2 Pages<12
#51 Posted : 07 December 2019 22:03:41(UTC)
The recent CS3 v2.0.0(0) update has generally played catchup to the CS2 4.2.9.
However, the "shell" of Class 66 as earlier noticed earlier in the CS2, is now available as a full cab in the CS3 as ID=46
And, while not referenced in the ChangeLog, This "Class 66" is also available for non mFX+ decoders in the psedo WOO mode
#52 Posted : 07 May 2020 12:15:41(UTC)
3 new Cabs with CS3 update 2.1.0
All three are available for non-mFX locos
ICE-4
SBB RAm TEE
BR 648 Lint
#53 Posted : 17 November 2020 07:56:10(UTC)
With CS3 2.2.0 there is a nice improvement in the configuration screens.
Where "ID's" or "codes" used to be needed, a selector is now available with a text description of the Loco/Cab is seen
#54 Posted : 27 February 2021 04:10:30(UTC)
CS2 4.2.13 brings its list of CabModes up to date with the CS3 (see last 3 modes above)
#55 Posted : 04 March 2022 03:16:24(UTC)
Cab mode 58 = VT92.5
CabMode77 = (missing/skipped)
Cab Mode 81 = Reihe 1189
#56 Posted : 24 March 2022 06:08:53(UTC)
Cab mode 77 finally makes an appearance via the CS2 update (4.3.0(5)
but 85 is skipped
However Cab Mode 89 and the RABe 501 appear to be early may simply mean that no CS2 update is due for a while
Cab mode 77 = Re 6/8
Cab Mode85 = ET 85
Cab Mode 89 = RBAe 501
Edited by user 07 August 2023 13:07:56(UTC)  | Reason: Not specified
#57 Posted : 01 February 2023 08:54:50(UTC)
From a partial (images only) CS3 update Jan2023
Cab mode 93 = Reihe 1x00
UserPostedImage30130 NS 1100
Cab Mode 97 = SJ RC6
UserPostedImage39281 Rc 5
Cab Mode 10 = E 71.1
UserPostedImage39771 E 71.1
#58 Posted : 01 February 2023 13:49:53(UTC)
I'll guess! Top br 111, 120, 101, etc? Center br 216, 218, 212, 236? bottom E 191, EP 5,6 or ae 3/6?
#59 Posted : 07 August 2023 12:53:09(UTC)
Cab mode 62 = ES44AC (probably 38440/38441 : Type GE ES44AC diesel locomotive)
Cab mode 66 = DR V200 (probably 39200 : Class 120 diesel locomotive)
Edited by user 08 August 2023 02:01:08(UTC)  | Reason: Not specified
#60 Posted : 07 August 2023 15:37:43(UTC)
Cab mode 66 = DB V200
Why do both of those cab views have SBB CFF FFS across them? I didn't know that the Swiss operated Union Pacific or DB rails ... Confused
#61 Posted : 08 August 2023 01:58:12(UTC)
That text is just the name of the loco I happened to select when pulling up the various cabview options for capture
#62 Posted : 01 March 2024 08:18:41(UTC)
117 (old 105?) Ae 8/14 EP III
Edited by user 21 September 2025 05:11:55(UTC)  | Reason: Not specified
#63 Posted : 21 September 2025 05:31:03(UTC)
I am unclear what may have changed , or I have misinterpreted.
I had previously posted #105 as the Ae 8/14 EP III
On reviewing at the latest CS3 2.6 update ...
Currently #105 and #109 have been skipped/retired
Curiously #113 appears to be identical to #013
#117 now presents as the Ae 8/14 EPIII.
This may be an incomplete update as the Web representation of the Cabmode selector uses the text "fahrpult117" instead of the expected "Ae 8/14 EPIII" that is seen on the CS3 itself. Noting the mode code is treated as alphanumeric in sorting i.e. 117 is after 10 but before 13
The following may not strictly be new. The original(current?) mFX+ decoders appeared limited to 16 functions.
With the introduction of the Proxy "Operational Mode" in the CS3 for any other decoder, it is possible have a decoder with more than 16 functions to use Cabmode.
The Ae 8/14 EPIII is one theme that presents more than 16 buttons/switches
F16,F17,F18 can be seen referenced here...
Also of note is that the CS2 update 4.3.2(4) has #113 (the clone of #013 ) but not #117 (Ae 8/14 III)theme available
Edited by user 23 September 2025 04:13:52(UTC)  | Reason: Not specified
2 Pages<12
This page was generated in 0.631 seconds.
