Offline Airfix05
#1 Posted : 02 June 2020 23:48:12(UTC)
Airfix05
Ireland
Would someone be kind enough to explain the various plugs and what they are used for , Marklin have orange, brown, green and grey plugs
Thanking you
Airfix 05
Offline owidgie
#2 Posted : 03 June 2020 01:37:30(UTC)
owidgie
Plugs and wires used by Marklin have always followed their color scheme for analog.
Red and brown wire with red and brown plugs are always used for track power.
Brown wire with brown plug will also go to an analog switch box.
Blue wire with green and red plugs from analog turnouts to analog switch box.
Yellow wire with yellow plug to yellow from transformer for turnouts (lighting and "+" lead).
Signals follow the same color scheme as turnout with the exception of an entry signal with a blue wire and an orange plug.
Blue wire with red, green or orange plugs from a circuit track to signals or turnouts corresponding to their action.
Grey wire with grey plug is for scenic lighting.
Digital color scheme is basically the same if analog components are to be used with the exception of blue wire is not only from circuit track, but also from contact track or reed contact to s88.
Rick
thanks 4 users liked this useful post by owidgie
Guest (4)
New Style Marklin Plugs (General MRR)
by petestra 15/05/2024 18:55:12(UTC)
Marklin Plugs & Sockets (vintage) - when did they change? (Collector's Corner general)
by cookee_nz 28/03/2020 10:04:29(UTC)
Connectors for Marklin plugs (Model railroad wiring)
by Robert Davies 23/11/2016 21:48:16(UTC)
This page was generated in 0.420 seconds.
