Online Ian555
#1 Posted : 13 July 2009 19:43:36(UTC)
Ian555
Hi all
Some very basic questions about the mobile station (sorry).
It can run up to 10 trains all at the one time.
If say 10 trains running can you stop 1 reverse it and then travel in
the opposite direction,while the others carry on.
Can it run a mixture of track and overhead loco's at the same time.
Can they be isolated from each other using M track (say 4 stations)
Can they control points/signals.
Thanks for any help.
Ian
Offline dntower85
#2 Posted : 13 July 2009 20:15:10(UTC)
dntower85
1. You can store up to 10 trans and have them ready to run on a mobile station, but do to the amount of power that the mobile station puts out 1.2 or 1.9 amps (depends on when it was made) it will most likely only want to run 3 or 4 at a time. Lights on coaches and smoke units all take power. As soon as the Mobile station hits its power limit it will think it has a short and will shut off the power.
2. yes all locos are independent as long as the address is different so any can be stopped reversed and functions can be trigged independently.
3.You can combine C M and K track, not sure what you mean by overhead track.
4. I let some one else help on isolating m track but there should be a way. if they are independent loops there is no problem
5. yes you can control by signals either digitally or by the older relay style signals all though there is a few tricks to do it that way.
Ian, do you all ready have 4 mobile stations or are you planning to buy them. A Central station 1 or 2 or an ESU EcosStation might be a better choice.
DT
Online Ian555
#3 Posted : 13 July 2009 20:38:11(UTC)
Ian555
Hi Darrin
Not starting the layout for another couple of months,have not got any
digital equipment yet,unsure of what to buy.On my old anologue layout
(20 years ago)I could run up to 12 loco's at the one time,all of them
moving together.I used 5 old style transformers to do this.
I would like to duplicate this but using digital equipment but will stick with using M track....any ideas.
Thanks again
Ian
Offline mmervine
#4 Posted : 13 July 2009 20:41:23(UTC)
mmervine
Ian: You can download the MS manual in English here
http://www.marklin.com/n...004/systemssoftware.html
Offline James
#5 Posted : 13 July 2009 23:47:36(UTC)
James
Ian:
You Asked:
"It can run up to 10 trains all at the one time."
Yes... with the older Mobile station you can control up to 10 locomotives. This is due to the fact that the mobile station can only store up to 10 locomotive addresses in it's buffer. Apparently with the newer mobile station the buffer can be increased to 11 locomotives with the card reader option. But... as Darren said, this take a lot of power to do. More than a single Marklin Trafo can supply.
You asked:
"If say 10 trains running can you stop 1 reverse it and then travel in the opposite direction,while the others carry on."
Again, yes, in a digital environment power is now supplied continuously to the rails, which is why a greater amount of power is needed for your layout. Instead of a rehostat controller supplying power to the system in incrimental units (ie: the more you turn the knob, the more power you feed to the system) power is now continuously fed to the rails at a constant level. To test this, just place one of your older locomotives on the digital tracks and it will take off at a very fast speed and it will be uncontrollable. In order to control the locomotives the controller (mobile station/Central station) "communicates" by way of a decoder located in each locomotive which is designated by a specific address. The controller then "issues" commands for said locomotives/address (either foreward, reverse or stop). As was stated, the mobile station can store 10(11) locomotive addresses, while the Central station can store considerably more. While I'm not sure just how many it can store, I know that it can store up to at least 80 but I I've heard it can store more and I'm sure that someone on this list can tell you the exact amount, suffice to say, more than anyone could conceivably need or use
You asked:
"Can it run a mixture of track and overhead loco's at the same time."
I'm assumeing that by overhead loco's you mean Catanery, if so the answer is again, yes, although due to the "somewhat flimsy" connections between the Cat wires, Marklin doesn't recomend using this set-up to run locomotives as the connections cannot ensure the proper conduction of the digital signals to your locomotives. (Although, on an aside note, Catenary is the one instance that you can use your older "analogue locomotives" with a digital system. Due to Marklin's common ground system, you can supply an analogue signal to the Catenary wires and use the common ground as a return to your transformer.)
You asked
"Can they be isolated from each other using M track (say 4 stations)"
This one is difficult due to the fact that I'm not sure what you mean by "using M track". As far as using 4 stations, and again, I'm assuming that you mean 4 mobile stations, the answer is no.
Each mobile station requires a separate source for power, which would mean combining 4 separate transformers, something that is not recomended as it would cause a cumulative incriment in power to the layout which would cause at the very least a burn out of your system (damaging many expensive locomotives/solenoid equipment) or... at the worst... a serious overload of household electrical systems which could result in serious electrical shocks.
If you choose to go the route of a Central station (which I would recommend) extra Mobile stations can be connected to the system through connection on the Central station or through a special connection box (sorry, I don't have the part number at this time, but a dealer can tell you what the number is)
And lastly, you asked:
"Can they control points/signals."
