Offline Coen236
#1 Posted : 09 December 2024 21:03:51(UTC)
Coen236
Hi guys! I am totaly new here a week ago I started to buy a marklin train I choosed for analog because it was pretty cheap and it is easy to begin whit.
However, the problem is, when I want to change the direction of the loco, by pushing the knob under the 0. While I am doing that, it is going on full speed. When I am releasing it it stands still, so I don't think it is the spring. Well maybe y'all don't see this as a "big"problem but it is pretty anyoing when I want to couple some wagons but while I am pulsing to go forward it's throwing all the wagons off the track or pushing the buffer all the way trough my room. I'll hope for some anwers so I can continue this hobby :)
Greetings,
Coen
(sorry for bad english I am a very dutch person)
Offline HO Collector
#2 Posted : 09 December 2024 21:10:17(UTC)
HO Collector
Replace the spring with ne, the current might be too weak.
Online RudiC
#3 Posted : 09 December 2024 21:32:01(UTC)
RudiC
Sounds like too tight the spring to me. Is it the original reverser spring (there's loads of other, similar ones)? With a Voltmeter you can check the reverse pulse, it should be 24V or slightly above. As a first measure, unhinge the spring - take care it doesn't snap around the room never to be found again - extend it to a certain degree so it gets looser, put it back and try reversing. Repeat until happy. Make sure the loco doesn't reverse at highest speed (knob fully right extreme).
Rüdiger (Rudi)
thanks 2 users liked this useful post by RudiC
Offline Coen236
#4 Posted : 10 December 2024 07:51:31(UTC)
Coen236
well, It is more that only when I am pulsing it gos at full speed. If I am not pulsing nothing happens. So when I do the pulshe, It gos (ONLY WHEN I AM PUSLING) full speed. Now, just when I couple some wagons, it pushes the wagons (whit the buffer too) off the tarck. I looked inside the train, and it looks like it is getting a 24 volt pulshe, but that 24 volt is also going to the motor. My friends says this is very logic, he says that only digital could go in other direction whitout going forward. I don't think so, thanks for the help by the way
#5 Posted : 10 December 2024 08:47:29(UTC)
If the spring is not too strong, the reversing relay will disconnect the motor - and in the best case the loco will move just a tiny little bit.
But if the spring is too strong, the relay will not engage and the motor gets the full power all of the time.
Long story short: Adjust the spring tension, that's the only issue.
Offline TrainIride
#6 Posted : 10 December 2024 08:52:09(UTC)
TrainIride
You can try to open the locomotive ( which loco is it ? ),
and see what's happening to the reversing unit when the pulse occurs.
Maybe a wire is blocking the mechanism, or something else..
Best Regards
Joël
Offline Coen236
#7 Posted : 10 December 2024 11:25:06(UTC)
Coen236
DB br 216 thanks I will try it later now I have work to do ;)
Online RudiC
#8 Posted : 10 December 2024 14:39:41(UTC)
RudiC
So it doesn't move (slowly, steadily) if you turn the knob slightly to give it, say, 10V? That would be somewhat weird as the connection seems to work (if you pulse) ...
A picture or movie might help us help you.
Rüdiger (Rudi)
Offline ccranium
#9 Posted : 10 December 2024 19:31:40(UTC)
ccranium
If you happen to know the Marklin model number it would help also since there are a few versions of the 216 which have been made.
A picture of it with the body removed will help also so the forum can see what kind of reversing unit, motor and electrical system is inside. And a picture of your transformer would help as well, since those can also differ over time.
Welcome to the forum! There are lots of experienced Marklinists here!
Brian
#10 Posted : 10 December 2024 21:06:34(UTC)
Ik weet niet welk model je hebt gekocht.
Oudere locomotieven hadden een elektromechanisch relais dat werd geactiveerd door de inversiepuls.
Locomotieven sinds de jaren 1980 hebben voornamelijk elektronische relais die circuits gebruiken om dit te doen.
Heb je een nieuwe set gekocht of is dit een ouder model dat je hebt gekocht (gebruikte of oude voorraad)?
I don't know which model you bought
Older locomotives had an electro-mechanical relay that was activated by the reverse pulse
Locomotives since the 1980s mainly have electronics relays that replace the older reverse units.
Did you buy a new set or is it an older model (used or old stock)?
The old models often required a higher reverse pulse than the newer models.
If the transformer is outputting 23-24V to an older model, it could cause the exact problem that you describe, where the locomotive charges off like a raging bull.
My older blue metal transformers used to send a pulse as high as 26-28V.
On older models, if it was due to the relay not fully engaging, it was possible to replace the spring or adjust the tension to ensure that the relay fully engaged with the pulse.
On more recent models, it may not be a problem with the relay, but rather insufficient voltage to fully trip it.
Over the years, line voltages have changed. In North America, the voltages vary between 110 and 120.
In Europe, the voltages would vary between 220 and 230. Today, it is more regulated and stays at 220.
