Offline LA2019
#1 Posted : 18 December 2025 23:27:44(UTC)
LA2019
I have a large circle of track on the patio. I'm going to add two independent sidings to hold one loco while the other runs. I have an LGB 1205 and 1215 turnout. Can I convert these to power routing (when I throw the switch) or do I need to wire both sidings the old fashioned way with blocks?
I attached an image of the layout and how I plan to use the turnouts to hold the locos.
The back of the LGB turnout.
Ken
USofA
thanks 1 user liked this useful post by LA2019
#2 Posted : 19 December 2025 03:48:31(UTC)
FD is interested in the answer to this one too. She has just bought the turnout set and a bunch of track so that she can run her marklin maxi/1 gauge stuff in the garden.
Offline rbw993
#3 Posted : 19 December 2025 14:12:16(UTC)
rbw993
LGB part no. 12070 will do the trick. It is an auxiliary switch that mounts to the switch motor.
Offline LA2019
#4 Posted : 21 December 2025 15:33:24(UTC)
LA2019
Sorry, should have clarified. I will be using the switches manually (a.k.a. 'the hand of God').
Seems that the easiest way is to just block the turnout and use a DPDT switch.
Ken
USofA
This page was generated in 0.342 seconds.
