Offline Gtpooleltc
#1 Posted : 10 November 2024 19:14:23(UTC)
Gtpooleltc
I purchased two Marklin locomotives.. 88834 and 8800. They both appear like new and have probably been sitting, unused, for 30 years. Both are in original box with instruction sheet on lubrication. Should I lubricate locomotives before running? What lubricant? The Marklin 7199 oil recommended is unavailable.
Thanks for your help,
Gtpooleltc
#2 Posted : 10 November 2024 19:22:31(UTC)
Welcome to our great forum.
The Märklin oil is to be used whenever you can.
For a small gauge like Z, a fluid, neutral oil will do. Maybe vaseline oil as used on sewing machines
The key thing is to lubricate very sparingly (I use a seringe to deposit a micro drop of oil. Wipe the excess oil with a clean cloth.
Offline madhu.gn.71
#3 Posted : 11 November 2024 06:54:53(UTC)
madhu.gn.71
India
If a loco is not used used for many years (I had purchased a loco set from 1997 and had this issue of dried lubricant), the lubricant\grease becomes super sticky preventing the gears from turning. I would first keep the loco on the track and see if it moves and the lights come up. If the lights come up but the loco does not move or stalls with a humming noise, I would open up the loco and remove the dried lubricant in the gear train. Lubricate it with tiny bit of sewing machine oil and move the loco back and forth manually with motor assembly disconnected. This lets you know how smooth the loco is. I usually lubricate the gear train and motor shaft.
thanks 1 user liked this useful post by madhu.gn.71
#4 Posted : 11 November 2024 12:06:57(UTC)
here is a method used on small scale N, Z HO
This is based on using SR24 (NOCH) cleaning liquid used by many modellers
No need for dangerous opening of tiny locos
Let the loco dry a little and then lubricate A LITTLE
This page was generated in 0.234 seconds.
