Offline Bfloeyes
#1 Posted : 02 December 2025 16:57:57(UTC)
Bfloeyes
Hello. Just found this forum. I purchased a Maxi starter set 54402 when my kids were little. Used around the Christmas tree primarily. Trying to do the same with grandchildren.
The train will only go in reverse and only at full speed.
Is this a common problem? Can anyone help me find a solution?
Thanks!
thanks 1 user liked this useful post by Bfloeyes
#2 Posted : 02 December 2025 17:27:12(UTC)
May not be the transformer. Does it run in the opposite direction if you turn it around on the track? I remember when it came out, but not if it has a Delta/digital decoder or is analog.
Offline ccranium
#3 Posted : 02 December 2025 18:19:28(UTC)
ccranium
The 1996 catalog says for 54402 "Tank locomotive with built-in electronic circuit plate for operation with AC power or Marklin Delta. Electronic circuit plate included for operating the locomotive with DC power." The image of the trafo looks like an analog 6647 for 230V; the text says the US version of the set comes with a 6627 for 110V which has a blue plastic case.
So it sounds like you should be able to run it without a Delta controller; I think you can reverse the direction by turning it around on the track as suggested above, or by switching the power leads on the trafo. If it's only going at full speed, you may have power coming from the L circuit which is for lighting and accessories. Be sure to use the B and O connections on the trafo to get variable speeds.
I'm not familiar with the Maxi line so I don't know if the reversing function on the 6627 will do anything. It's the far counterclockwise momentary position past "0" which gives a momentary ~27V pulse to HO-scale reversing units.
I hope this helps.
Brian
#4 Posted : 02 December 2025 20:49:06(UTC)
As you said it is very likely there is a delta electronic inside with switches and all off is for analogue (DC) operation if I remember right
Her'e is the Märklin generic document on how to set Märklin decoders of any type
Coding table
#5 Posted : 03 December 2025 06:52:10(UTC)
If the set was set up for DC operation using the controller, there was a direction switch to invert the polarity, which would switch the direction of the train.
If the set was set up for AC operation using a 32VA transformer, direction change should be controlled by moving the knob counterclockwise past 0 for a short moment
If the locomotive has been set for Delta operation, you should have a digital controller which would connect to the track or the transformer. Some versions came with this:
https://www.maerklin.de/...55d89f3c63b37f04436a9dcb
Can you provide a photo of your transformer and of any controller you might have with your set?
This page was generated in 0.309 seconds.
