Offline Grandcrappy
#1 Posted : 05 December 2024 01:25:05(UTC)
Grandcrappy
Anybody, I can't get my DCC engine to move. It worked before. I saw?a green light when plugging in cord, Only get a red flashing light with commands?
#2 Posted : 05 December 2024 04:52:37(UTC)
Is that the only Maerklin you have?
I am not familiar with the Infrared controller that came with that set. The power adapter has to be plugged into the track section with the IR receiver. The controller itself requires batteries in order to function.
According to the instructions, it takes 2 Triple A (AAA) size batteries.
You may need to replace the batteries that are currently in the remote control.
That would be the first test. Please let us know if it works once done.
Offline rhfil
#3 Posted : 05 December 2024 20:16:47(UTC)
rhfil
According to the Maerklin website the engine that comes with the 29722 set is mfx. Are you trying to use the controller with a different locomotive which is dcc?
#4 Posted : 05 December 2024 20:52:54(UTC)
The loco may be mfx, but the starter set controller is MM only - no mfx, no DCC.
The controller has 4 different addresses.
Grandcrappy, have you tried all 4 addresses?
Offline rhfil
#5 Posted : 05 December 2024 21:39:59(UTC)
rhfil
And then if the locomotive did not come with the set is the decoder at one of the four addresses that the IR controller can communicate with?
OceanSpiders 2.0
This page was generated in 0.364 seconds.
