marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
H0-scale
Current Märklin quality: a quick inventory
2 Pages
1
2
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
gachar001
#51
Posted :
21 October 2009 23:19:15(UTC)
Retweet
In the last 18 months I purchased new Marklin -
1. 43600 Amtrak car set, new old stock - Looks fine. I have not tried it yet as I just received it today
2. 29680 Swiss mega starter set with CS2 - Flawless. Crock needed oil, CS2 flawless
3. 29821 - Mega starter set - BR50 loco had weak speaker. Dealer fixed it but sound still weak
4. 37993 - Big Boy - Loco flawless. Wooden stand had some damage due to improper mounting of loco
5. 36080 - V80 - Flawless
6. 37653 - S260 - Flawless but noisy motor
7. 37772 - SVT04 - Body vibration during horn sound function. Have not been able to fix it yet and it is not worth sending back
8. Various cars, wagons and sets - flawless
9. C track sets, C tracks and switches - flawless
10 - 74490 - Turnout solenoids - Unusually high failure rate
11. - 39970 - Caternary maintenance car - Slight wobble (many other owners have reported this)
12. 37610 - UP Alco PA-1 - Flawless
Gautham
Atlanta, GA USA
User Profile
View All Posts by User
View Thanks
Davy
#52
Posted :
22 October 2009 01:54:24(UTC)
Retweet
Originally posted by Armando
Originally posted by Davy
<br />Quality is now much better then three years ago.
Other firms have much more problems now with their quality then Marklin now have.
Roco has a lot of trouble with their 1:87 coaches.
What exactly are the problems that you have experienced with the correct-to-scale Roco coaches? I have many of them, and so far no problems at all.
Skewed on their wheels. The coaches were a little twisted.
M-track with a CS2.
User Profile
View Thanks
Armando
#53
Posted :
22 October 2009 02:18:27(UTC)
Retweet
Do you know why that happened? Factory flaw? What did you do about it?
Armando García
User Profile
View Thanks
Posted :
22 October 2009 05:29:34(UTC)
Retweet
Other than two Roco 44976 coaches (already mentioned) where the addition of some detail parts caused a weak point and break in the the support for the axles, I have not experienced a single problem with any of my 1:87 coaches from Roco. The broken bogies were immediately replaced by the dealer.
I have noticed (once again already mentioned) that on some Roco coaches, I have had problems inserting the Maerklin 7203 coupler into the NEM shaft. I have been able to install Fleischmann Profi and Roco Universal Couplers without any problem. I do not know whether the Roco shaft opening has become tighter or Maerklin's couplers have a larger shaft than before. I have been able to solve the problem by using the Roco Universal Coupler, installing older Roco coupling shafts from a spare parts supplier or swapping Maerklin couplers with older stock on earlier Maerklin coaches. This problem has not yet been attributed to a specific manufacturer.
Other than that, the only other problems I have had has been with Liliput-Bachman SBB UIC coaches where the design resulted in the coupling shaft being a little over a mm too short, causing coupling problems when using close couplers. I solved this issue by using Roco's Universal Couplers, which have a little added length vis-a-vis the Maerklin ones. The same solution was also applied to select coaches from LS Models, RailTop and ACME as Modern Gala was also slightly off from NEM norms in earlier models.
In the last 18 months, I have bought 3 Maerklin Hobby Loks, 8 Maerklin Loks, 8 Roco Loks, 1 RailTop Trainset, 2 Liliput Trainsets and 3 Hag Loks.
They all have their positive and negative points, but they are all integral parts of my collection and hold special memories of trips to Switzerland for me.
Next in line are the Roco Re 4/4II 11109 Swiss Express and the Maerklin RABe EC followed by the Maerklin Re 10/10 and Roco ICN in 2010.
User Profile
View Thanks
davemr
#55
Posted :
22 October 2009 13:33:05(UTC)
Retweet
Hi Mike. Nice selection of locos and coaches. Roco do provide a lot of detail parts which are a bit flimsy but then I suppose it is getting them to scale.
Good to see that apart from being a Marklin enthusiast you have a wide range of other manufacturers which for the three rail hobby person is I think important.
Roco and Brawa do a good job for us in that we have a choice and Marklin has some competion.
This thread could be useful if it got back to the manufacturer who could take note to inprove on weak points in models.
dave
davemr
User Profile
View Thanks
Oscar
#56
Posted :
26 October 2009 08:09:41(UTC)
Retweet
You have been a member since:: 25/11/2003(UTC)
<font face="Verdana]
Right, let's see where we stand. Only counting Märklin items that were listed as bought recently; starter sets and batches of C-rail were counted as 1 item, turn-out motors were counted individually, provided that exact numbers bought were mentioned. Instances were the owner accidentally broke off a fragile body part were not counted as defects, unless there were other problems with the model.
-Total # of items counted: 80
-Flawless: 59 items (73,8%)
-Technical problems: 11 items (13,8%)
-Cosmetic problems: 2 items (2,5%)
-Structural problems: 2 items (2,5%)
-Design problems: 6 items (7,5%)
-Total # of problems: 21 (26,3%)
On the Dutch Märklin site, an
announcement
has been made by Märklin that they will increase quality control, as a consequence of this delivery of new models might be delayed.
@TimR:
the # of Trix items mentioned in this thread is too low to make a difference. And if Trix is included, then should I also include LGB? It's a slippery issue to I decided to stick with Märklin
</font id="Verdana]
WWW
User Profile
View Thanks
davemr
#57
Posted :
26 October 2009 11:46:21(UTC)
Retweet
The figures show a much larger number of faulty models than I would have thought. Apart from the poor quality given to the customers Marklin must be spending a lot of cash on repairs and replacements.
Good to see that quality control will now increase.
davemr
User Profile
View Thanks
gachar001
#58
Posted :
26 October 2009 14:34:03(UTC)
Retweet
Originally posted by davemr
<br />The figures show a much larger number of faulty models than I would have thought. Apart from the poor quality given to the customers Marklin must be spending a lot of cash on repairs and replacements.
Fixing items under warranty is always more expensive than better quality control overall.
Gautham
Atlanta, GA USA
User Profile
View Thanks
2 Pages
1
2
Go to Page...
General topics
H0-scale
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.308 seconds.