A transformer that would emit 26V reverse pulse in the 80s might only emit 24V today.
If you know which set or model you bought, it would help us to be able to identify the internal components and assess the best way to resolve your issue.
Hartelijke groeten
Offline Coen236
#11 Posted : 11 December 2024 08:18:26(UTC)
Coen236
Ik zal vandaag een foto sturen. Hij gaat alleen op volle snelheid tijdens de pulse. Als hij weer op 0 staat staat hij gewoon weer stil. Ik zeg dit maar want asl de spring te strak staat dan blijft hij doorreiden maar dan gebeurd bij mij niet.
I should post a photo today. It is only going on full speed during the pulse. If it is on 0 it stands still. I say this because if the spring is to tight the train will drive even is it on 0( I saw this on other forums)
Online RudiC
#12 Posted : 11 December 2024 08:46:39(UTC)
RudiC
... Als hij weer op 0 staat staat hij gewoon weer stil...
... If it is on 0 it stands still...
Good boy.
... asl de spring te strak staat dan blijft hij doorreiden
... if the spring is to tight the train will drive even is it on 0...
Certainly not. With 0V the motor will have no reason to run. Does it move with the trafo knob in mid position?
Must have been a wrong setup or a defective trafo / controller.
Rüdiger (Rudi)
#13 Posted : 11 December 2024 09:48:54(UTC)
HO Collector
Now I am a bit confused.
I can see the logic when you say that the spring might be too tight, hence the reverser doesn't move, make sense, but springs get softer over time, no? I have never seen a springs becoming stiffer, brittle, yes, but not stiffer.
Do I miss something?
Online RudiC
#14 Posted : 11 December 2024 10:07:36(UTC)
RudiC
Originally Posted by: HO Collector Go to Quoted Post
... springs get softer over time, no?
Not if operated within specs, i.e. not mechanically overextended, nor exposed to (very high, at least red glow) temperatures. And not rusty. Won't get stiffer, either, by the way.
I'd assume (too little info from OP) that the setup was bought second hand, and not all parts are what they should be: trafo too weak (reverse pulse considerably below 24V), or pre-owner messed with the loco reverser, or what have you...
Let us wait for complementary details from owner as requested.
Rüdiger (Rudi)
thanks 1 user liked this useful post by RudiC
#15 Posted : 12 December 2024 13:44:21(UTC)
Just adjust the spring tension on the reverser with a small flat screwdriver... It is really very simple!
#16 Posted : 12 December 2024 22:11:37(UTC)
Do we know for a fact that the poster is referring to 3074/3075 or could have have a more recent version that does not have the classic reverse mechanism? There were models with Electronic Reverse Mechanism, Delta and Digital 6080 all by the mid-1990s
The fact that the loco races off at high speed could be spring/voltage related on the old ones, but could be voltage related on the ERM version.
#17 Posted : 12 December 2024 22:27:27(UTC)
Als de transformator op nul staat, staat de trein stil. wanneer u op "Reverse" drukt, stuurt het een spanningspiek. Bij oudere modellen had de inversie-eenheid een trekveer. Bij gebruik zou die veer uitrekken en zwakker worden. Het resultaat was dat het relais niet volledig zou worden geactiveerd en de locomotief niet achteruit zou rijden. In het ergste geval reageert de locomotief op de spanningspiek en gaat er met hoge snelheid vandoor. Ik herinner me dat mijn 3013 (SEH800) tegen de schuur 7029 liep en tegen de eindbuffers botste.
Het vervangen van de veer op de inversie-unit was vaak de oplossing.
Bij nieuwere modellen (elektronisch) kan dit probleem worden veroorzaakt doordat de spanning onvoldoende is om de richtingsverandering te activeren. In dit geval moet u ervoor zorgen dat de transformator voldoende vermogen levert om het elektronische relais te activeren. Er is geen enkele afstelling meer die u aan de locomotief kunt doen.
Is uw transformator een metalen transformator uit de jaren 1950-1968? Is het een blauw plastic model van 197X tot 1990? Is het een witte plastic (na 1990)?
Wat is de nominale ingangsspanning?
Sommige modellen waren voor 240V. Anderen waren voor 220-230 of 220?
De oudere 240V-modellen geven bij gebruik met moderne 220V mogelijk niet voldoende spanning af om het inversierelais te starten.
Kunt u naast een foto van uw locomotief (uitwendige en inwendige componenten) ook een foto van uw transformator aanleveren?
https://www.maerklin-sam.../03075/03075_bda_001.pdf (SEE PAGE 2)
Groeten
#18 Posted : 13 December 2024 00:44:46(UTC)
That only works for the particular late model reverse unit that was pictured. There are several other styles of reverse unit that are adjustable like that.
Offline Coen236
#19 Posted : 14 December 2024 11:37:49(UTC)
Coen236
f WhatsApp Video 2024-12-14 at 11.31.17.mp4 (2,540kb) downloaded 37 time(s).
