Offline Michael4
#1 Posted : 09 December 2025 10:14:04(UTC)
Michael4
Analogue, have I gone a bit too far?
I have a circuit with the catenary powered by a transformer and the track powered by 6699.
The idea is that the lights in the carriages can be controlled while the train is on the move. I have also incorporated some contact tracks (5146 etc) so that the carriage lights come on and go off when activated using a remote switch.
So far, so good.
Now I thought I'd replace the 6699 with our old friend 6600. Then using the 6600 functions the lights could be delayed or made to come on gradually. I also would not need the remote switch
The 6600 functions I am using are the variable ones for controlled acceleration and pause.
A problem arises.
Using 6600 with its functions turned off it performs as you'd expect and controls the carriage lights when the dial is turned. However, when you select the 6600 functions the set up shorts.
Why? The catenary power is not connected to the track power in any way except negative/earth. What have I done?
Perhaps it is time to question my sanity...
#2 Posted : 09 December 2025 11:10:47(UTC)
Hi Michael
I love the 6600 unit but alas it was almost instantly killed by digital to which it was incompatible
Difficult to diagnose what is happening. some some questions:
Is your 6600 unit fully functional?
- does it shorts when not connected to the rest of the layout even when activating fonctions?
- does it work with one loco alone, a piece of track and fonctions on? Of course not the last fonction on the right which is the emergency stop
I don't know how compatible is the 6699 with the 6600 so as to run on the same transformer: Check with separate transformers
Of course you probably are familiar with the 6600 fonctiions
Of course you know the 6600 is NOT compatible with digital locos and I am not even sure about locos with preselection / electronic direction relay
The sort may be caused by (sorry as it is obvious):
- a wiring error (so better test the unit with a very simple bunch of rails to see if the same short appears)
- a fault in the 6600 unit (this is still possible but unless your are an electronician, it will be difficult to repair.
So, if when disconnecting all wires to the fonction plugs on the 6600, the unit works then you probably have a wiring issue.
Sorry this is all I can say as now I am fully digital and I still have my lovely 6600 but it remains in its box
Offline Michael4
#3 Posted : 09 December 2025 15:27:15(UTC)
Michael4
Jean,
Many thanks for your input. I have tested the 6600 and it has passed with flying colours.
A few years ago I had a conversation with Marcus Schild about 6600 and 6699. I see hasn't posted for ages.
My memory is not helping but I think he said that they both use pulse width modulation to control the loco. I wonder if PWM clashes with a normal controller in some way, maybe through a shared negative/earth?
Of course you have to remember that I do not know what I am talking about...
#4 Posted : 10 December 2025 05:43:18(UTC)
I just love my 6600. I played around with using it on my Wonderwheel for the acceleration and braking, it worked really smoothly but I've yet to find a way to trigger it after a set time delay, or, number of revolutions of the wheel.
I was hoping to be able to count revolutions mechanically but it proved harder than I first thought so I'm using a modern delay time in the meantime until I figure it out.
It's a much under-rated accessory, in the right situation.
#5 Posted : 10 December 2025 11:19:40(UTC)
A problem arises.
I own 3 of these lovely units. I originally planned to use them on my analogue layout, but eventually found that I could get further with PLC control, and at the same time avoid the problem with decoder-equipped locos entering the 6600 controlled tracks. (Analogue "5-star" equipped locos also do not work with the 6600 unit!)
BUT; I still have one of these units wired up to a station track, and actually went and performed a test based on your description above;
It works perfectly, and you are not going too far.
I hooked up 2 waggons with interior lighting; one with a LED strip, and the other with bulps.
I set the dial of the 6600 to (almost) max, and enabled the pause and reverse functions. The dials for acceleration, braking and pause I set to around half position, in order to see the effect well.
I then pushed the waggons slowly down the track, until it first trigged the BRAKE+PAUSE function of the 6600 unit, and then a little bit further down the track, until it triggered the REVERSE function of the unit.
Both events executed perfectly, with the lights dimming after the brake triggering, and flashing brightly (1 time) when triggering the reverse.
At the end of the pause, the lights slowly came back on again.
In no moment was the STOP triggered, or a short detected.
Sorry for this long-winded description, when a video cdould have shown it perfectly, but it was a rather uncomfortable position climbing onto the layout in order to try these "de-commisioned" cabled functions out.
So if your system fails, you should simplify the setup and double-check your wiring. (Maybe you got brown and yellow reversed on the 6600 unit¿?)
Also, be sure to have common ground between the normal trafo and the 6600.
Good luck!
#6 Posted : 10 December 2025 11:38:46(UTC)
Well, the 6600 units can´t count the revolutions, but the wonderwheel -being build with Metallbaukasten- you should be able to build a reduction-gear coupled to the wheels main axle, and if you can make another wheel spin at a ratio of -say- 1:10 of the main wonderwheel, the geared wheel could close an electrical contact at a certain position, thus allwoing the wonderwheel to spin 10 times and then trigger the PAUSE-input of the 6600-unit.
