Offline JDB103
#1 Posted : 22 November 2024 11:14:38(UTC)
JDB103
Greetings- brand new to this forum!
Question: What is Delta? I’ve seen some engines listed as Delta Digital. Can these be used on regular digital systems?
Many thanks!
-J
thanks 2 users liked this useful post by JDB103
#2 Posted : 22 November 2024 11:30:30(UTC)
You have been a member since:: 04/02/2011(UTC)
Greetings James
Thank you for joining us on this great forum.
Here a Märklin fan from Paris - France
What is DELTA:
- it is a Märklin brand to designate a simplified digital loco.
- it was used 20 years ago during many years (no brand new Delta anymore)
What simplifications?
- a reduced number of possible addresses (often limited to 4 or 5)
- no indepedant fonction(s) like lights, Telex, etc
- lights are dependant on the speed (faster = brighter)
- no inertia simulation
- no sound
Offline PeFu
#3 Posted : 22 November 2024 11:30:55(UTC)
PeFu
Welcome to this forum! You will find some basic but good information on this topic, here:
https://en.m.wikipedia.o...iki/M%C3%A4rklin_Digital
Smile
thanks 2 users liked this useful post by PeFu
#4 Posted : 22 November 2024 13:20:07(UTC)
Welcome James. Yes, you can run Delta decoder equipped locos with any of the Marklin digital controllers. The first Delta controller had a 4 position switch, for a steam, diesel, electric, and a railcar, but not exclusively for one of each. Just 4 addresses.
It connected to the blue former transformer. A Delta pilot corded extension control came next, to allow a second person or to run two trains at once. It had a speed control knob and a reverse button. I made my own with a blue project box, red button, and potentiometer from Radio Shack. The second Delta control was white and added a button for the headlight function. Also the starter sets initially came with a fixed address decoder, but later delta locos have a dip switch decoder with 4 switches which adds additional possibie addresses. As my collection and layout grew in size, I upgrade to a 6021 digital controller, then to the MS2 and a CS 3 plus.
Offline JDB103
#5 Posted : 22 November 2024 20:38:14(UTC)
JDB103
Many thanks! Very helpful and much appreciated!
#6 Posted : 23 November 2024 12:36:52(UTC)
What is DELTA:
To say that Delta is not used today is not strictly true. While they are not labelled as Delta the joystick and infrared controllers used in start sets use the identical loco addresses for the four selectable locos as the Delta addresses, and in most cases the locos supplied by Marklin have their MM address set to the appropriate one of these address for the loco type.
To expand a little on Jeans explanation, the Delta controller had a selector switch that designated the type of loco that was to be controlled, namely steam, diesel, railbus, electric.
Each class was allocated an address; -
Steam, address 78
Diesel, address 72
Railbus, address 60.
Electric, address 24.
The earliest DELTA controllers could also have an additional handset that had a dedicated address of 80, although use of this never really seemed to catch on.
Locos were supplied from the factory with the MM address already set to that appropriate for the loco type, so for the end user the system was very 'plug and play', take the loco out of the box, put it on the track, select it from the switch and away you went.
The addresses are a sub-selection of the full MM (Marklin motorola) address range and can be driven by any controller capable of controlling Marklin decoders.
The original Delta decoders had no functions available, but as they used the same chips as standard decoders people worked out how to add the headlight function. Later Delta controllers had a button to control headlights. Some of the current Start Up controllers do have up to four functions controllable plus the headlight.
Offline 60904
#7 Posted : 23 November 2024 18:01:04(UTC)
60904
Today's starter sets have nothing like DELTA decoders. For quite some time there are mfx decoders which are set to the old Delta addresses in MM. 255 are possible to set. I am not aware of any Delta decoder with F0. The last Delta decoder sold was one where 80 addresses were possible. Function could be activated by switching direction twice.
Martin
thanks 2 users liked this useful post by 60904
Offline Wolfram_Stn
#8 Posted : 28 November 2024 09:52:11(UTC)
Wolfram_Stn
That is right. Delta, as brand and as technical way, has been discontinued.
IMHO delta disappeared from catalogue at the moment that the PIC decoders were introduced, and the StartUp controllers with plugin power supply unit imposed by EU rules. At that moment they did the step to abandon all analogical and semi-analogical locos. (delta was the solution to replace the relais by some cheaper electronics and on the same time to offer a cheap entrance to digital railroading.)
But, effectively, remain some details, so as the MM addresses that can be piloted by the joystick controllers you may find in some "StartUp" starting packs. I suppose that this is because Märklin wants to maintain compatibility with some old delta locos to be found at the grandfather's house... so as any new loco may be controlled with a 1960s transformer (except if the manual says you shall not).
Since some years, there are some people that call "delta" all decoders with microswitch address coding, which is simply stupid since they throw in the same bin the c80, delta and c90/c90x, last but not least since they were the 1st class decoders for a couple of years with a really good motor controlling, and besides the antique MM or MM2 protocole, they hold very well their place face to modern decoders.
thanks 2 users liked this useful post by Wolfram_Stn
#9 Posted : 28 November 2024 11:37:09(UTC)
The Delta decoder 66032 was in the catalogue until 2011/2012. How about that?
