Offline Bones
#1 Posted : 19 September 2017 06:56:42(UTC)
Bones
I just need some help in clarifying why when using my old tinplate carriages does the MS3 turn off with only 3 carriages
The transformer says it has 36 va output so there should be enough power to run at least 4 carriages
I run a 24 class lcomotive with the other 185 electric loco I purchased
Is this due to a limitation on the digital outputConfused
#2 Posted : 19 September 2017 07:05:14(UTC)
There is no such device as a MS3........
I assume you are referring to the MS2 with the later black case (rather than the grey one).
While the power supply (it is not a transformer, rather a switchmode power supply - there are lots of other threads on the forum talking about this) is rated at 36va, the important specification is the output capability of the MS2, which I believe is 1.9 amps.
You don't say, but I assume from your post that the tinplate coaches have interior lighting. It may well be that the power output limit is being reached.
I think the MS2 has an inbuilt display that tells you current consumption, etc. This is in the Info menu on the MS2. Refer to Page 4 of the manual.
See https://www.marklin-user...451_60113-Track-Box.aspx
Offline Bones
#3 Posted : 19 September 2017 07:55:35(UTC)
Bones
No I have the grey box but I always get confused as to wether its an MS2 or MS3
Please note I don't use LED's I use the old 7077 light globes
Now that someone has pointed out that the supply from the grey box is only 1.9 amp which gives 34 va then its not surprisng that i can only run 3 carriages
I should have looked that up myself and thanks all for your help
That also means I will need the a CS2 or CS3 if I want run the whole 7 tinplate carriages
Again thanks for the advice
thanks 1 user liked this useful post by Bones
#4 Posted : 19 September 2017 11:28:54(UTC)
If you replace the globes with LED strip lighting (get warm white to match the colour of the globes) you will find you will be able to run all 7 coaches with the MS2.
Have a look at the current usage meter on the MS2 for interest sake to see how much current is being used by the 3 coaches.
#5 Posted : 19 September 2017 12:36:31(UTC)
I run a TEE train with a 3054 Br103 loco and 6 tinplate coaches, of which 4 are fitted with old style interior lights (The other two are awaiting LED strips). I have no problem running this train and another train at the same time on my MS2.
Do you have other devices powered from the track? The MS2 should be good for at least one fully lit train so there must be something else drawing current.
Offline eroncelli
#6 Posted : 20 September 2017 10:19:41(UTC)
eroncelli
Instead of installing LED strips, with some major work, check this site to have LED bulbs that fit in the existing lamp-holder:
http://stores.ebay.it/tu...p?_trksid=p2047675.l2563
thanks 4 users liked this useful post by eroncelli
#7 Posted : 20 September 2017 12:53:36(UTC)
Yep, been meaning to get some of those LED globes to replace the bulbs in my M track turnouts and 7283 catenary masts!
#8 Posted : 20 September 2017 13:03:32(UTC)
I'm slowly changing over to the self-powered LED strips from Train Tech. They are easy to fit and do not rely on sliders or current conducting couplers. They are fairly expensive, but you do save money on the sliders, contact wipers, etc.
http://www.train-tech.co.../interior-coach-lighting
Offline Jabez
#9 Posted : 21 September 2017 21:31:26(UTC)
Jabez
This sounds like a very interesting product line. And when you factor in the cost of lighting pickups or conducting couplers and the associated wiring, pretty competitive with rail-powered lighting cost-wise. Thanks for the heads up.
Jabez
#10 Posted : 22 September 2017 21:39:21(UTC)
An interesting approach though I cannot get past the use of batteries (that have to be replaced in each car over time) when there is perfectly good power source directly below some 2 inches away.
Offline Jabez
#11 Posted : 22 September 2017 22:06:36(UTC)
Jabez
Fair enough.
It's a simple and convenient lighting solution (I hesitate to say the lazy man's) but I suppose it depends on how long the batteries last.
Battery is the popular 20mm diameter 2032 coin cell - lasts months in normal use, years in standby Says the mnfr.
'months' could mean a couple of months or maybe 6-12.
Maybe Ray could advise us of his experience.
Offline Danlake
#12 Posted : 22 September 2017 22:17:24(UTC)
Danlake
I have also used these strip for a few years now.
The lighting is good (you can get both warm white and cool white), but the best feature is the little sensor that will detect movement and turn them on automatically. With average use I would get min. a year out of them before replacing batteries.