This is whats happening
it doesnt look very bad but it's very anyoing when coupling
Offline Jan Trein
#20 Posted : 14 December 2024 13:39:14(UTC)
Jan Trein
There are at least 4 train forums in the Dutch language (er zijn minstens 4 Nederlandstalige treinforums en een Vlaamse)
One of those has contact groups, and one of those is situated in Rotterdam, you can come along with your loco and ask help.
(Een van die forums heeft een stamtafel in Rotterdam (https://wiki.3rail.nl/index.php?title=Stichting_3rail_-_Stamtafel_Rotterdam), en je kunt erheen met je loc om een hulpvraag te stellen).
So, if people cannot help you because of a language gap, try in in your own neighbourhood, in your own language.
According to my knowlegde of analog Märklin h0, your question has been answered, and that should be enough.
If not, try some of these forums: https://forum.3rail.nl is a Dutch Märklin Users forum.
thanks 1 user liked this useful post by Jan Trein
Offline hermanvk
#21 Posted : 14 December 2024 13:54:14(UTC)
hermanvk
I know 3rail! ThumpUp and the members are very friendly and helpful. .
Also: https://forum.beneluxspoor.net/index.php
And: https://forum.modelspoormagazine.be/
thanks 2 users liked this useful post by hermanvk
Online RudiC
#22 Posted : 14 December 2024 16:06:51(UTC)
RudiC
To me, this looks pretty normal for analog mechanical operation. You can try to weaken / loosen the spring a tiny bit to reduce the well known "Bocksprung" (leap frog). Or, install an electronic reverser if not a full blown decoder to eliminate it to its entirety.
Rüdiger (Rudi)
#23 Posted : 14 December 2024 20:26:24(UTC)
I see the European version of the 10VA Start Set transformer. I don't know what the voltage setting for that model was. If the transformer was originally designed for 230VAC instead of 220VAC, it would reduce the output voltage slightly. This might be enough to cause the locomotive to not be able to trigger the inversion mechanism. The locomotive in the video does not suffer from the raging bull acceleration that I have seen on my older (3001, 3005, 3013, 3014 type) models. It does seem to jump a bit when the pulse is actuated. A 230VAC transformer running on 220VAC would yield around 23V instead of 24V. The newer versions were designed to deliver the 24V inversion pulse at 220VAC.
By adjusting the tension on the spring, you can adjust the reverse unit so that it actuates faster, which may reduce the jumping.
230VAC
Screenshot 2024-12-14 at 2.14.11 PM.png (1,398kb) downloaded 25 time(s).
220VAC
Screenshot 2024-12-14 at 2.14.32 PM.png (1,629kb) downloaded 21 time(s).
Offline Jan Trein
#24 Posted : 15 December 2024 11:20:23(UTC)
Jan Trein
Confused
I don't see any pictures from TS, so you know things I don't, for example loc 3074 and transformer number and type 37540.
If you have loc and transformer number, it's easier to retrieve information.
There is no coincidence between an analog transformer (220, 230 volt) and the pulse on an analog loc.
(OK, just have to adjust the spring tense a bit, perhaps, intuitively).
There is a rather complex technical explanation for it (about changed electric current fluctuation on the European net),
and there is simple practical information (I know people using these old blue transformers with analog locs, without problem).
But don't use that transformer on a digital loc, the decoder will be burned and never works again,
whatever the voltage the transformer was meant for.
Analog blue and some analog white transformers are incompatible with decoder usage.
So if there might be a problem, this loc must have an electronic reversing unit (FRU in German) from either Märklin, Uhlenbrock, Hag or what so ever. And that unit then should be restricted to exactly 25 volt. I don't know any model of those. Those restrictions came during the decoder introduction.
On the contrary, I have 2 HAG reversing units (built for Buco), and they have a pulse range from 18-48 volt, caused by the relay type used to switch direction. As soon a pulse is higher than 18 volt, the (bistable) relay switches once. Capacitors prevent a next switch, based on the same pulse.
Anyway, all analog Märklin locs in the past were leaving the factory in a box with a leaflet.
(Second hand bought trains seldom have the leaflet included.)
In that leaflet was written (in 4 languages) what to do with and buy for that specific loc (reverse spring tension, oiling principles, asb change, a.s.o.).
Of this loc number (3074) I scanned 2 pictures out of that leaflet (and put them in an Album), and attached them here
(just to see how it works):
Fig 1:
Text (in Dutch):
thanks 2 users liked this useful post by Jan Trein
Offline Coen236
#25 Posted : 15 December 2024 16:15:11(UTC)
Coen236
Thanks all! it worked a lot! The spring was a way to tight so I weaked it whit the srewdriwer and it worked now it moves a tiny tiny bit but its not trowhing the buffer away ;)
thanks 3 users liked this useful post by Coen236
#26 Posted : 15 December 2024 18:32:18(UTC)
you´re welcome...
Guest (6)
This page was generated in 0.940 seconds.
