Offline Ian555
#1 Posted : 05 August 2009 20:55:25(UTC)
Ian555
Hi all
Bought a 3084 loco off E-bay(from Portugal).
Arrived this morning,tried it on my test track,
runs very smoothly.Can any one help with the years
this model was made(1982?..)UserPostedImage
Offline Piggy
#2 Posted : 05 August 2009 21:14:52(UTC)
Piggy
Hi Ian, They start making it in 1974. I got one myself, if one of my favorits. I hope you will be as happy with yours, as I am with mine.
Kenneth
Offline Davy
#3 Posted : 05 August 2009 21:17:44(UTC)
Davy
Yes from 1974 till 1996.
http://www.hfkern.de/Maerklin/Dt_Loks_D50.html.
I have also this steamer. The modell I have is from the seventies.
My 3084 has be upgraded with a 60901 and drives after that perfect.
M-track with a CS2.
Offline Ian555
#4 Posted : 05 August 2009 22:25:30(UTC)
Ian555
Thanks for the information.Can you find out from
the model or type of box etc the year it was made.
Thanks for any help.
Ian
Offline Piggy
#5 Posted : 05 August 2009 22:37:34(UTC)
Piggy
They first of them came in the old strong boxes, without the transparent foil. I guess only the first year or two.
Kenneth
#6 Posted : 05 August 2009 22:42:07(UTC)
If there is a serial number at the bottom, then you can tell the year from that (from color and first digit).
The details had been posted here (will have to search it).
The box should also have a production code.
#7 Posted : 06 August 2009 00:49:24(UTC)
I guess it is between 1972 and 1980.
Offline Ian555
#8 Posted : 06 August 2009 15:11:27(UTC)
Ian555
Could not find a serial no. on the loco.
The box has the no's 60 177 Ya 08 89 sr on it.
The instructions say it can be converted with a 7180
five star kit.It also mentions a convert to digitial
using a c80 decoder.
Can this help narrow down it's year of manufacture.
Thanks again
Ian
Offline Nigel Packer
#9 Posted : 06 August 2009 15:29:12(UTC)
Nigel Packer
[size=1" face="Verdana" id="quote]quote:Originally posted by Ian555
<br />Hi
Hi Ian,
That means the box was printed in 1989 (08 89 is the month and year), so the loco is probably 1989 too, or possibly slightly later. From 1982, this loco has die-cast cross-heads (the sliding bit on the valve gear) as opposed to folded sheet-metal.
Possibly, the chassis number label will be under the pony truck - you might be able to see it if you move the pony truck to the side, or else if you remove it.
Hope this helps!
Nigel
Offline Ian555
#10 Posted : 06 August 2009 15:59:54(UTC)
Ian555
Hi Nigel
You were right, the chassis no.is 00179320
Thanks for the help.
Ian
#11 Posted : 06 August 2009 16:08:26(UTC)
Nigel Packer
<br />You were right, the chassis no.is 00179320
So this loco was made in 1990! The first digit of the chassis number is the last digit of the year. Analogue locos do not have an initial letter designating decoder type.
So I think that's a complete dating process!
Best wishes,
Nigel
Offline Ian555
#12 Posted : 06 August 2009 16:47:25(UTC)
Ian555
Hi Nigel
Hopefully this information will help when I find out what is
required to convert Loco to digital.(eventually)
Thanks again.
Ian
#13 Posted : 06 August 2009 17:05:09(UTC)
Ian, I converted mine very successfully with a 60760 kit. If you want a better decoder you can always replace the one in the kit with a lokpilot V3.
Offline Piggy
#14 Posted : 06 August 2009 17:17:33(UTC)
Piggy
Exactly Ray. And you can use the hidden F3 if you have a smoke generator, look for 60760 and F3 in the digital section of this forum. I placed a thin PCB strip on top of spring to the smoke gerator, that way separating it from headlight. Later on I changed the decoder to a Loksound MFX, there plenty of space in the tender.
Kenneth
#15 Posted : 06 August 2009 18:20:13(UTC)
Here are some photos from the conversion:
<font face="Times New Roman]The gearlight has been added, Smokegenerator has been seperated from the light source</font id="Times New Roman]
<font face="Times New Roman]Here you can see the motor is upside down</font id="Times New Roman]
<font face="Times New Roman]The 10 wheel rubbertyres was an addition before we had loadregulated decoders</font id="Times New Roman]
Offline Ian555
#16 Posted : 06 August 2009 20:52:31(UTC)
Ian555
Hi all
Thanks for the information on converting loco 3084 to digital.
As you know I haven't started my layout yet(baseboard Oct/Nov.time)
Will go over parts reqd. suppliers once I've got some track laid.
Will keep in touch.
Ian
#17 Posted : 07 August 2009 00:39:53(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by river6109
<br />UserPostedImage
10 wheel rubbers - what clever solution, congratulations, John Smile[:p]Cool[^]
She must be one excellent puller ...
And congratulations on your new beauty, Ian CoolCoolCool
#18 Posted : 07 August 2009 01:07:52(UTC)
Don't you get problems getting a good ground connection with tyres on all the drivers?
#19 Posted : 07 August 2009 01:54:18(UTC)
<br />Don't you get problems getting a good ground connection with tyres on all the drivers?
The ground connections are picked up from the front bogy and the tender 4 axles.
Today it would'nt be necessary to do this.
regards.,
#20 Posted : 07 August 2009 01:56:29(UTC)
One could say it is a bit of an overkill but you're right she is an excellent puller.
regards.,
Offline Ian555
#21 Posted : 07 August 2009 12:44:09(UTC)
Ian555
Hi All
Got a Loco 3047 on it's way in the post(E-bay).Says it's in Mint condition.Will start new topic with photo and info when it arrives.
Ian
#22 Posted : 07 August 2009 13:47:19(UTC)
<br />Hi All
Ian
Very good, It is a heavy loco with large motor.
You may notice the black box in the cab.
#23 Posted : 07 August 2009 16:00:25(UTC)
Nigel Packer
<br />Got a Loco 3047 on it's way in the post(E-bay).Says it's in Mint condition.Will start new topic with photo and info when it arrives.
Ian
Probably my favourite of all Märklin locos.
My father bought me one new for Christmas in 1964, and I still have it today. At that time the technology seemed incredible (especially when compared to what British manufacturers were producing then). All metal loco, 2-10-0 with flanges on all wheels, articulated all-wheel gear drive, working lights, working smoke, Telex uncoupling, huge pulling power. What an amazing model! I love it!
Best wishes,
Nigel
Offline Ian555
#24 Posted : 07 August 2009 19:59:32(UTC)
Ian555
Hi Nigel
I have a catalog from 1964 and it says the 3074 was brand new model in that year.If the postal strike doesn't upset things then should
have it next week.Will let you know what condition the Loco is in.
Ian
Converting a Marklin loco 3084 (Digital)
by river6109 24/12/2011 11:53:04(UTC)
This page was generated in 0.757 seconds.
