Offline Lostcajun
#1 Posted : 24 December 2024 15:47:11(UTC)
Lostcajun
Hello all -
I created this account just to ask this question. I am helping my family with assembling a small track for Christmas. Our Marklin 6177 seems to have lost the ability to control speed of the locomotive. Changes in knob position do not affect the locomotive's speed - it only operates at a near the highest speed. Is this an issue that can be troubleshot or resolved? Thank you for the help and let me know if more information is needed.
thanks 1 user liked this useful post by Lostcajun
#2 Posted : 24 December 2024 15:57:36(UTC)
Theere is at least one YouiTube video on restoring one. It may only need a cleaning of the rheostat.
#3 Posted : 24 December 2024 17:03:15(UTC)
Hi LostCajun
Welcome to this great forum
Here is a cajun from France BigGrin . I am jockin but I live in Paris but go often to Normandy where most Cajun came from I think
Regarding these transformers
- you may open them by straingtening the protruding pieces of steel to unlock the upper case in place
- caution by opening, there still will be a wire in place (between the cursor attached to the red button and the "B" output
- then you have to inspect the power cord for any damage (often with early models) and possible replacement
- then it is about cleaning the cursor's path on the winding and having lithium grease back on the path
- in your case, the metal finger needs probably to be bent A LITTLE so that the contact is better
- close the casing and bent the protruding metal to lock it in place
WARNING: do not try to open the assembly around the red button and its bass finger. It would be a lost cause, a lost spring
Here is mine once opened
#4 Posted : 24 December 2024 17:45:16(UTC)
Make sure that the wires to the track are connected to the brown and red outputs and not to the yellow one
If this does not resolve the issue, proceed as described by Jean
Offline Lostcajun
#5 Posted : 24 December 2024 19:34:46(UTC)
Lostcajun
Hi LostCajun
Thank you so much, Jean. I have the device open. How would you suggest I clean the cursor path?
Offline 1borna
#6 Posted : 27 December 2024 20:21:01(UTC)
1borna
Croatia
You say it only works at maximum speed - that would mean you have incorrectly connected the rail leads, yellow and brown, which gives a constant 16 volts (and more). Another, but only theoretical, possibility would be that the wire going to the current collector inside the transformer has come loose and fallen to the maximum speed position (I have never seen that in my 60 years of repairs).
thanks 2 users liked this useful post by 1borna
This page was generated in 0.458 seconds.