AIUI EU rules still allow analogue starter sets, but they no longer made sense for Märklin.
And yes, decoders with standard PIC chips were cheaper than DIP-switch decoders with custom-made chips. The first programmable decoders in H0 locos came 2004 AFAIK.
There was a year when all sorts of decoders from the spare parts store were used in Aldi starter sets.
Offline bph
#10 Posted : 28 November 2024 12:43:36(UTC)
I recommend this site for more information on Delta/old digital decoders: http://www.pallund.dk/digiview.htm
including this page with various enhancements etc, including how to program 80 addresses on a delta decoder with 4 dip switches.
http://www.pallund.dk/convert.htm
Offline Wolfram_Stn
#11 Posted : 30 November 2024 15:49:28(UTC)
Wolfram_Stn
Maybe. I do not have a catalogue from 2011/2012, I do not know how it was presented - maybe as a spare part? But the latest models with Delta module were presented, so far as I know, about 2004.
And 2004 was the year when the Delta Control f (66045) was discontinued. Technically, it survived in some "digital piloting consoles" ("digitales Fahrgerät") so as in https://www.maerklin.de/...te/details/article/29852 but these were no more sold separately, and were not branded "Delta" but "Märklin digital". Remark, 29852 contains a classic transformer as power source ! *)
Right - but classic transformers are no more allowed in children's toys. The toy must not be connected directly to a wall plug but to a PELV or SELV source. That's the reason for commanding units with separate plugin power supply unit - which existed, for Z, in analogue variants, but were abandoned in H0 for 4-adresses-digital commanding units (infrared or cable).
*) With this package, they did not fear the ridiculous : a 18VA transformer (if I see well) instead of 30VA in elder one-train-packages, and a single command unit in a package "Daddy, come and play with me"... there was not even a Hand pilot, and no possibility to connect another command unit...
this remains me the 29820 "Mega Digital" package, with a 60052 transfo (60VA - enough power to put a smoker in the loco, and 7329 lighting in the three coaches...), but only a 18VA MS1, so when the coaches have light, you start sound, the smoker, one loco - and the second loco will put the MS in fail as you go over 18VA. Not mega at all. ThumbDown Cursing
thanks 1 user liked this useful post by Wolfram_Stn
#12 Posted : 30 November 2024 19:06:33(UTC)
This is not correct; FYI Märklin still produces and sells the 66471 transformers.
Nowhere in the EN IEC 62115 is it mentioned that transformers can't be used by children,
actually there's a note in the latest version from 2020 saying:
"Transformers for toys (EN 61558‑2‑7:2007 for linear types or EN 61558‑2‑7:2007 and EN 61558‑2‑16:2013 for switch mode types), battery chargers (EN 60335‑2‑29:2010) and battery chargers for use by children (EN 60335‑2‑29:2010,Annex AA) are not considered to be part of an electric toy even if supplied with an electric toy".
P.S: Of course Märklin has a not required note in the 66471 description:
"The 66471 safety transformer is not a toy for children."
Unlike manufacturers and sellers of balloons who are required to mark their products with:
"Warning! Children under eight years can choke or suffocate on uninflated or broken balloons. Adult supervision required.
Keep uninflated balloons from children. Discard broken balloons at once."
Offline Wolfram_Stn
#13 Posted : 02 December 2024 19:45:35(UTC)
Wolfram_Stn
Oh... let us stay on the facts.
It's fine to cite EN IEC 62115, since it's impossible to find the text on internet except behind a paywall : it's a normative text for professionals...
But you should not forget Directive 2009/48/EC in it's actual version (5 december 2022!), where you can read the rule
IV. Electrical Properties
9. The electrical transformer of a toy shall not be an integral part of the toy.
THIS is the reason why 66471 is not a children's toy, and why it will and shall never be considered as a toy: it combines the transformer and the regulation unit necessary to control the trains. So the cited mention is not "not required" as you said, but imposed by law.
For toys, you MUST separate the transformer and the controller.
So far, the resting choice is to give a transformation unit, and combine it with a rheostatic analogical controlling unit for one single train, or an electronic unit for up to four trains... the last makes more sense since there are no more analogical locomotives, so why offer starting packs with analogical controller ?
But... aren't we getting out of the topic ?
#14 Posted : 02 December 2024 20:44:22(UTC)
I don't know; you started by telling us Märklin stopped making starter sets with transformers,
because transformers are not allowed in children's toys BigGrin
What you've mixed up, and what you can see in the below found by yourself, is that a transformer is not allowed to be
an integrated part of the toy ( but has to be a stand-alone unit, as e.g. the 66471 )
Please show us where the law is that makes stricter rules for the Märklin 66471 than for any other household transformer.
