Offline matias
#1 Posted : 07 April 2013 17:49:07(UTC)
matias
Hello Everyone
I have been looking a 2 loco shed for my trains and I was just thinking what might be best for my needs. I think that my biggest train at the moment is German Federal Railroad passenger train approx 300 mm?? havent measured it exactly.
Been lookin for vollmer, kibri and some others, but they do not inform inside measure , I think it is only outside measures that is on details, am I right???
If someone would know inside measures for different loco sheds that would be ideal for my "longest" train, or if someone could send additional details for products that can be bought at the moment from above mentioned manufacturers (numbers that might suit my needs) that would be great
Thank you for all details that might be ideal for my train
And one more think, I have H0 Trains
Offline Danlake
#2 Posted : 07 April 2013 19:29:11(UTC)
Danlake
Hi Matias,
That’s correct the measurements is the external.
You may still be able to use below:
Faller
FA120165 – two-stall engine shed
Locomotive up to 270mm
Vollmer
5753 – two stall engine shed
External length 310mm (so should be able to fit 290mm).
Also remember it’s fairly easy to kitbash 2 sheds to make it into a double length, so that could be another option?
Good luck!
Brgds - Lasse
This page was generated in 0.206 seconds.
