Offline KevinM
#1 Posted : 03 January 2026 21:32:02(UTC)
KevinM
I am a long term member but infrequent poster, but always get good, useful information here.
I am starting on a new layout. I have used and still use Rail Modeller and have for a long while. I have come across some 3800 and 3900 track and I want to use it in the new layout.
As far as I can figure Rail Modeller doesn't support the 3800/3900 track.
I have been looking at Wintrack since it does support 3800/3900 track, but Wintrack is cumbersome to use. using Rail Modeller I was up and planning in an hour or so.
Not so with Wintrack. I've slogged through a dozen or so learning modules but it's not helping or not quickly.
I'm just trying to fit a layout together and outline the space. Is there a quick and dirty way to do this using wintrack or a way to add 3800/3900 to Rail Modeller?
Kevin
SBB Era III
DB Era IV
SBB Era V
4415 basis beer cars
#2 Posted : 04 January 2026 11:00:15(UTC)
SCARM has Märklin M-3900 library for download.
Wintrack is excellent, despite of its learning-curve. I used it for designing my own layout 20 years ago, but a lot has happened with it since then (most of which I am not familiar with)
Offline KevinM
#3 Posted : 06 January 2026 00:06:24(UTC)
KevinM
Thanks Henrik. I actually started tinkering with SCARM before I posted and went deeper after your post. It only took a few minutes to get the basics down. Should work for me. Went for enough with the free version to see how I could use 3900 series with the 'modern' 5100/5200 series. I found one way that will work. I'll put up another post to see what other recommendations others have for combining the two track series.
Thanks again,
Kevin
SBB Era III
DB Era IV
SBB Era V
OceanSpiders 2.0
This page was generated in 0.298 seconds.