#15 Posted : 02 December 2024 21:49:41(UTC)
Actually, when I follow your link I get to a page headed "This text is meant purely as a documentation tool and has no legal effect."
The IEC standards are international standards that do have legal effect. I know that for a fact as i have had to do testing to such standards.
You also forget another reason why manufacturers keep the transformer as a separate item, and that is standards testing. An item with mains connection needs testing to the appropriate IEC standards for its end use - but once you get to the isolated low voltage side you don't need to test to IEC standards. If the mains supply is built into the end item then the whole end item needs to be tested to appropriate IEC standards relevant to the whole item. This can involve a considerable amount more testing than that required by having a separate power supply, as once you get to a complete item the IEC standards can interact which makes the testing very complex.
Offline Wolfram_Stn
#16 Posted : 04 December 2024 08:35:44(UTC)
Wolfram_Stn
Oh, this is low.
You should read the whole header:
This text is meant purely as a documentation tool and has no legal effect. The Union's institutions do not assume any liability for its contents. The authentic versions of the relevant acts, including their preambles, are those published in the Official Journal of the European Union and available in EUR-Lex. Those official texts are directly accessible through the links embedded in this document
►B
DIRECTIVE 2009/48/EC OF THE EUROPEAN PARLIAMENT AND OF THE COUNCIL
of 18 June 2009
on the safety of toys
(Text with EEA relevance)
(OJ L 170 30.6.2009, p. 1)
I agree, the link in the header points to an obsolete version of the text, the actual text - in it's relevant version having legal effect - is here: https://eur-lex.europa.e...EX%3A02009L0048-20221205
But the cited text is the same.
From the moment you need to touch the transformer when playing with your train, the transformer is integrated part of the toy and must not be connected directly to the wall socket but to a PELV or SELV source.
Is that really so difficult, or just an attempt to keep reason against all arguments ?
'cause I give arguments, you say just "it's not that". Proove it! Give texts that say, with legal authority, "a transformer with integrated controlling unit is not a toy in the meaning of the toy directive".
That is the reason why a 66471 is not and will never be declared as toy for children below 14 years: it combines the controlling unit, which is clearly part of the toy, with the transformer unit. This combination is prohibited by 2009/48/EC.
And since you have access to EN IEC 62115 without paying 200 Euros, would you, please, verify the description given in EN61558 about "transformers for toys"?
#17 Posted : 04 December 2024 17:56:48(UTC)
So in a new start set, with a SMPS, how would the child connect the SMPS to the wall socket without touching it?
Please read ANNEX I.18 to see if a transformer is a toy or not ( + ANNEX II.IV.9 ) and ANNEX V part B, to see if a warning is required:
https://eur-lex.europa.e...2009L0048-20221205#M17-1
A transformer is not considered a toy, thus no warning is required Cool
Everything connected to a wall socket in your house, transformers and SMPSs included, are under this directive:
https://eur-lex.europa.e...XT/?uri=CELEX:32014L0035
Nothing special mentioned about Märklin's 66471 or any other transformer or SMPS - and no pay wall Cool
And it all comes from this statement from you, which you don't accept being wrong:
It has nothing to do with "Children's toys"
The main reason Märklin now sells SMPSs included in their starter sets, is the EuP directive from 2005,
which later became the Energy Efficiency Directive.
Offline rbw993
#18 Posted : 04 December 2024 18:42:50(UTC)
rbw993
This all seems a bit off topic from J's original question.
#19 Posted : 04 December 2024 20:09:00(UTC)
Yes!
Offline TrainIride
#20 Posted : 05 December 2024 19:03:34(UTC)
TrainIride
Many thanks!
-J
Hi J !
Just to add a picture with the address selection for Delta/Digital
Best Regards
Joël
thanks 5 users liked this useful post by TrainIride
Offline ChrisKenna
#21 Posted : 31 December 2024 00:19:52(UTC)
ChrisKenna
Many thanks for your post plus helpful links. Reading these makes me realise that I'm way out of depth on this topic. I recently bought two Delta locos and I think my options are either to send them to a Marklin expert for help or just run them in analogue.
Thanks again, Chris, Canberra
With respect and thanks to Ngannawal, Ngambri and all First Nations people
thanks 1 user liked this useful post by ChrisKenna
OceanSpiders 2.0
mFX or Delta, when my other engines are all Delta? (Digital)
by Nate 11/12/2020 23:13:45(UTC)
3459? Delta? (Digital)
by Iamnotthecrazyone 05/12/2012 23:47:00(UTC)
explanation of digital and delta? (General MRR)
by sheu 22/01/2011 05:45:06(UTC)
MFX,FX...and DELTA? (Digital)
by FMS 06/02/2009 03:45:26(UTC)
Help- MAXI Engine- Digital? Delta? or DC Only? (Digital)
by steameng8 02/02/2009 23:56:21(UTC)
Retrofitting old locos with Digital or Delta? (Digital)
by yosefi 27/11/2001 10:06:02(UTC)
This page was generated in 1.398 seconds.
