Offline Boris Orloff
#1 Posted : 23 September 2025 02:00:44(UTC)
Boris Orloff
How many bulbs can I power with a Marklin transformer. I read somewhere it is 30. If that is true I would need about 10 transformers for my layout.
Offline RudiC
#2 Posted : 23 September 2025 11:00:06(UTC)
RudiC
There are various bulbs and various transformers. Usual bulbs consume 30 mA to 90 mA, so between 33 to 11 bulbs per A. Märklin Transformers supply between 600 mA and roughly 2 A, except for the big ones with up to 60 W or 100 W.
So you should specify what bulbs and what transformers we are talking about.
If you use LED articles, you can have roughly five to ten times the number of devices per transformator.
Edited by user 23 September 2025 15:24:08(UTC)  | Reason: Not specified
Rüdiger (Rudi)
#3 Posted : 23 September 2025 11:40:41(UTC)
I use a Faller transformer and I have at least 100 buildings and stations with LEDs and have no problems. Most bulbs are Faller and some Viessmann.
#4 Posted : 23 September 2025 14:29:45(UTC)
I use two additional transformers for lighting and accessory drives. Depends on your layout size, number of lit structures, etc.
#5 Posted : 23 September 2025 21:08:37(UTC)
Boris Orloff
I use a32 va Marklin transformer but with mostly incandescent bulbs. I will use leds in the future and trash the incandescents. I have over 200 structures on my layout.
thanks 1 user liked this useful post by Boris Orloff
Guest (4)
replace light bulbs with LED (General MRR)
by jonas_sthlm 21/03/2025 23:02:33(UTC)
incandescent bulbs in digital conversion (Digital)
by einotuominen 18/03/2025 18:14:34(UTC)
Replacement Bulbs for 5129 Stopper and 3601 MWR Turnout (H0-scale)
by Saulo35 18/11/2024 01:50:49(UTC)
Light Bulbs for Analog Engines (H0-scale)
by FastEddie 08/08/2024 14:31:59(UTC)
Colouring bulbs (H0-scale)
by Michael4 10/01/2023 12:38:05(UTC)
Marklin 600000 bulbs in the UK (General MRR)
by Michael4 17/08/2022 17:02:39(UTC)
Vintage signals, digital power and led bulbs (Model railroad wiring)
by BenP 08/05/2022 00:14:22(UTC)
Faller 670 lamp bulbs (General MRR)
by mountainroads 05/04/2022 23:15:13(UTC)
Marklin M Track 5117 Points / Led Bulbs (H0-scale)
by fossie 28/11/2021 10:53:09(UTC)
LED Replacement for Marklin 610040 Bulbs (H0-scale)
by frickwg 07/01/2021 20:31:43(UTC)
60010 bulbs ?? (H0-scale)
by dominator 03/07/2020 09:02:24(UTC)
Replacement Light Bulbs (H0-scale)
by Don Mebius 20/10/2018 22:51:19(UTC)
Where to buy replacement incandescent light bulbs and micro-leds (Model railroad wiring)
by guitartoys 05/11/2017 17:54:00(UTC)
LEDs to Replace Incandescent Bulbs (H0-scale)
by dickinsonj 04/04/2017 19:07:11(UTC)
Problem with led bulbs in passenger coach (H0-scale)
by Br502362 07/01/2016 16:37:15(UTC)
replacement light bulbs (H0-scale)
by thomasparks 18/02/2015 22:55:31(UTC)
Replacement LED Bulbs In Bulk? (General MRR)
by Roman 08/03/2013 19:51:36(UTC)
Converting old Märklin locos with single bulbs to potential-free lighting (Model kits & layout details, kitbashing and such)
by Frankenbahner 09/06/2012 14:29:13(UTC)
Which bulbs are best for vintage accessories ? (Collector's Corner general)
by 20-VOLT-AC 11/05/2012 17:55:10(UTC)
Which 5 MM bulbs to use for accessories ? (Collector's Corner general)
by 20-VOLT-AC 06/04/2012 22:05:59(UTC)
How many bulbs can i run off a 280A Transformer ? (Collector's Corner general)
by 20-VOLT-AC 18/03/2012 16:52:12(UTC)
Light bulbs for 3016, 3058 (H0-scale)
by Harvey 26/02/2012 00:54:26(UTC)
Discontinued Brawa Lights - 5450/5460 - Bulbs? (General MRR)
by BrandonVA 12/01/2012 18:08:52(UTC)
Lightbulbs for old locomotives (H0-scale)
by Answ 23/01/2011 05:25:08(UTC)
Lightbulbs (H0-scale)
by Answ 17/01/2011 16:09:35(UTC)
marklin analog/delta light bulbs confusion (Digital)
by Hendro 29/12/2007 09:56:03(UTC)
Question about replacement lightbulbs ... (H0-scale)
by Night Train 29/04/2005 23:38:38(UTC)
Light bulbs (Digital)
by rugauger 09/03/2004 00:13:15(UTC)
LEDs as replacement for bulbs in digital engines (Digital)
by Peter Neumann 01/12/2003 05:48:57(UTC)
3042 to Digital - Bulbs (Digital)
by chris.busby 23/06/2002 22:23:04(UTC)
This page was generated in 0.261 seconds.
