Hi I am about to fit my turntable with a D2010 decoder with sound and would like to control a Gleisspersignal on the bridge ( Weinert 7235). Reason for the 7235 is my epoch II layout. The question is if anyone knoeshow to get the signal rotating on the limites space underthe bridge ? I have tried to postan english message on the video below but no luck. Hope someone is as curious as I am Br Jan
Joined: 21/05/2004(UTC) Posts: 1,769 Location: Brisbane, Queensland
Originally Posted by: JanThyregod  Hi I am about to fit my turntable with a D2010 decoder with sound and would like to control a Gleisspersignal on the bridge ( Weinert 7235). Reason for the 7235 is my epoch II layout. The question is if anyone knoeshow to get the signal rotating on the limites space underthe bridge ? I have tried to postan english message on the video below but no luck. Hope someone is as curious as I am Br Jan You could go without the GS completely, there were prototypical turntables from that period and later with no signal. You can see it here: https://www.marklin-user...vements-to-BW#post544707I don't think anyone here has installed the Weinert GS on a Marklin turntable but obviously it can be done based on the video you posted. Have you already purchased the required parts? The Weinert GS would be controlled by a servo, it would be a matter of trying to find space for it. |
modelling era IIIa (1951-1955) Germany |
Joined: 15/10/2006(UTC) Posts: 2,319 Location: Washington, Pacific Northwest
Either a very tiny servo, or something like a Viessmann c-track turnout motor 4558) would be a candidate for fitting under the table's platform. How to bend a wire and mount it to rotate the signal I cannot say but should be quite doable but requires modeling work (assuming Weinert doesn't provide some sort of solution ) |
