Offline sudibarba
#1 Posted : 05 January 2026 02:49:09(UTC)
sudibarba
Does anyone know if Marklin is planning a new controller? It was not many years between the CS1
and the CS2. CS3 has been around a while now. My CS3 works fine right now but it is getting years
on it. If it fails I could get by with my old CS2 or even the 6021 for some of my loks But....
#2 Posted : 05 January 2026 07:33:07(UTC)
Those who know are not allowed to talk about it.
It was not many years between the CS1 and the CS2.
The CS1 was an ESU ECoS with red buttons, the CS2 was developed by Märklin with a new partner and probably more profittable.
As long as the hardware does the job and is still available, why come up with a CS4?
The ECoS is still around, just with a new display - so the hardware is quite fast and capable if you take the time to optimize the software.
The real CS2 is somewhat slow, but the PC version reacts very fast. Just dreaming of optimized software for the CS2 that makes it much faster...
#3 Posted : 05 January 2026 13:05:01(UTC)
With any electronic devices, age can affect performance if capacitors, resistors or transistors lose their efficiency and get out of spec. Heat causes damage too. As far as anything new on the horizon, factors that may determine that are economics, market research and the competition.
#4 Posted : 05 January 2026 13:55:32(UTC)
One would have to ask what "new features" you would expect in a new model. About the only ones I can think of are larger 'disk' size and faster processor. Now the cs3 already has a quad core ARM controller, and there is nothing that could go in place of that and provide faster processing without going to a PC style processor, that I am aware of.
Yes it could do with a larger 'disk', but you can add a 32GB SD card in a slot to provide about four times the 'disk' capacity on top of the on board storage.
Maybe it could do with more RAM, but I'm not sure just how much it has, and it seems to get along just fine with what it has.
Anything else is essentially software features, which, disk capacity allowing, can be added to the existing cs3.
And also remember that with the current AI revolution swallowing up any sort of memory chips the price of a cs3 is only going to go up considerably in the coming year, and any new model will only suffer that same problem even more.
Offline rhfil
#5 Posted : 05 January 2026 15:11:48(UTC)
rhfil
kiwiAlan you seem to have knowledge of the CS3's architecture. Would it be possible for Marklin to expand the RAM and ROM sizes for people with the 32GB SD cards through a limited software update? I haven't been able to figure out what exactly the card adds to a CS3 but then my CS3 will not accept a card.
Offline dsinn
#6 Posted : 07 January 2026 18:10:48(UTC)
dsinn
That's not quite accurate. There are multiple 6, 8 and more core small CPU's you can find that are used in the RaspberryPI like small system space. Ditto in the embedded phone world either publicly or only for private consumption (aka Apple and their iPhone custom CPU's).
This is actually the real problem faced by Marklin. Not the costs but the specific parts they are going to use. Eventually the CPU and RAM being used in the CS3 will reach end of production. Even in the embedded space, 10 years is the nominal longest run-time for a given part. Eventually Marklin will be faced with the choice of redesigning the existing CS3 to use the new part or starting from scratch and making a CS4. They are also no where large enough to force a supplier to continue production of a chip that the supplier wants to end. So that points to the CPU and/or RAM being the most likely parts to be phased out. RAM is the more likely of the two as AI is demanding the more modern HBM and DDR5 style memory that the CS3 just doesn't use. Secondarily which ever chip fab their supplier is using will eventually phase out of the old silicon processes to move to newer more lucrative ones, so the parts will go away.
Now that can be offset by last time buy's from your suppliers, but even then that runs out and that has ended up ending badly in some random cases (a few years ago a VERY common chip was ended by a supplier who banked the final production run for it's customers but when they un-banked the dies to put them in chips the failure rate was far higher and it caused a scramble for everyone using that part). So eventually those parts will run out and Marklin will have to decide what to do. A board redesign to support newer parts is not cheap and often approaches the costs of a whole system redesign where you can add in improvements (parts shrink so you can produce them cheaper, more functionality, etc.).
thanks 1 user liked this useful post by dsinn
OceanSpiders 2.0
Is the Marklin controller working well with the new locos? (Small scale)
by husafreak 10/09/2019 19:56:24(UTC)
Marklin Controllers aka Transformers (H0-scale)
by Danny_82 06/09/2015 09:12:53(UTC)
This page was generated in 0.599 seconds.
