Offline Drongo
#1 Posted : 14 December 2024 22:37:28(UTC)
Drongo
I have a M84 setup with addresses 125 to 128 using an ECoS. On addresses 127 and 128 I have 12v DC LED lights connected, both to the same power supply (a 12v DC 5amp). Address 127 only works with MM protocol and address 128 only with DCC protocol. Can someone explain why the different protocols as basically the lights are the same.
Greg
Offline Drongo
#2 Posted : 23 December 2024 10:21:39(UTC)
Drongo
Can anyone help explain this ?
Greg
#3 Posted : 23 December 2024 16:47:11(UTC)
I don’t understand how you did get two different protocols on the same switch decoder? You can only use one protocol by choice MM or DCC.
Offline bph
#4 Posted : 23 December 2024 17:12:02(UTC)
Greg
Have you tried a decoder reset ? (cv 8), and initialised again using DCC ? (Dip switch 10 on)
I use my m83/84 decoders on a cs3 in Mfx/mm mode, so I don't have experience with ECoS.
Offline Drongo
#5 Posted : 28 December 2024 10:36:09(UTC)
Drongo
Greg
Thanks for the advice, I checked that I had dip switch 10 on and I reset the decoder and now it works well.
Happy New Year. BigGrin BigGrin
This page was generated in 0.236 seconds.
