Offline johnhendry
#1 Posted : 16 February 2025 22:24:12(UTC)
johnhendry
Motor suddenly started running very jumpy. Video attached. We’ve cleaned everything and it seems like an electronic issue. IMG_2135.mov (11,750kb) downloaded 135 time(s).
Online marklinist5999
#2 Posted : 17 February 2025 00:02:43(UTC)
The motor is in the tender? Roco does that, not Marklin. Is it item #37835, or 37844?
Offline johnhendry
#3 Posted : 17 February 2025 01:29:42(UTC)
johnhendry
No, the motor is at the back of the loco.
thanks 2 users liked this useful post by johnhendry
Offline TrainIride
#4 Posted : 17 February 2025 08:27:41(UTC)
TrainIride
Hi John,
maybe you can check the pressure on the brushes, sometimes it goes like this.
Best Regards
Joël
#5 Posted : 17 February 2025 11:42:36(UTC)
Hi John
What to check?
- first, check if it is not a current pick-up issue: place the loco upside down and power it using 2 wires one on the slider and one on the chassis. If the motor turns smoothly, then you have a pick-up issue EITHER the slider is bad OR the wheel bearings are dirty In this case a tiny drop of oil on the bearings, let the loco run for a while and wipe the excess of oil.
- remove the brushes and check them for wear and cleanliness, clean the brush guide with a piece of cleenex and tweezers (we call them Bruxelles over here)
- without brushes the motor should turn freely through a gentle rotation of the wheels. If not, unscrew the brush holder and position it so that the rotation is free before tightening (not too much as it is plastic). This is because during the large time span of production of this model, lack of precision could cause the rotor to collide with the inductor.
- for a big repair check the motor impedence in various rotor position (it should be around 40 Ω ish) but if the value is 10 Ω ish, then the rotor is burned and needs changing before it burns the decoder as a result (personal experience). Another symptom of this burned winding is the motor does not always starts (needs help in some positions)
- another possible test: disconnect the motor and power it with DC voltage (5 VDC to 9 VDC) and see if the rotation is smooth with a small current (under 100 mA)
#6 Posted : 17 February 2025 11:49:25(UTC)
A tender refers to the fuel, either coal or oil and water storage car towed behind the locomotive.
Offline dickinsonj
#7 Posted : 18 February 2025 00:38:25(UTC)
It is common to refer to a loco as a tender in opposition to what we call a tank loco, which was much more common in Europe.
I assume that is the reason for calling his loco a BR50 Tender.
#8 Posted : 18 February 2025 12:32:28(UTC)
Tank locos were not common in the USA. At first I thought he was meaning the condenser fans or snow plow in the tender stopped running. He didn't say which class is was. I don't download files on my tablet I have to look at off the site.
Offline johnhendry
#9 Posted : 09 March 2025 00:09:06(UTC)
johnhendry
Sorry guys, yes, I said tender just because I wanted to describe the model a bit more (it’s not a tank engine). This model has the pickup and decoder in the coal tender and the motor obviously in the loco.
I have checked and cleaned the motor and brushes and everything runs smoothly when it’s apart and a little more friction but still smooth when the brushes back in and the motor is back together. There was a little binding happening at one point (I think maybe the main rods / connecting rods were misaligned). That is fixed now but I’m concerned that this could have burned the motor (I don’t see any evidence of that).
I’m going to check the impedance. Anything else I should check?
Offline johnhendry
#10 Posted : 09 March 2025 00:28:17(UTC)
johnhendry
Resistance between the pickup shoe and ground (wheels) is about 8kohm. Does that sound right or is that not a good way to measure?
Offline johnhendry
#11 Posted : 08 August 2025 21:36:50(UTC)
johnhendry
IMG_28311.mov (12,399kb) downloaded 30 time(s).
Guys, an update on our BR50. It will run all the way around the track like this (if you give the drive gear a little start). In both directions. Everything else works perfectly - the sounds match the speed, etc. If you don't give the gear a little push it will not move at all. Everything LOOKS good inside... Any suggestions as so what else we could look at?
Offline Bill L
#12 Posted : 09 August 2025 04:29:10(UTC)
Bill L
I have had Marklin locos that I have run a lot do that, needing a push to run again.
In my case, cleaned the armature gaps, there are 5 of them in a digital motor. Use a needle to scrape out the carbon that has accumulated in the gaps that are between the commutator plates. You can visually see the carbon dust between the commutators in the gaps. Use a sheet of paper to collect the carbon dust. I was surprised there can be a lot. The black dust can be real messy on you fingers and your work table. Hope this is your problem.
thanks 2 users liked this useful post by Bill L
Offline rhfil
#13 Posted : 09 August 2025 13:42:29(UTC)
rhfil
Hopefully the above is the problem and it is more likely if it fails to start every time it stops. Something is causing a gap in the electrical circuit which can be overridden by motion. Also check the slider. Make sure it is clean and you might bend it away from the body a bit to give it some arch.
Offline johnhendry
#14 Posted : 10 August 2025 03:54:37(UTC)
johnhendry
Thank you both for the suggestions. We opened it all up and cleaned it out very thoroughly. It’s still doing the same thing. Are you able to see on the video how jumpy the motor is when it’s running? It’s not just that it won’t start once it stops, it’s that it’s so jumpy when it does run and it’s totally consistent. Any other suggestions?
#15 Posted : 10 August 2025 12:08:24(UTC)
I dont have this model but is it possible to try another decoder even from another loco. No idea if that is possible but would rule out the decoder and just leave the motor but as you have cleaned that and checked the slider and its connectgions then you may need a new motor. Have you done a decoder reset.
Offline rhfil
#16 Posted : 10 August 2025 12:34:22(UTC)
rhfil
I have an engine that runs like that and I was told that the quartering was off.
#17 Posted : 10 August 2025 12:48:46(UTC)
What is the running number on cabside?
Offline dickinsonj
#18 Posted : 10 August 2025 13:03:13(UTC)
Yes! If you have not yet checked that the quartering is correct definitely do that.
Offline johnhendry
#19 Posted : 13 August 2025 20:38:18(UTC)
johnhendry
We have checked the quartering and it’s good. Running number on the side is 502362.
Offline johnhendry
#20 Posted : 22 September 2025 23:31:51(UTC)
johnhendry
Okay, I finally decided to just swap out the motor with another one with the same motor. The motor is clearly faulty. Is it the 60943 motor that we're looking for?
thanks 1 user liked this useful post by johnhendry
Offline bph
#21 Posted : 28 September 2025 15:10:08(UTC)
It's probably a 60941 you will need. If you don't need all the parts, you can look into the E165841 or separate parts.
This page was generated in 1.573 seconds.