You should then rely on the intertia (or the brake-setting of the 6600) of the wonderwheel again to OPEN the electrical contact of the geared wheel, otherwise the PAUSE will be maintained forever...
In any event, the max time for the pause that the 6600 unit can do, is around 35 seconds (unless -as mentioned before; the trigger-input is continously shorted)
Also remember that any BRAKING effect set on the 6600 unit will eat into the set pause-time!-So if you want a really smooth stopping, you´ll eventualyl run out of time and the acceleration will begin again. -Which renders this whole setup rather dubious; (Refer to my comment before to Michael, that I found that pure PLC control will yield better results if your desired fuinctionality is more complex...)
#7 Posted : 11 December 2025 03:41:52(UTC)
The original design of the Wunderrad is to run for approx 3-4 minutes, then via a thermal relay, track power is cut for about 20 seconds.
The purpose of this is to confirm to observers that is it in fact the little 3000 Loco driving the entire display. And it's very effective.
I did some experiments with the 6600 a few months back and there are absolutely no issues with replicating this timing and I personally like the more smooth start and stop, the wheel doesn't tend to oscillate so much when stopping.
The *only* issue is how to trigger it. Hence looking at a 'counter'.
There is only one axle in the display that is standard and that I could tap off relatively easily. But I've experimented with M-M and Meccano gears (largely identical), and even M-plus system gears because they have a totally different range of ratio options and are designed to be fully compatible with M-M but I didn't get far.
One thing I quickly found was that if I used a worm-gear arrangement for example, the minute the number of revolutions (approx 10) was achieved, when the 6600 was triggered it would stop relatively quickly, but the trigger would remain active, preventing the 6600 from starting the acceleration again.
I'm sure there will be a solution, I even constructed a replica of the drive area so I could experiment on the workbench rather than the wheel itself but I had an exhibition looming so decided to employ a modern delay timer which works perfectly, 100% - except, it's not Märklin of course.
On the other hand, neither was the original bi-metal cutout, but it was installed by the factory when the apprentices built the model so it's still authentic, just unobtanium and definitely not worth trying to repair.
At the exhibition (as a guest of a joint Meccano & LEGO display) the reliability of it really grew on me, I also installed a PIR sensor so that it would only run when someone was actually in front of it. I toyed with the idea of an interactive switch that you maybe had to press or whatever to start it but that was just something else to potentially go wrong.
Here's a short video of the electronic timer in operation. That was a prototype, the final reuslt is slightly tidier but same idea.
#8 Posted : 11 December 2025 07:45:59(UTC)
First thing I would do is to make sure that mains plugs of the transformer(s) you are using for catenary and to power your 6699/6600 are in the same polarity. This also applies to the connections between the transformer and controller (6699/6600) and between the controller and the track.
AFAIR the 6600 was to be connected to the brown and yellow outputs of a transformer. Are you using the red and brown of the same transformer for the catenary or a different transformer?
What happens when you disconnect the catenary from the transformer? Does the 6600 still short?
What locomotives are on the track when this occurs? Is it possible that the locomotive is somehow bridging between track and catenary? Is the switch not completely to one side?
Does it short if there is no raised pantograph, but the locomotive is on the tracks?
#9 Posted : 11 December 2025 15:09:18(UTC)
How similar to the bi-metal cutout in the old 280 series 30VA and related age 16VA and 10VA transformers is it? That could be a vital source of spares.
Offline Michael4
#10 Posted : 11 December 2025 15:30:57(UTC)
Michael4
Thanks for all the suggestions. Rather than go over it again I will build a test track and let you know how i get on.
Offline Michael4
#11 Posted : 11 January 2026 09:44:25(UTC)
Michael4
Well, Christmas got in the way but I have now built a little test track.
Loco is powered by catenary and normal controller, track power for coach lighting supplied by 6600.
The test track works confirming that I need to go over the wiring on the layout looking for a fault.
So now I can control carriage lighting, the 6600 function for pausing a loco will turn off lights and turn them back on again after a set time (quite short as mentioned above).
The 6600 function for controlled acceleration and braking will turn lights on and off 'softly' ie gradually.
One question remains...why did I want to go to the bother of doing this in the first place??!!
#12 Posted : 11 January 2026 10:45:17(UTC)
I may be repeating myself, but the PAUSE time can be prolonged indefinetly if you maintain the input-signal to the 6600 shortened!
I.e: It will do the braking and then maintain 0V output until the input-signal is released; If there is still time left on the timer, it will wait, but once the input-signal is released AND the timer has expired, the acceleration will begin.
So you CAN have a longer pause, if you can control the input-signal (maybe by using a UFS)
Offline Michael4
#13 Posted : 11 January 2026 16:46:41(UTC)
Michael4
Henrik,
Many thanks for the info about extending the PAUSE time, I will make use of it later..
Best
Michael
This page was generated in 0.773 seconds.
