Offline hdunsmore
#1 Posted : 08 December 2024 05:08:09(UTC)
hdunsmore
I have taken possession of a Marklin 6021 Control Unit and a Control 80f 'box'.
What do I need to make these power up in N America?
thanks 2 users liked this useful post by hdunsmore
Offline tonyfh
#2 Posted : 08 December 2024 09:21:58(UTC)
tonyfh
Hello, welcome to the forum.
To power up your 6021 you need a transformer that gives max. 52 VA at 16 VAC at the output, not necessary one of the transformers from the picture, any transformer with 16 VAC output will do the trick.
then simply connect the control 80f to the RIGHT of the control unit 6021 via the built in connectors.
in case you have locomotives with the older decoders with dipswitches you can find the adress in the table
succes, Tony
thanks 3 users liked this useful post by tonyfh
#3 Posted : 08 December 2024 20:09:59(UTC)
That's wrong.
According to Märklin their 60 VA transformers are also suitable for the 6021.
#4 Posted : 08 December 2024 22:08:00(UTC)
https://www.reynaulds.co...ts/Consignment/6001.aspx
You can connect it to the yellow and brown outputs of any Maerklin transformer. The 32VA model (6646) will not power as many locomotives as the stronger 52VA dedicated model (6001 USA)
Offline hdunsmore
#5 Posted : 09 December 2024 02:35:27(UTC)
hdunsmore
https://www.reynaulds.com/products/Consignment/6001.aspx
You can connect it to the yellow and brown outputs of any Marklin transformer. The 32VA model (6646) will not power as many locomotives as the stronger 52VA dedicated model (6001 USA)
Hello to the above responders. I'm sorry but I should have mentioned that I am in Canada. The convertors I've seen on eBay, etc, all seem to be "110V 32Va" i.e N.American voltage.
Is this unit worth putting money into - it looks versatile but I've never use Marklin products before.
Any advise would be welcome. Cheers,
Henry D
thanks 1 user liked this useful post by hdunsmore
#6 Posted : 09 December 2024 14:43:02(UTC)
Iv'e had my 6021 since new in 1997. No issues with it. It has an external heat sink too. Far less complex than a CS3, if you don't mind the way fewer functions and capabilities.
My 40va transformer failed, but upon opening it up, it was only a positive terminal wire that came unsoldered.
Offline hdunsmore
#7 Posted : 09 December 2024 16:30:04(UTC)
hdunsmore
Thanks for the comment. I guess I will buy the 40A transformer.
Does the 6021 run DCC trains as well as DC?
#8 Posted : 09 December 2024 17:07:39(UTC)
The 6021 is MM "Marklin Motorola" and expanded FX format protocol only. However, if the Loco. is newer with a both DCC/MFX decoder, it might?? Only 80 addresses can be set in the 6021. 01-80.
#9 Posted : 09 December 2024 17:23:37(UTC)
Not sure what type or size of layout you are aiming for but I would go for a Marklin start set with controls or if a large layout then a CS3 is good. Big difference in price but in my view it is worth spending on control with more locos etc coming later.
#10 Posted : 09 December 2024 17:34:47(UTC)
Yes, and , because the 6021 can only access headlights plus 4 more functions. New models with sound offer many more functions. I've read that more functions can be activated with a 6021, but that requirtes toggling the speed knob with several reversing moves within a certain time period. Same for changing the address with it on earlier Piko and ESU Loksound decoders.
Offline mvd71
#11 Posted : 09 December 2024 19:29:59(UTC)
The 6021 and 6036 combi is a great digital control setup. They are reliable, robust, and easy to use.
Since you already have them, I would suggest you definitely get a transformer and make use of them. The 6021 puts out a Märklin Motorola digital signal, it will not drive DCC equiped locos unless they happen to have a multiprotocol decoder installed.
The restriction regarding extended functions can be gotten around by setting secondary addresses in the loco decoders (on newer decoders).
I think you will find you have a good starting point for Märklin digital, and you can always upgrade later if you wish. In the meantime what you have will be excellent value for money!
Cheers…..
#12 Posted : 09 December 2024 20:40:27(UTC)
Nope.
With the F key you set the address for F1 through F4 and with the L key you set the address for the speed knob.
Some decoders support 4 MM addresses for up to 17 functions per loco that can easily be accessed with the F key while the speed knob always controls loco speed.
#13 Posted : 09 December 2024 23:28:08(UTC)
What about the instructions with my Piko basic digital from the 90s that tells you for the Marklin 6021to hold the knob in reverse until the headlights flash, then enter the address and reverse the knob again twice or something etc.?
#14 Posted : 10 December 2024 07:49:08(UTC)
That's the procedure for Uhlenschrott decoders to change the address of the decoder. This has to be done once per loco.
This does not occur during normal loco operation.
AFAIK no Märklin loco came with Uhlenschrott decoders.
And I think the last Piko or Fleischmann loco with such an decoder was produced far more than 10 years ago.
Offline 60904
#15 Posted : 10 December 2024 13:37:01(UTC)
60904
Märklin never came with Uhenbrock decoders. Early mfx came from ESU.
Martin
thanks 1 user liked this useful post by 60904
#16 Posted : 10 December 2024 14:30:22(UTC)
I think my Piko has Uhlenbrock because the instructions also say the procedure is for the Intellibox.
