Offline jonas_sthlm
#1 Posted : 26 November 2025 11:52:30(UTC)
jonas_sthlm
Does anyone know if it would be harmful for an SDS motor if you connect it to some type of power backup easy capacitor on +Ub/GND?
I install them on others without any problems so...
This installation has a buffer capacitor installed.
BLDC Motor Controller für bürstenlose Motoren (C-Sinus, SDS und Maxon EC)
Edited by user 28 November 2025 23:54:42(UTC)  | Reason: Not specified
Offline jonas_sthlm
#2 Posted : 27 November 2025 17:02:31(UTC)
jonas_sthlm
I gave it a try with 1000uF 25V capacitor, but it doesn’t seem like the LED stays on for longer Mellow
The sound module was connected here for39894Br189 with LokPilot V3.0 M4 decoder.
I tried with a 2200uF 25V and connected an LED directly on capacitor, and it lights up when the power is cut but not the locomotive.
So, the conclusion is that the capacitor doesn’t function with the standard SDS configuration when the GND (-) is connected directly to the engine Huh
It turned into a slightly simpler solution by using a direct cable LOL
Edited by user 28 November 2025 08:38:59(UTC)  | Reason: Not specified
Online kiwiAlan
#3 Posted : 28 November 2025 14:03:08(UTC)
If you are connecting it directly to the chassis of the loco, no that will not work.
Offline jonas_sthlm
#4 Posted : 28 November 2025 14:49:12(UTC)
jonas_sthlm
I don't follow you, doesn't ground with chassi...
Follow the connection line as it goes into the connection for the SDS engine.
This link has an interesting article, so fischer-modell.de can maybe be the solution...
Offline jonas_sthlm
#5 Posted : 28 November 2025 23:54:07(UTC)
jonas_sthlm
It did work with T44 ThumpUp
This page was generated in 0.324 seconds.
