Offline Pmare4
#1 Posted : 14 April 2017 09:35:29(UTC)
Pmare4
Hi everyone,
I recently purchased some more Hornby O gauge items for my collection, and thought somebody else here might be interested.
The first item is a very rare 1936 M0 Mixed Goods train set. Costing 7/6 in 1937, the set contained the smallest oval of track known to man, as well as a clockwork loco and 3 goods wagons. The loco included was the cheapest in the Hornby series, and so had no reverse or front coupling.
The next is a 1948 E502 loco. Only exported to countries such as Australia and Argentina, it was the only electric O gauge engine produced by Hornby after WW2. As such, it is also fairly rare and desirable. Obviously, mine is missing its tender and coupling rods (which I can source), however, what I can't find a replacement for is the gear that sits on the armature shaft, mine of which is completely stripped. If you know where I can get another one of these gears, then I would be very interested.
thanks 9 users liked this useful post by Pmare4
#2 Posted : 15 April 2017 13:32:24(UTC)
This sounds like a 3D print project. If you could get the part to someone that does metal 3D printing I'm sure they could sort something out.
Offline kweekalot
#3 Posted : 15 April 2017 15:56:47(UTC)
kweekalot
Very nice set but a bit too modern for my liking.
I only run Trix Express from 1935. BigGrin BigGrin BigGrin
Marco
#4 Posted : 15 April 2017 21:52:43(UTC)
I'd venture to say that gears' 3D printing won't be a lasting success in this case;
On the other hand I seem to remember that Meccano/ Hornby were using DP38 gear standard.
I I had a picture and some dimensions, I *may* be able to help you here
can you post a picture of the mechanism showing were the missing gear should be??
Offline Pmare4
#5 Posted : 24 April 2017 10:29:54(UTC)
Pmare4
Can you post a picture of the mechanism showing were the missing gear should be??
Hi Jacques, sorry for the delay.
It looks like the gear is cut into the shaft and is not a separate part. Would it still be possible to make a replacement?
I've attached some pictures below which show the problem and some measurements. Also, the gear has 8 teeth and is the part outlined in red in the diagram.
#6 Posted : 24 April 2017 14:08:31(UTC)
OK, I know what you need: a whole new rotor.Wink RollEyes
I don't have that part here, since it's not Märklin, sorry
But I have a good friend in Paris who collects Hornby (intensely!! ) and is well plugged into the Hornby Collectors community.
I'll check with him and will let you know.
Jacques
This page was generated in 0.446 seconds.