The answer to this is yes and no. That is... with the older Mobile station, the control of the solenoid or control points was/is not possible (again, due to the buffer size). With the newer Mobile station the control of solenoids/control points is now possible.
If you are going with the older Mobile station for controlling your layout, you will still have to control your solenoids through the older (tried and true) control box set-up. The good news with this is that if you are using the control box system you can use any older "analogue" transformers to supply power (separately) to the control points.
That is, just don't ever...ever... ever hook up a "red" wire from your analogue transformers to the "red" wire of a digital transformer.
Hopefully... this helps. If you want more info, feel free to contact me offline anytime, and good luck!
____________________________________________________________________________________________________________________________________________
James Bannerman
Give me steam, and how you feel can make it real, real as anything you've seen. (Peter Gabriel)
Online Ian555
#6 Posted : 14 July 2009 00:20:49(UTC)
Ian555
Hi Darrin and James
Firstly I'd like to thank you for the time you took to answer my what must seem very basic questions.After reading thro your answers
a couple of times it looks like with the number of loco's I'd like to
run(12) all at the one time a Central Station would be the way to go.
This would then be 1 controller for the whole layout,is that rite.
I plan to also run a section of the layout(no track conn.)using my
"old" analogue loco's and transformers.Can this ground(earth) wire be connected to the digital ground?
Also did I get it rite that I could run a cantenary loco using an analogue transformer but on the digitial section of the layout?
The complete layout will be using the old M track
Note. The cantenary loco is not digital.
Thanks again
Ian..(things are getting a little clearer)
Offline dntower85
#7 Posted : 14 July 2009 01:23:16(UTC)
dntower85
I would not recommend connecting any ground from the analog system to the digital system.
But.... I just had a thought of something that I never had thought of before.
****So hopefully some one else might be able to commit on this.****
The digital system puts out a constant 16-18 volts from the central or mobile station. and if you place a old analog Loco on the track it takes off at full speed.
So if this loco is run form the Catanery what would happen if you put a variable resistor between the power feed to the catanery. no way to reverse the old analog lok but I think it might work.
Could the variable resistor cause some feed back or damage the digital system?
DT
Offline davemr
#8 Posted : 14 July 2009 01:32:26(UTC)
davemr
Looking at what you require I would buy the new Central Station.
Not sure why you want to use M track (other than you have it at present) C track will give you better running and it is easy to instal decoders under the track etc.
It might be that buying a cheaper starter set with a MS would give you the understanding of the system and allow you to then plan ahead for what you want.
davemr
#9 Posted : 14 July 2009 01:57:59(UTC)
Hi, Ian!
[size=1" face="Verdana" id="quote]quote:Originally posted by Ian555
<br />This would then be 1 controller for the whole layout,is that rite.
That's the standard in the digital word: a single digital central controls the whole layout (adding boosters if more power is needed).
But additional controllers can be connected to this central (a few Mobile Station or another Central Station).
<br />I plan to also run a section of the layout(no track conn.)using my "old" analogue loco's and transformers.Can this ground(earth) wire be connected to the digital ground?
Yes - but why should it if tracks are not connected?
Connecting centre rails could then kill the digital controller.
<br />Also did I get it rite that I could run a cantenary loco using an analogue transformer but on the digitial section of the layout?
Sure - but a shortcut between catenary and centre rail could kill the digital controller.
How should such a shortcut occur: any piece of metal (e. g. a Märklin tin-plate coach) could do it. Modern plastic coaches are less risky. wink
Offline James
#10 Posted : 14 July 2009 06:36:59(UTC)
James
Ian:
You can use an older electric locomotive with overhead pick-up capabilities on a Marklin digital layout by feeding power to the catenary lines.
HO is correct in saying that a problem could occur if the overhead lines were to find a direct route to the digital 3rd rail. Although it would require the catenary line coming into contact with the centre stud (puko) while power were being applied to both systems (this could occur if the cat wire were to drop down onto the track below it and touch one of the centre studs).
As far as running two separate layouts (one digital and one analogue) HO rightly poses the question, why run the risk connecting the ground wires? If the two layouts are completely separated with no physical track connections, better to run separate power feed set-ups and save yourself some grief.
As for running M track on your layout... Many members on this list do so with no apparent problems (I do as well). My only advice in this regard is to make sure your track sections have good electrical connections.
As with the catenary, according to Marklin, older M track sections lack the physical capabilities to allow for proper conduction of the digital signal (loose connections etc.). M track is prone to power "drop outs" while undetectable on analogue layouts, can, in theory, play havoc with the digital set-ups. Of course, this could also just be a Marklin ploy to get you to purchase their newer C track wink, which they claim offers a better electrical connection.
Digital signals do not require that the wires/rails etc. be large, or that the voltages be as great as those in analogue. In analogue set-ups, electrical power is distributed much like that in your household power set-ups. The rules of volts, amps, resistance apply. In a digital system, control of the locomotives is done by sending low power pulses down the lines to communicate with your layout's engine/solenoid decoders, not unlike your telephone line set-ups these days.
