Offline PMPeter
#1 Posted : 16 March 2015 15:50:39(UTC)
PMPeter
Is there a trick to soldering the new Marklin or Viessmann catenary? I know officially it states no soldering required, but in practicality any small touch or bump tends to knock the wire off.
I'm not sure what material the Viessmann wires and Y connectors are made of, but solder does not seem to flow to make a connection.
#2 Posted : 16 March 2015 19:01:49(UTC)
Hi Peter,
I have the Viessmann catenary and I have not needed to solder any of it. It sounds to me like your mast spacing is not quite right if the wires can easily be knocked off. Make sure that the wires are under tension at all times.
You can sometimes add a bit of tension by sliding the wires to the ends of the hangers on the curves, making them go a longer way round, if you see what I mean.
Offline PMPeter
#3 Posted : 17 March 2015 03:25:58(UTC)
PMPeter
Hi Ray,
I understand that they do not require soldering. The mast spacing is fine and everything is usually under tension. However, when an inadvertent hand or something accidently knocks a wire off, it becomes a snowball effect and I spent some time making sure everything is back the way it should be. So I have now started to solder the connections at the masts and that is the reason for my question. Since my catenary is electrified I also use the Y seil and this is what doesn't seem to want to accept solder.
So my question remains to those that have previously indicated that they too solder the catenary - is a special solder or flux required?
#4 Posted : 17 March 2015 05:16:41(UTC)
if it stainless steel you can forget about it, or a forged metal, like Roco's pantograph, you can't solder them when they break. just out of interest how much more expensive is Sommerfeldt comparing it with Märklin or Viessmann, yo can try a acid free flux but I can't see any reason you would need it, its more likely to do with the type of material the y seil is made of.
CS2 and catenary analogue (General MRR)
by Bryan 12/04/2024 23:50:12(UTC)
Catenary Transition for Shadow Station to Tunnel (H0-scale)
by sforugby 22/03/2024 21:05:18(UTC)
Starting with catenary. (H0-scale)
by dave55uk 21/01/2024 12:09:40(UTC)
Paint Colour required for Marklin Catenary (H0-scale)
by marklin61 04/12/2023 20:45:38(UTC)
3015 didn’t work from catenary (H0-scale)
by Hematite 13/06/2023 19:25:59(UTC)
Catenary Set Up - Curve Combinations (H0-scale)
by Eddie7979 04/01/2023 06:01:00(UTC)
Transfer table 7294 catenary (General MRR)
by Boydrlhome 21/11/2022 16:09:09(UTC)
Using Block signal #89391 with Catenary system (Small scale)
by veloboldie 06/10/2022 21:40:31(UTC)
Catenary pole spacing (General MRR)
by Mr. Ron 17/01/2022 10:34:42(UTC)
Catenary (General MRR)
by Mr. Ron 25/12/2021 23:32:37(UTC)
by Ausipeet 18/08/2021 05:13:57(UTC)
Catenary fabrication for M track (H0-scale)
by Mr. Ron 12/07/2021 21:49:21(UTC)
Catenary Function (H0-scale)
by Ranjit 23/06/2021 15:06:10(UTC)
Lowering the Catenary (Small scale)
by Ricinport 07/03/2021 11:43:26(UTC)
How to isolate catenary circuits at a crossing? (H0-scale)
by ccranium 25/01/2021 21:57:31(UTC)
711.1 Catenary service vehicle catches fire and becomes run-away - July 9 2020 (Prototype)
by Minok 05/01/2021 00:22:19(UTC)
Looking for a source for a, Marklin 03902 ”Catenary Handbook” (H0-scale)
by frickwg 10/12/2020 19:18:01(UTC)
Catenary (H0-scale)
by Mr. Ron 16/11/2020 00:29:02(UTC)
39940 Unimog Catenary Maintenance Locomotive (Loco Reviews)
by xxup 08/11/2020 09:04:06(UTC)
M track, catenary and helixes (or helices) (H0-scale)
by Michael4 25/08/2020 15:30:16(UTC)
kato catenary 5-052 (General MRR)
by sonra 30/04/2020 16:23:44(UTC)
Dapol catenary masts (H0-scale)
by PeFu 24/03/2020 08:56:51(UTC)
Märklin gauge 1 catenary wires (Big scale)
by aclassifier 17/01/2020 10:30:22(UTC)
Searching for catenary manual (General MRR)
by Bertl 09/01/2020 17:25:06(UTC)
Sommerfeldt catenary (General MRR)
by Nuno 11/11/2019 20:59:59(UTC)
Marklin 88564 catenary issue (Small scale)
by husafreak 25/08/2019 08:08:36(UTC)
My world under catenary? (General MRR)
by hennabm 08/03/2019 21:27:11(UTC)
Bent catenary masts...and wires (H0-scale)
by Michael4 31/01/2019 10:44:10(UTC)
39970 Catenary Railcar Coupling (H0-scale)
by cookee_nz 28/01/2019 05:39:24(UTC)
Buying catenary for marklin ho (H0-scale)
by quarkhirad 10/12/2018 18:57:49(UTC)
Electric Locos with or without catenary (H0-scale)
by Jabez 16/10/2018 21:24:37(UTC)
by Kyrannosaurus 08/08/2018 11:01:16(UTC)
Overhead wiring with Sommerfeldt catenary (Model railroad wiring)
by river6109 10/07/2018 12:39:47(UTC)
Bundesbahn Catenary Safety Film (Prototype)
by analogmike 26/07/2017 02:30:24(UTC)
Brawa KLv 60.9001 Catenary Test Coach - Sound and Light mod (H0-scale)
by Moritz-BR365 28/06/2017 15:05:41(UTC)
Catenary (yet again, sorry!) (H0-scale)
by Michael4 24/06/2017 18:32:01(UTC)
Tunnel Portals for M-track w/catenary (H0-scale)
by AtlanticMan 21/05/2017 19:19:49(UTC)
Catenary mast question (H0-scale)
by DB Fan 07/05/2017 05:47:15(UTC)
Catenary Lengths and M-track (H0-scale)
by AtlanticMan 23/03/2017 21:01:18(UTC)
constructing a Sommerfeldt catenary (General MRR)
by river6109 08/03/2017 05:15:34(UTC)
Catenary and M-track (H0-scale)
by AtlanticMan 10/02/2017 20:40:26(UTC)
Catenary for M-track (H0-scale)
by AtlanticMan 07/02/2017 02:26:20(UTC)
AC operations with catenary (H0-scale)
by Leitner 19/10/2016 13:28:19(UTC)
z scale catenary (Small scale)
by thomas buckley 28/09/2016 03:22:03(UTC)
Marklin M Track catenary: Which screw type is needed? (H0-scale)
by Slider 05/09/2016 14:34:01(UTC)
old style catenary questions (H0-scale)
by thomas buckley 30/05/2016 17:53:03(UTC)
Old-Style Marklin Catenary- Wire Material and Conductive Weathering Treatments? (Painting & Weathering)
by 5HorizonsRR 09/05/2016 22:43:46(UTC)
digital and catenary (Digital)
by thomas buckley 09/05/2016 18:24:20(UTC)
Catenary vehicle I've never saw it before, have you? (H0-scale)
by Iamnotthecrazyone 03/04/2016 13:25:10(UTC)
more catenary questions (H0-scale)
by thomas buckley 27/01/2016 17:48:18(UTC)
This page was generated in 0.361 seconds.
