD2.
I hope this answers your question
Online river6109
#7 Posted : 09 June 2020 03:03:21(UTC)
Originally Posted by: fossie Go to Quoted Post
Dear All
Andy
Andy, I would send it back to Märklin again, regardless being out of Warranty, I'm sure you can proof the loco they've fixed, they didn't fix properly and therefore and extended warranty is warranted.
Offline fossie
#8 Posted : 29 June 2020 12:10:31(UTC)
fossie
Dear All
I went for the option and purchased the Marklin 60975 msd steam sounds decoder kit and installed the decoder in the tender of the br24 (36242). Now the locomotive will produce all the sounds but there are some issues.
1) The locomotive runs fine backwards with the lights working. But going forward it moves jerky and the front head lights do not work.
2) The smoke option is always on even if the F1 option is not selected.
I have an ecos 50200 so can not program the decoder with the sounds of the br24. The only other option is to resend it back to Marklin for its third repair out of warranty.
Any ideas
Andy
#9 Posted : 29 June 2020 12:44:27(UTC)
Hi Andy
Regarding the front light and motor not working correctly in forward, I would reset the decoder (CV8=8)
As for programming I know how to do it with a CS2 but not with an ecos 50200 and I believe Märklin does not include the list of all CVs with the MSD3 kit notice
I would not resend to factory because, they will replace the decoder, repair the loco, charge you a lot (150 € minimum plus shipment) and you will have to wait quite a while.
Additional things to check:
- the wire to front light not broken and the return wire to common plus is OK
- absence of mechanical issues but removing the decoder, powering the motor with a 5 to 10 VDC and see how it runs
- checking the wiring of the smoke unit (central part connected to AUX1?
My experience with Märklin support is they are good on obvious failures but very poor on intermittent issues.
Here is the pin-out of the decoder (21MTC)
Offline fossie
#10 Posted : 29 June 2020 12:56:06(UTC)
fossie
Hi Jean
Thanks for your reply on this. I will try resetting the CV to 8. One thing I did not mention is I plugged the new decoder into the existing pcb in the tender not the one supplied in the 60975 kit as there is a pcb soldered on to it for the rear lights.
Do you think this will cause an issue or should I use the pcb in the kit and then have a problem with connecting the rear light pcb.
Andy
#11 Posted : 29 June 2020 13:40:29(UTC)
Hi Jean
Andy
I suspect your problem is a case of needing to correctly map the function outputs to the CVs. There is no guarantee that a bog standard decoder from Marklin will match a fitted decoder for CV settings as they are so configurable, and the PCB you plug onto is likely to have been laid out to suit production requirements, not off the shelf settings.
When i did the factory tour at the IMA last year you could see the operator fitting the decoder put it into a programmer just before fitting it into the loco, so the sound file used could well be a special one.
Offline fossie
#12 Posted : 29 June 2020 14:20:12(UTC)
fossie
Can these cv's be re programmed by the ecos 50200 or do I need to purchase the Märklin 60971 decoder programmer.
Andy
#13 Posted : 30 June 2020 09:25:58(UTC)
The CVs can be programmed with the ECoS 50200, or the ECoS 50000, or the ECoS 60212 - to name just a few.
Offline fossie
#14 Posted : 30 June 2020 16:10:24(UTC)
fossie
Hi Tom
thanks for your reply... The decoder is setup for mfx by default and the only CV I have set is CV 8 factory defaults... It made no difference. What other CV's do you recommend I try?. Am I right in thinking all the other CV's can only be accessed when the decoder is configured in the MM format and not mfx format.
Andy
#15 Posted : 30 June 2020 18:10:03(UTC)
Where abouts are you Andy, maybe someone can come and help.
Offline fossie
#16 Posted : 30 June 2020 18:34:37(UTC)
fossie
I live in Lichfield, Staffordshire...
Andy
#17 Posted : 30 June 2020 19:35:19(UTC)
No.
When in mfx mode, forget about the CVs and edit the advanced loco settings.
There you define what happens when you activate F0, F1, and so forth.
Offline fossie
#18 Posted : 30 June 2020 20:00:49(UTC)
fossie
Hi Tom
Thanks for your reply.... Just tried it and under that option and it displays the following message.
"No settable parameters for the selected decoder profile in this menu".
Incidentally the same mfx loco with the old failed decoder has entry's in that option on the ecos 50200.
Do you think I will need to purchase the Märklin H0 60971 Decoder-Programmer to fix the problem?.
Thanks again
Andy
#19 Posted : 30 June 2020 20:27:07(UTC)
I don't think so.
You can still disable M4 in the ECoS and use DCC CV programming to make the changes.
Theoretically the ECoS should give you a user-friendly UI for mfx decoders if M4 is enabled, but somehow this does not seem to work for you.
With the decoder programmer you will also have a GUI to make the changes. But theoretically this is not the only option.
Offline fossie
#20 Posted : 24 November 2020 18:24:44(UTC)
fossie
Dear All
It has been some time but I decided to give it a go and try repairing the locomotive, I purchased the decoder programmer and the 60975 msd decoder. I programmed the sounds ok of the br24 and got the smoke and front lights to work. Unfortunately when working with this fiddley locomotive. both wires to the motor got broken of at the connection to the tender pcb.
Does anyone have a wiring diagram of this locomotive?
Many thanks
Andy
#21 Posted : 24 November 2020 19:25:34(UTC)
Hi Andy
Sorry I don't have a wiring diagram but maybe Märklin follows its own color scheme fro wiring.
Look at page 29 -Märklin Column of the following document https://static.maerklin....49aec5e3521564554225.pdf
Typically Green and Blue for the motor
Red: Slider
Brown: chassis and wheels
Orange for all function's return (+voltage) used by all lights function
Grey: Font light
Brown/red for Function 1 (Smoke unit)
All the rest remains in the tender
On some locos all cables are black and you may have to "ring" them with a multimeter
Here is a picture of my BR 24 36240 (very close to yours)
Before the installation of the Sound decoder
Offline fossie
#22 Posted : 24 November 2020 20:01:51(UTC)
fossie
Hi Jean
The picture is really helpful.
Thanks so much
Andy
This page was generated in 0.658 seconds.