Good luck with your digital experience.
(Just wait until you start using a mouse to control your layout! biggrin)
James Bannerman
Offline davemr
#11 Posted : 14 July 2009 14:11:19(UTC)
davemr
James. Having used both I can confirm that C track does offer better electrical connection. If already using M track and happy then of course no need to change but if starting from scratch then C track is the way to go. (or K if you wish to ballast by hand)
davemr
#12 Posted : 14 July 2009 15:14:15(UTC)
Ian,
One thing I would like to consider which central station you buy.
although Märklin is in safe hands for the moment and a possible buyer can be found by August or September.
On the other hand ESU has had previous plenty of experiences into digital components including the Ecos. it is consumer friendly.
sofar the Mobile unit is concerned there is another snag you may come across, which has'nt been voiced.
For instance if you register 10 locos into your mobile station (max. numbers)and a 11th loco (mfx loco) onto the track, the mobile unit tries to register it, but because the maximum numbers have already been entered, the mobile unit shuts down.
regards.,
Offline James
#13 Posted : 14 July 2009 21:25:54(UTC)
James
Dave:
You're absolutely right.Smile
My "Lorelie" layout is currently undergoing the change from M track (which I inherited from my Dad) to K and C track. I'm using K track (flex)for my mainline runs, and C track for seconday routes and yards. M track, which currently occupies my shadow yards, will eventually be replaced with 2 rail "flex track". I will run a third rail down the centre, not unlike the older M track sections.biggrin
I do sympathize with those members who are currently using M track and are thinking about changing to C track. It is very cost prohibitive, to say nothing of the labour required. My advice (for what it's worth) to those who are intending to go digital, but wish to remain with M track, would be to ensure that you increase the number of power leads to your trackage.wink
But I have digressed from the original topic and I apologize to Ian.[:I]
James Bannerman
#14 Posted : 14 July 2009 22:29:32(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by James
<br />Digital signals do not require that the wires/rails etc. be large, or that the voltages be as great as those in analogue. [...] In a digital system, control of the locomotives is done by sending low power pulses down the lines to communicate with your layout's engine/solenoid decoders, not unlike your telephone line set-ups these days.
Not really: track voltage is higher if you run digital (CS1 reloaded comes with a 90 W power supply and a 4 A booster output).
Constant power on the track (typically 22 V with Märklin H0), commands are encoded by the pattern of polarity switches on the track (rectangular wave, not a sine wave).
Cables should be as thick as on analogue layouts (or even thicker).
If a cable loses 1 V at 1 A then it'll lose 4 V at 4 A.
When running analogue, you'll normally have one transformer for every running loco (1 A).
When running digital, you can run four or more locos from one booster - more Amps, higher voltage drop.
Offline davemr
#15 Posted : 15 July 2009 01:26:31(UTC)
davemr
Hi John. Just a quick mention for the CS2 which I feel is a better bet than anything from ESU with regard to which firm will survive in the long term.
ESU is very small compared to Marklin and small is not always safe.
Hopefully there will be a new mobile station from Marklin (not made by ESU) which should be better than the orginal Mobile Station which was a disaster.
Both products are good but if and when Marklin gets going again then the CS2 should be the best bet for the future.
For Ian I still think a cheap starter set is the best way to get up and running. You can compare the track which comes free.
davemr
Offline Dreadnought
#16 Posted : 22 July 2009 05:13:01(UTC)
Dreadnought
HELP!!!!
I bought a mobile station on ebay. I thought it a cheap way to try digital before going whole hog on a CS 2.
It arrived today. It has a piece of C track with the connections for the plugs. My layout is M track. Looking at "apendix A" in the manual it appears you can connect red and brown via a small white box to 1 scale or Z scale. I can't find that "box" in the catalogues.
How do I connect to M track????
Do I need to put the connector piece of C into the layout, and then get two C to M adaptors to make it work?
D
#17 Posted : 22 July 2009 05:35:34(UTC)
Easiest way is to use the 'ugly box' piece of C track. Connect your mobile station and transformer to that. Connect one red and one brown wire from underneath the 'ugly box' piece of C track to your M track feeder rail. Make sure that any capacitors in the M track feeder rail are removed, as they are not needed for digital operation, and can interfere with the digital signal.
The red wire goes to the 'B' terminal, and the brown wire to the 'O' terminal, underneath the piece of C track.
Offline Dreadnought
#18 Posted : 22 July 2009 07:32:53(UTC)
Dreadnought
Thank you!!
It works. It is a right mess of wires, but what a pleasure to watch the Belgian 2 10 0 with condensing tender. I like the control over the fans, lights, and the smoke generator.
Now to figure out how to get my other digitals recognised.
D
Offline Dreadnought
#19 Posted : 23 July 2009 06:22:43(UTC)
Dreadnought
Thank you both for your help. I have two now working on digital, and love it.
In my catalogue 60115 shows for K track, no mention of M. I assume you mean it will work for K and M?
D
This page was generated in 0.589 seconds.
