Offline geir
#1 Posted : 26 May 2019 20:56:16(UTC)
geir
What have I done wrong when I made this event ?I cant choose "trigger control"its grey.
I have a CS3 with S88 link with contack tracks,trying to make a classic staging yard.Ref".Running trains digitally with the central station 3" marklin book
Offline MaerklinLife
#2 Posted : 26 May 2019 22:43:57(UTC)
MaerklinLife
Did you turn on advanced event mode under system settings?
Offline geir
#3 Posted : 27 May 2019 18:24:21(UTC)
geir
Thanks,the drop down meny worked but the setting meny is difference from the book.I have made 6 events
setting menu:
book.jpg 6 events
Offline geir
#4 Posted : 27 May 2019 19:22:30(UTC)
geir
setting menu:
book.jpg 6 events
I found something interesting on forum:
Marklin recently changed their format for the Contact Track Event programing. BTW, this info is now covered by Curtis Jeung in the latest Digital Newsletter.
In sum....1) Drag and drop the Contact Track icon from the TDCB onto the block at the left of the event script...where the word "manual" is located. 2) Click on that loco icon which now appears. ...this will then show the details for further programming which have now changed. There will be too ovoid CT icons to the right side of the "detail".....one will be in YELLOW and the other will be in GREY.... If you click on the Yellow one, you will note that the icon in the event script will be the "arrival" loco. If you click on the "grey" CT icon, then the loco in the event script will be the "departure" loco icon....
Marklin didn't do us any favors by not announcing that kind of change. It caused a "little bit of indigestion" !!! ;-0
Hope that helps...if now PM me ....alan
From http://railway.zone/post...arklin-central-station-3
"Clicking the trigger will bring up the settings window for the trigger. The settings window contains a few more options. The most important being "Position". Position tells the CS3 to trigger the event either by the contact becoming occupied or the contact becoming vacant. An event will only trigger on a status change of the feedback contact in question."
none of my entry track events (departing events) works only Exit (arriving) events
Edited by user 29 May 2019 19:30:42(UTC)  | Reason: Not specified
CS3 audio output (Digital)
by rhfil Yesterday at 16:35:50(UTC)
CS3 run time event (Digital)
by QQQ1970 15/04/2024 14:44:37(UTC)
Using an Intellibox with a CS3 (Digital)
by rschaffr 09/04/2024 23:23:07(UTC)
CS3 Failure to Read and thus Write to DCC Decoder. (Digital)
by nikdog 06/04/2024 00:45:33(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
CS3 2.5.2. update older decoder FW (Digital)
by jonas_sthlm 25/03/2024 10:55:37(UTC)
Mobile station 1 and CS3plus compatibility (Digital)
by biswasg 25/03/2024 10:00:10(UTC)
CS3+ automation macros examples & documentation (Digital)
by fabstar68 18/03/2024 15:04:49(UTC)
CS3 with it's new update 2.5.2. & ESU Loksound 5 (mfx) (Digital)
by bygger01 14/03/2024 20:11:58(UTC)
CS3 and mfx locos in maintenance mode (Digital)
by rhfil 27/02/2024 23:23:05(UTC)
CS3+ Locomotive data pictures (Digital)
by MSanches 27/02/2024 10:48:24(UTC)
CS3 events, IF macro inside a loop... how is it supposed to work? (Digital)
by dodi 22/02/2024 18:37:15(UTC)
CS3 Cannot edit control boards when connected via Browser (Digital)
by malsnake 17/02/2024 03:51:24(UTC)
Decoder Read Message CS3Plus (Digital)
by mzecchi70 12/02/2024 03:21:12(UTC)
do the lok data cards - 60135 - work with CS3+? (Digital)
by roedj 10/01/2024 12:14:32(UTC)
Mouse not working with CS3 (Digital)
by Uwe 04/01/2024 02:34:04(UTC)
CS3 Update Issue (Model railroad software)
by Eddie7979 22/12/2023 05:57:46(UTC)
CS3 connexion with a smartphone (Digital)
by JohnjeanB 20/12/2023 10:49:42(UTC)
Cs3+ (H0-scale)
by bobgiam 16/12/2023 01:17:51(UTC)
SUSI CV Menu in CS3 (Digital)
by Diesel2000 14/12/2023 18:19:52(UTC)
CS2 upgrade to CS3 (Digital)
by rhfil 11/12/2023 00:39:07(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
CS3 deleted actions (Digital)
by petestra 07/12/2023 15:15:04(UTC)
CS3 loco history (Digital)
by rhfil 04/12/2023 19:04:12(UTC)
CS3 and Wifi camera (Digital)
by jonas_sthlm 03/12/2023 11:12:11(UTC)
CS3+ update using USB stick. (Digital)
by Flupke 13/11/2023 16:33:07(UTC)
S88 contact and Track Diagram CS3 (Digital)
by fvelazdem 13/11/2023 13:50:14(UTC)
CS2/CS3 multiprotocol Wave form (Digital)
by peter_moulin 07/11/2023 12:43:12(UTC)
CS3 and loco photo (Digital)
by fvelazdem 19/10/2023 13:44:39(UTC)
CS3 layout editing (Digital)
by rytter 30/09/2023 23:50:31(UTC)
CS3 and ethernet connection (Digital)
by Luna 20/09/2023 05:47:45(UTC)
Breakmodule vs CS3 (Digital)
by Mille 10/09/2023 09:11:20(UTC)
CS3 Trackplan (Digital)
by henna 31/08/2023 06:56:08(UTC)
Backdating a CS3+ (Digital)
by Drongo 22/08/2023 12:40:28(UTC)
7687 and 6040 keyboard vs Marklin CS3 (Digital)
by brauer.jim 09/08/2023 22:50:40(UTC)
CS3 Auto Addition of Locomotives (Digital)
by Eddie7979 30/07/2023 08:28:35(UTC)
CS3/CS2 - same loco different photos (Digital)
by twmarklinfan 26/07/2023 00:51:29(UTC)
Using the macro BLOCK on the Märklin CS3. Questions (Digital)
by JohnjeanB 08/07/2023 15:31:28(UTC)
CS3 Overload Error (Digital)
by Roland 04/07/2023 02:16:06(UTC)
22560 Santa Fe with CS3 (Big scale)
by Pkimbrough 17/06/2023 23:31:19(UTC)
CS3+ Help: cannot create "areas" on layout (Digital)
by plg 03/06/2023 21:00:28(UTC)
Use old 6083 (K83) and 6084 (K84) with CS3+? (Digital)
by Feelixen 18/05/2023 14:45:27(UTC)
Resetting cs3 (Digital)
by Mille 14/05/2023 10:56:38(UTC)
My cs3 dont find my New m84 (Digital)
by Mille 10/05/2023 10:03:36(UTC)
CS3+ Events (Digital)
by Drongo 27/04/2023 07:40:50(UTC)
Loco speed in RocRail and CS3+ (Digital)
by Tue Albertsen 15/04/2023 17:30:21(UTC)
CS3 new update 2.4.1.0 (Digital)
by gamolina 15/04/2023 02:58:14(UTC)
Steps to add CS3 into a system running MS2 (Digital)
by Cmondialo 15/04/2023 01:09:17(UTC)
editing a 76496 mfx home/exit signal time on CS3 (Digital)
by marklinist5999 11/04/2023 14:25:20(UTC)
CS3 - Locomotive Functions (H0-scale)
by Eddie7979 09/04/2023 10:58:43(UTC)
This page was generated in 0.414 seconds.
