Offline morsing
#1 Posted : 26 January 2020 19:16:32(UTC)
morsing
Sorry but another CS3 problem...
I spent days trying to figure out how not to use "Workspaces" in RocRail, and when I finally had it, and both my PC and laptop could loads the same plan from RocRail, it seems the CS3 will no longer respond to RocRail.
I have no idea if it is related or coincidence...
I have tried restarting the CS3, RocRail, shut down RocView multiple times.
RocRail log says:
20200126.163452.283 r9999c fbreader OMCS2 0306 System STOP
20200126.163452.284 r9999I cmdrF400 OModel 2647 informing 10 listeners of a system event name=sys val=stop...
20200126.174128.470 r9999c fbreader OMCS2 0322 System GO
20200126.174128.470 r9999I cmdrF400 OModel 2647 informing 10 listeners of a system event name=sys val=go...
20200126.174153.998 r9999c fbreader OMCS2 0306 System STOP
20200126.174153.999 r9999I cmdrF400 OModel 2647 informing 10 listeners of a system event name=sys val=stop...
20200126.174155.734 r9999c fbreader OMCS2 0322 System GO
20200126.174155.734 r9999I cmdrF400 OModel 2647 informing 10 listeners of a system event name=sys val=go...
20200126.174202.054 r9999I cmdrF400 OSwitch 1364 Switch [sw31] will be set to [straight,0,0]
20200126.174202.054 r9999c fbreader OMCS2 0374 Switch 52 (mm) to straight
20200126.174202.055 r9999I cmdrF400 OSwitch 2035 switch [sw31] field event: state=straight(field:straight) gatevalue=1 inv=0 fieldstate=straight
20200126.174202.055 r9999I cmdrF400 OSwitch 0178 CTC LED: m1=0 m2=0
I ran a tcpdump as well:
root@albert:/opt/rocrail# tcpdump -s0 -li eth1.200 host cs3
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth1.200, link-type EN10MB (Ethernet), capture size 262144 bytes
17:48:22.307734 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:22.453884 ARP, Request who-has cs3.local tell albert.local, length 28
17:48:22.459091 ARP, Reply cs3.local is-at 00:1f:b2:05:3a:5f (oui Unknown), length 46
17:48:25.241649 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:25.251787 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:25.995297 IP cs3.local.15730 > 255.255.255.255.15731: UDP, length 13
17:48:27.308216 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:32.308700 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:37.310034 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:42.310759 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:47.308677 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:52.309663 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:48:52.405841 ARP, Request who-has cs3.local tell albert.local, length 28
17:48:52.415445 ARP, Reply cs3.local is-at 00:1f:b2:05:3a:5f (oui Unknown), length 46
17:48:55.997710 IP cs3.local.15730 > 255.255.255.255.15731: UDP, length 13
17:48:57.309862 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:49:02.309545 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:49:07.309771 IP albert.local.46206 > cs3.local.15731: UDP, length 13
17:49:12.312220 IP albert.local.46206 > cs3.local.15731: UDP, length 13
The CS3 just isn't responding... What could cause this? Also, what is the CS3 broadcasting on 15731?
Thanks for any help, I feel a bit stressed about the amount of time I'm spending on this.
Henrik
Marklin C-track + CS3+
thanks 1 user liked this useful post by morsing
Offline PMPeter
#2 Posted : 26 January 2020 21:42:07(UTC)
PMPeter
Normally for me when my laptop and CS2 no longer talk to each other, the network settings have changed on their own. I always experience this after a CS2 update and quite often after a short circuit shutdown of the CS2.
I do not know if this is your problem, but I would certainly check the network settings on the CS3 to see if they have changed from what you have configured in Rocrail.
#3 Posted : 26 January 2020 22:38:19(UTC)
Can't help with any of your other problems, but your trace doesn't list the IP address it is attempting to contact. However I wonder if this is the cs3 attempting to contact Marklin to see if there is a software update available.
Offline TEEWolf
#4 Posted : 27 January 2020 05:48:13(UTC)
You have been a member since:: 01/06/2016(UTC)
Henrik
Why don't you try it at the Rocrail Forum too? It is in English available.
https://forum.rocrail.net/
You may find there more people with experience in Rocrail combined with the CS 3 from Maerklin.
Offline morsing
#5 Posted : 27 January 2020 19:36:24(UTC)
morsing
The dump has the destination address, 255.255.255.255. It's an odd port to broadcast on.
Offline morsing
#6 Posted : 27 January 2020 19:38:35(UTC)
morsing
Because most Internet fora are quite un-pleasant, this on isn't. I haven't got an account on there, maybe I will set one up.
That being said, this is a CS3 problem, not a RocRail problem, I think.
#7 Posted : 27 January 2020 21:34:16(UTC)
Views messages in topic : 7,341
If your Cs3 works fine without Rocrail then the problem will not be with the controller. The Rocrail site might be your best bet although I am sure somebody on here will have a similar set up and could help.
Offline morsing
#8 Posted : 27 January 2020 21:41:28(UTC)
morsing
I have done a full packet dump as well, and RocRail sends all the right stuff, power on/off etc. is clearly visible in the packet and it doesn't get rejected by the CS3.
Ok, I will register on the RocRail forum.
#9 Posted : 28 January 2020 00:24:03(UTC)
OK, I am not a network expert, but if I remember correctly that address is reserved as a broadcast address for an item to say to anything else interested on the local network "hey I exist". I don't know what the story is with the port number, but that may be an option that allows other equipment to know what is broadcasting and identify it. I presume the message also contains the message of the item broadcasting so other items know who to reply to.
Offline morsing
#10 Posted : 28 January 2020 17:46:50(UTC)
morsing
I actually think I might know what has happened. I ticked "Auxiliary Device" under Master/Slave settings by mistake. I unticked it again, but not sure it's right or what it has done.
Offline morsing
#11 Posted : 28 January 2020 20:24:15(UTC)
morsing
I think it's factory reset time. I have backed up to USB, can I import only track plan and locomotives after a reset?
#12 Posted : 28 January 2020 21:33:58(UTC)
From memory you need to reboot after unticking 'auxiliary device'. have you done this?
Offline morsing
#13 Posted : 28 January 2020 21:48:52(UTC)
morsing
Many times, but it reboots automatically as well.
#14 Posted : 28 January 2020 21:55:10(UTC)
If the cs3 is set to DHCP, I assume you have a DHCP server, normally the router.
If you have the cs3 set to static IP address is the first three digits the same as the IP address of the PC?
Offline morsing
#15 Posted : 30 January 2020 09:14:18(UTC)
morsing
Problem resolved, the controller in RocRail had been changed to mcs2 instead of mbus. God knows how, I haven't been anywhere near that.
thanks 5 users liked this useful post by morsing
This page was generated in 0.598 seconds.
