Offline cintrans
#1 Posted : 12 July 2025 18:03:29(UTC)
cintrans
Aruba
Hi all
I have some NOS 6080 decoders laying around and was thinking of building up a tandem (double drive) F7 using spare parts.
I would use the original 3 pole motor with either one or 2 6080 decoders but only one common slider.
Anyone ever done that with decent results?
Jean-Pierre
#2 Posted : 12 July 2025 19:33:41(UTC)
Hi Jean-Pierre
The 6080 Märklin decoders are of the very first generation dealing with Motorola (Not MM2) so the direction bit is not decoded.
Long story short: you cannot use independent 6080 decoders even with the same slider to drive 2 motors as you run the risk they could run in opposite directions.
Märklin never used 6080 decoders to drive two-motor units (M. used stronger drivers instead).
I think some Märklin fans did try to drive 2 motors with one 6080 and it would probably work as long as you avoid peak currents caused by stalled motors
Note: driving a twin motor unit with a 60906 all-current decoder, capable of 1.6 A motor current would do it probably better
#3 Posted : 12 July 2025 21:13:45(UTC)
The decoder used in the original 3649 ENMD F7 Demonstrator loco is certainly based on the 6080 decoder, but I haven't checked what they have done to drive the two motors compared to a standard 6080. The decoder uses the original LME07 chip which predates the 717.xx series chips used in the 6090 and later decoders.
#4 Posted : 13 July 2025 13:04:46(UTC)
Here is an example of Märklin's way of driving two A/C motors in parallel
Here on a 2-motors A-B-A GM EMD F7 unit where you may see the separate stronger drivers for the motors
6080 decoders (Digital)
by cintrans 25/01/2024 17:26:11(UTC)
digital loco with 6080 decoder in analog mode (H0-scale)
by 3104V200 25/08/2023 08:04:09(UTC)
peculiar behavior from an old 6080 decoder (Digital)
by DaleSchultz 20/05/2020 20:50:29(UTC)
6080 decoder not responding? (H0-scale)
by Sir Timbo 05/03/2019 06:43:07(UTC)
Marklin 6080 decoder and Ecos controller (Digital)
by johnmarklin 21/06/2018 21:13:28(UTC)
CS2 - 6080 Decoder - 3670 Litt D 109 (Digital)
by gdk2003 04/01/2017 19:32:30(UTC)
Is there any benefits using 5-pole armature instead of 3-pole with Delta or 6080 decoders? (Digital)
by Janne75 01/05/2013 16:19:15(UTC)
I converted an 3106 BR 78 355 steam tank loco to digital with 6080 decoder today (Digital)
by Janne75 08/02/2013 01:24:29(UTC)
Testing Marklin 6080 Decoder (Digital)
by Arbeithuber 20/12/2010 01:33:19(UTC)
by nevw 21/06/2008 09:03:04(UTC)
This page was generated in 0.253 seconds.