#17 Posted : 10 December 2024 23:13:58(UTC)
My Marklin 37537 br 120 is not MFX but has a decoder without dip switches. So ESU? Only horn sound and a small auxiliary sound module. The instructions for the 6021 are the same as my Piko.
#18 Posted : 10 December 2024 23:49:41(UTC)
That's an ESU decoder.
With ESU decoders, you simply hold the speed knob in the reversing position while you press the Go button, then you wait for flashing lights.
Märklin adopted the same procedure for their own fx decoders and mfx decoders they made later without ESU.
With some Uhlenschrott decoders, procedure is much more complicated and you have to engage direction change quickly for 8 seconds.
Offline hdunsmore
#19 Posted : 11 December 2024 05:50:13(UTC)
hdunsmore
Thanks David:
I am many light years from having a large layout. Just trying to get familiar with Marklin Control unit before making major decisions. I am still trying to find out what the 6021 is capable of. Perhaps even the 6021 is beyond my simple needs and limited technical know-how.
Henry
#20 Posted : 11 December 2024 06:04:23(UTC)
Here are the instructions for the 6021: https://static.maerklin....1189fe42a71434542461.pdf
English version is not available from Maerklin
The 6021 can operate with the original and revised versions of the Maerklin Motorola system. The settings can be changed via the dip switches on the rear of the unit.
The 6036 Control 80f can be used in cooperation with the 6021 to control additional locomotives. I am not certain that it can be used with the latest version of the Maerklin Motorola decoders, but it is possible as the unit was in the product line until 2006..
You can ask questions to Rick or Curtis at digital(at)marklin.com. They are the digital experts for Canada/USA at Marklin USA.
#21 Posted : 11 December 2024 10:25:43(UTC)
MFX locos will run with a 6021. Additionally the 6021 can be used with a CS 3 with a 6021 connect box and cable. Sounds redundant perhaps, but large layout's may benefit from it.
#22 Posted : 11 December 2024 12:34:50(UTC)
Thanks David:
Henry
Refer to the 0303 manual which can be found in this post as well as manuals for the 6021, 6036, 6050 etc in the previous post on that link.
#23 Posted : 11 December 2024 14:49:32(UTC)
My Roco br 218 with DCC Zimo souind decoder does work on my 6021. The Piko must have the Uhlenshrott because the reversing and light flashings must be done within seconds for them to change the address.
Offline ocram63_uk
#24 Posted : 11 December 2024 16:26:48(UTC)
ocram63_uk
I would simply aim at a new Mobile Station 2 if I wanted to understand what Marklin digital trains are about. It isn't even intuitive, at first.
Starting today with a 6021, IMO, is the wrong way to go.
#25 Posted : 11 December 2024 16:47:44(UTC)
I upgraded to the MS2 29000 set (under $200 U.SD.) with track from the 6021. then a CS3+. I use my 6021 primarily on my workbench for testing. I just put it under the Christmas tree with an M track oval fro my digital non mfx 3511 klasse C and Royal Wurtemberg car set for my dickens village and Victoria station.
#26 Posted : 11 December 2024 21:59:44(UTC)
Marklin 6021 Manual in PDF.
>6021 English<
Thanks to Marklinisterne.dk for the PDF.
#27 Posted : 12 December 2024 12:24:40(UTC)
Thanks David:
Henry
I understand your view but I do think a Mobile Station 2 would be better than the 6021 which is obsolete and the Mobile Station will do more and probably easier to operate.
You will also get the Marklin guarantee. The start set is ideal as you have everything which is easy to set up and operate. You can also come back here for advice as many on the forum use the Mobile Station. Much of the fun is playing and learning as you go.
#28 Posted : 12 December 2024 14:43:34(UTC)
The 6021 is old and long out of warranty, the MS2 has more digital capabilities.
But the 6021 has physical keys you use to change settings and operate the loco. Trained 6021 users can achieve things very quickly - the same operation takes much longer with the MS2 where you have to dive through on-screen menus to reach the setting you need.
The MS2 is the unit I take with me to club meetings, but the 6021 is at home, connected to a test track and allowing quick tests or quick changes of basic settings.
Both devices have their merits.
And everybody must find the device that suits best.
764xx signals with 6021 control unit and 6040 keyboard (Digital)
by PeterCambridge 11/10/2018 17:56:25(UTC)
MTH and Marklin 6021 Control Unit. (H0-scale)
by Hoover007 22/11/2015 02:57:59(UTC)
Programing the MTH Proto Sounds 3E+ 3rd rail loco to the Marklin 6021 control unit, (H0-scale)
by Gary Gibler 17/11/2015 16:36:03(UTC)
6021 Control Unit with Uhlenbrock UHL64820 Loconet & IRIS infrared remote control to use k83 decoder (Digital)
by Hoover007 20/03/2014 08:00:50(UTC)
Converting to digital no output 6021 Control unit (Digital)
by upnatum 05/11/2010 23:49:02(UTC)
Digital control with 6021 control unit (Digital)
by Tex 22/10/2008 07:06:48(UTC)
ganging 2* 6021 control units (Digital)
by teecee 28/10/2005 03:39:55(UTC)
6021 Control Unit (H0-scale)
by jimbrauer 27/03/2003 05:41:09(UTC)
This page was generated in 0.792 seconds.
