Offline michelvr
#1 Posted : 19 April 2017 01:58:56(UTC)
michelvr
After waiting 7 months for the Marklin 36629 NS Class E 186 Electric Locomotive I see something so small that sees so large that I'm returning for replacement.
Would you find this acceptable?
Michel
#2 Posted : 19 April 2017 02:03:29(UTC)
Are you talking about the missing running number? Confused
Offline michelvr
#3 Posted : 19 April 2017 02:07:12(UTC)
michelvr
Hi Adrian,
Sorry for for omitting the obvious which might not show up well on the pictures.
The blue angles down left to right causing the yellow to show up on top below the grey roof.
Michel
#4 Posted : 19 April 2017 04:43:01(UTC)
@Adrian:
I was looking for a paint issue similar to the one on the 37446 Re 482 and did not even notice the missing road number in the photo, but if you look close enough, you will see the S from the "NS", as the road number is just outside of the photographed zone to the left.
@Michel
The two sides do not appear to be the same. The upper edge of the sidewall seems to be painted blue in the second photo, but the other side has a thin strip of yellow that is visible.
I would check with your dealer if he can replace this model for you and hopefully they can check the new one before you accept it.
#5 Posted : 19 April 2017 10:54:22(UTC)
Ah now i see it.. Thanks..
Online river6109
#6 Posted : 03 May 2017 04:12:19(UTC)
how does this go past quality control ? someone is not taking their job serious enough and we all have to suffer for it.
This page was generated in 0.444 seconds.
