Offline garben
#1 Posted : 09 December 2024 00:51:25(UTC)
garben
I currently use Train Controller 10 to run my layout and have come across an issue that I hope someone may have some experience with.
I like to run my trains run in the forward direction with the slider/pick up shoe in the front. For one particular locomotive that I'm in the midst of speed profiling in TC, TC has the train direction opposite. In other words, when I move the locomotive forward (slide in front) TC thinks is's going backwards while speed profiling. Is there any setting I am missing in TC? Is there a way to correct this, without going "under the hood" and rewiring the decoder, lights etc?
Thanks.
Norbert
thanks 1 user liked this useful post by garben
Offline pederbc
#2 Posted : 09 December 2024 09:02:53(UTC)
pederbc
Hi Norbert,
You can change the direction in the lok-decoder. If it’s a DCC decoder this is controlled by bit 0 in CV 29. What type of controller ( Märklin etc) are you using to control your railroad?
Peder
Offline amartinezv
#3 Posted : 09 December 2024 11:31:00(UTC)
amartinezv
Although it is normal that the current pickup is at the front of the locomotive, this is not the case in all märklin locomotives, for example the diesel type 216 have the pickup shoe at the back, and there are more, the front of the locomotive is defined by the letter V or the number 1, and the back by the letter H or the number 2.
You also have to take into account the orientation of the train or locomotive.
It would be good to know what type of decoder your locomotive has, some decoders do not work well with the train controller, on the other hand, if your control panel is an Intellibox, the first generation marklin mfx decoders sometimes do not work well with the IB. And this is not a problem of the IB but of those decoders.
Märklin, MM, DCC, IB and TC 7
Antonio Martínez
www.raildigital.es/davidruso
thanks 1 user liked this useful post by amartinezv
#4 Posted : 09 December 2024 11:39:02(UTC)
Hi Norbert
I am not a TC user but a Rocrail user, however, I am pretty sure that the mechanism is the same:
- the "forward" direction (the direction the loco will proceed when driven by TC) is NOT necessarily the forward direction of the loco (cabin 1 first, slider in front)
- in Rocrail, when you right-click on the loco you have multiple choices and one is "change the logical direction" which allows to change the preferred operation direction (e.g.: tender first, tender last) so you might want to look for a similar command on the loco in TC)
Offline garben
#5 Posted : 09 December 2024 16:14:57(UTC)
garben
Originally Posted by: pederbc Go to Quoted Post
Hi Norbert,
Peder
Thanks for your reply. It is a Marklin MFX decoder. I use the Marklin CS3+ for train control. I was curious if it's possible to change the direction via the decoder but didn't get that far into it yet. I get a little nervous when it come to fiddling with such things.
Offline garben
#6 Posted : 09 December 2024 16:22:04(UTC)
garben
Thank you for your input! The loc has a Marklin MFX decoder, it's from 2018. I use the Marklin CS3+ for train control.
Norbert
Offline garben
#7 Posted : 09 December 2024 16:28:18(UTC)
garben
Hi Norbert
Jean, thanks for the input. I do know that when you right click on the locomotive there is an option to change the locomotive's orientation. I didn't try that yet because I assumed I needed to profile the train first, but maybe not. Hopefully it's that simple! I'll give that a try that tonight.
Thanks again. Norbert
P.S. I was in Paris last month and visited AU Pullman. Great shop! I'll be in Paris again in January, any other good train shops that you could recommend? I'm a Marklin HO collector.
#8 Posted : 09 December 2024 20:04:16(UTC)
Hi Norbert
Au Pullmann is the largest model train shop in Paris.
There use to be much many more
In rue de Douai Paris 9th district, you have 4 shops about trains and other toys
They are all located close to each other:
  • Paris Modélisme 51 rue de Douai very detailled new miniature trains, Märklin, REE and much 2 rails stuff
  • Deco Atelier TET 48-50 rue de Douai 2nd hand Märklin and other brands in HO and larger scales
  • Trans Europ Trains 40B rue de Douai 2 nd hand HO and smaller scales
Truth is that Miniature Trains don't sell as good as before and, thanks to the EU, we can buy directly in Germany and receive stuff within 3 to 5 days with a shipment cost of 3.50 € with much better prices (typically minus 30%)
Note: in the old days We use to visit train shops in Cologne (Köln) Vedes Schidergasse, Bonn (PuppenKöning) which were HUGE (multiple floors of trains) but not anymore
Offline garben
#9 Posted : 10 December 2024 16:34:59(UTC)
garben
Hi Norbert,
Peder
Hello. I was able to change the direction on the decoder as you suggested. All is good! Thank you for the suggestion.
Happy Holidays.
Offline garben
#10 Posted : 13 December 2024 15:13:36(UTC)
garben
Hi Norbert
Thank you Jean! I'll be back in Paris in January and will check out the other shops you mentioned. Have a very Merry Christmas and a great New Year!
P.S. I was able to change the direction via the decoder on the Locomotive. We are all going in the correct direction now!
Guest (4)
This page was generated in 0.316 seconds.