The only disadvantages is that you have to dissemble the coaches to get access and some newer plastic coaches has very fine tolerances for the roof and it’s hard to avoid making small marks when getting the roof off...
I have been contemplating if it would be possible to have the battery coin holder underneath the coaches with 2 thin wires up to the strips?
Brgds Lasse
#13 Posted : 22 September 2017 22:25:10(UTC)
Brgds Lasse
Yeah, that would be the price for entry at minimum. I'd expect one could put the coin battery holder on the bottom of the coaches.. Though the lights going out when the train stops in the station does give that very odd analog effect, doesn't it.
These days though, I' d almost be looking at possible wireless/inductive ways of getting power from the tracks though... but I think the power draw for all those LEDs is more than can be inductively transferred with such voltages in the track and over the cm or so gap from the rail to the car bottom.
Offline Jabez
#14 Posted : 23 September 2017 00:16:24(UTC)
Jabez
I think there is a time-delay, about 4 mins after motion stops, which prevents the lights being switched off when the loco halts temporarily at a signal or a station.
Offline Bones
#15 Posted : 30 September 2017 11:08:48(UTC)
Bones
Hi everyone
I'm sorry I haven't posted but I and my wife are in the process of purchasing a house so that took priority
I took the advice and checked the power consumption
After a bit of thought I realised that it gives the power for each loco when selected in turn after having done this the total power consumed by both locos came to
1 amp and so this left only 0.9 amp for the coaches and four of them would be pushing the margin here
Also I noted that the temperature rose very quickly from 36 to well over 40 degrees celcius hence forth why it kept shutting down
Thus poor Horatio I will have to wait until I can get the higher output CS2 or 3 from my local dealer
He has offered to sell me a used CS2
But the house is taking priority
Once again I thank everyone for the advice and input
Your comments and advice will always be appreciated
BigGrin
Online H0
#16 Posted : 30 September 2017 21:04:30(UTC)
The MS2 shows the total power consumption for everything that is on the track.
Typically you have between 0.1 A and 0.6 A per loco.
Some CS2 are limited to 2.4 A, so not much better than the MS2.
#17 Posted : 07 October 2017 17:05:22(UTC)
I am now using the Train Tech lights and find them great. Very useful for coaches where you cant fit pick ups. The batteries do last a long time (depends of course on running time) and with as said above the lights staying on for several minutes after stopping then going out it is realistic. They also make single lights for locos etc. I found that in the UK I get next day delivery if ordered in the morning. Also no flickering. I am hooked on these and will probably keep on using them .
thanks 6 users liked this useful post by David Dewar
#18 Posted : 07 October 2017 19:08:52(UTC)
Fair enough.
Sorry, I missed this question!
I have not had to change any batteries yet.
Admittedly because of the way I rotate my stock on the layout each rake of coaches only gets used for 2 - 3 weeks in the year, so I can't advise for those who run their coaches every day. Sometimes when the coaches are on my storage shelves the lights come on as I move the boxes around. The lights stay on for around five minutes. This does not seem to have drained the batteries on any of my sets yet.
As some others have commented there are coaches that are hard to open in order to change the batteries, but many of my coaches open up easily, and batteries can be changed in seconds. The tin-plate coaches, for example, are dead easy to open.
I'm sure there are methods of taking the supply from the track inductively, but at the moment I know of no system on the market to do it this way. I'll continue to buy train-tech sets for now.
Offline baggio
#19 Posted : 08 October 2017 00:48:18(UTC)
baggio
Does anyone know if it is possible to cut a strip in two or otherwise make it shorter to use on shorter coaches?
Thanks.
Offline baggio
#20 Posted : 08 October 2017 01:22:01(UTC)
baggio
I answered my own question: YES!
See the PDF instructions that are set out in the link (thank you). BigGrin
#21 Posted : 08 October 2017 12:02:01(UTC)
If you have other device like switch decoder m83 and m84 i recommended you to use external power source to save power output from the MS2.
#22 Posted : 08 October 2017 13:08:10(UTC)
You can also add other LEDs to the strip.
Different topic but they also supply sound modules although UK outline but I reckon most diesels etc sound the same not tried one yet though.
39552 Not Full Function with MS3 (Digital)
by ec2808 18/12/2016 08:12:31(UTC)
MS3 with Br 50 mfx loco (Digital)
by xxup 17/08/2016 04:49:20(UTC)
This page was generated in 0.723 seconds.
