Offline Adrian666
#1 Posted : 06 January 2025 09:02:10(UTC)
Adrian666
Romania
Hello friends,
Can You please identify the number model of thus loco tee v11.5
Also want to know If îs digital or not
Edited by moderator 08 January 2025 03:03:16(UTC)  | Reason: Realign photos
#2 Posted : 06 January 2025 10:20:50(UTC)
You have been a member since:: 04/02/2011(UTC)
Hello Andrian
This set of 3 passenger cars goes with the VT11.5 of Märklin
The first production run in 2003 was the 43115 and a later production run in 2017 was the 43114
The set does not include any decoder nor slider.
The difference between the 2 extension sets was yellow LEDs in the first run and white in the second
All sets going with this extension were digital (MM2 for the first one, MM2, DCC and MFX for the seoncd but the wiring and coupling are the same
PS: a presentation would be great if you intend to be part of this great forum.
Greetings from Paris
Offline Adrian666
#3 Posted : 06 January 2025 11:04:15(UTC)
Adrian666
Romania
Hello Andrian
Hi Jean,
Thanks for replying
I Have the full set both without box and can't establish the model, see new pictures, as You can see there are 2 locomotives and 2 pasager
Screenshot_20250106-120139.png (1,119kb) downloaded 38 time(s). Screenshot_20250106-120154.png (1,250kb) downloaded 34 time(s). Screenshot_20250106-120146.png (1,294kb) downloaded 27 time(s). Screenshot_20250106-120200.png (1,240kb) downloaded 30 time(s).
#4 Posted : 06 January 2025 11:16:31(UTC)
Did you bough train set as second hand?
Offline Adrian666
#5 Posted : 06 January 2025 11:22:59(UTC)
Adrian666
Romania
yes, I tried to find more about it based on the pictures, but was unlucky so far
currently not in my possesion to provide better pictures
#6 Posted : 06 January 2025 11:32:34(UTC)
You did wrote without the box so i thought you did missed manual of the train set too.
It should have been follow when you did bought the train set.
#7 Posted : 06 January 2025 12:08:30(UTC)
Hello Adrian
Your pictures do not allow me to tell which model it is
Here are a few indications
- the first model 37605 (2002) is only MM2-capable The users manual is here
https://static.maerklin....4cf1e2e8f11551856541.pdf
The factory address is 11 (MM2)
- the other model 37604 (2016) has white lights and MFX DCC. If tou have a multi protocol unit (MS2 or CS3) it will self register in MFX. Its users manual is here https://static.maerklin....5437fed7431464365599.pdf
The factory address is 11 (MM2) and 3 (DCC)
Offline Adrian666
#8 Posted : 06 January 2025 12:43:33(UTC)
Adrian666
Romania
Hello Adrian
Hi Jean, there are more models out there such as 37607 , the seller is not a model train pasionate, more or less îs clueless.
Îs there a way I can find out more about the train ? Should t be a code on the train to Say more ?
thanks 1 user liked this useful post by Adrian666
#9 Posted : 06 January 2025 13:18:16(UTC)
Yes there are more models by Märklin
Go to the marklin(dot)de and search for VT11.5
There is one with a gas turbine and another in gold
Offline torhb
#10 Posted : 07 January 2025 01:26:58(UTC)
torhb
This locomotive is produced in 2016 so the model number should be easy to find in the Märklin database.
The small label with green print starts with an "H", which indicates High Efficiency Propulsion, eg Digital. Next two digits indicates production year (16 = 2016). The rest is a production sequence number.
Tor Harald Bøhler
Tor Harald Bøhler
Oppegård, Norway
thanks 3 users liked this useful post by torhb
#11 Posted : 07 January 2025 03:25:42(UTC)
It would seem to me that with the destination sign Hamburg "TEE Helvetia" that this is from the 37604 or 43114 sets.
I think that the 37605 had a different destination sign as the train did not have Helvetia printed on the side.
Offline Adrian666
#12 Posted : 07 January 2025 05:03:11(UTC)
Adrian666
Romania
Hi Mike , thank You for your comment
https://wiki.3rail.nl/in...title=M%C3%A4rklin_37604
The issue with 37604 is that i fiind is made of metal , and in the pictures i think it's plastic, the housing îs plastic
Initialy, i tought was 37607 but i see now its a diffrent router written on the train.
Offline Iamnotthecrazyone
#13 Posted : 14 January 2025 06:48:20(UTC)
Iamnotthecrazyone
So far as I know they are all metal and yours should be too. I also think it is the 37604, I did not do an exhaustive search but the 604 seems to match the destination board while a couple of other models were different.
thanks 1 user liked this useful post by Iamnotthecrazyone
This page was generated in 0.419 seconds.
