Offline Keyser
#1 Posted : 27 September 2024 23:02:51(UTC)
Keyser
I have just acquired a 39662. It runs well even on R1 track and through turnouts. But, only going forward. When reversing the dual ( run and display) coupler contracts and the tender and loco will foul each other. Does anyone have a good way of keeping the coupler in the extended length short of gluing the adjustment slider in the extended position?
Offline nmbssncb
#2 Posted : 10 October 2024 11:35:13(UTC)
nmbssncb
Have you looked at pages 28 and 29 of the Instruction Manual 39662 and at the the Exploded View 39662 especially the spring part # 7?
Willy
thanks 1 user liked this useful post by nmbssncb
Offline Keyser
#3 Posted : 10 October 2024 14:47:58(UTC)
Keyser
Willie
Thank you for your reply. I believe that I have extended the coupler to run position. However, the click did not seem as pronounced as I fully extended it as it has on other Marklin locomotives. I will check when I get home.
As for the spring, I am not sure what you are saying. Is it to check that the spring is present? Please explain the significance of the spring.
Thank you again for your help.
Neely
thanks 1 user liked this useful post by Keyser
#4 Posted : 10 October 2024 15:12:00(UTC)
Yes, this is a common thing. The click stop seems tighter when they are new. My br 10, etc. are this way now. A heavier train can pull it out to the wider position.
#5 Posted : 10 October 2024 18:06:32(UTC)
Hi Keyser
I have that same loco and I also have many hidden tracks with R1 curves and R1 curved turnouts
Today it runs fantastic but after a few checks
Loco Checks
- the coupling between tender and loco is supposed to be in the WIDE position (Which I did) But on my loco and some others, the latch is weak resulting - in reverse - by getting the tender too close to the loco and provoking derailments. Solution? A bit of NOCH Hin & Weg Kleber to force the coupling in the right position. Result: It runs excellent even when pushing back a long set of passenger cars, you can still store the loco in its packing and remove the temporary glue anytime without damaging the beautiful model.
- the spring on the trailing bogie is a bit weak so I adjusted A LITTLE BIT yo increase the pressure on rails
Layout checvks
- no "S"-shaped tracks using R1, even when combined with R2. Solution? Insert a short straight between the curves. A "S" shape is allowed when using R2 or bigger.
- no grade UP or DOWN at entry of a curve
That loco goes now on my Rocrail-controlled layout to couple / uncouple a consist, manoeuver in the steam depot, go on the Turntable 7286. Only restriction The Fleischmann shed is a bit too short so the doors must remain open (Sorry I have no video on Youtube of my layout with this loco.
#6 Posted : 14 October 2024 18:25:46(UTC)
Hi All
This topic got me thinking that I missed a video with the 39662 BR 06 001
Here it is as you can see working very fine but I still have current pick-up issues (not the loco's fault but mine)
The point I am trying to make is the loco runs fantastic once you checked the issues I mentioned earlier
Offline franciscohg
#7 Posted : 14 October 2024 19:28:17(UTC)
franciscohg
Chile
Yes, yes, yes. When you extender the coupler to run position it does not lock easily causing derailment on backwards run as the tender comes to close to the loco. When trying to lock it the force you have to apply seems to big IMHO. I was scared of breaking the coupler, so i took the tender Cover out and help me with a pair of plyers. Works fine and never had troubles again.
42265 Insider 2022 coach set for BR06 39662 (H0-scale)
by kimballthurlow 15/12/2022 07:45:54(UTC)
39662 Insider - N&W (USA) comparison (Loco Reviews)
by kimballthurlow 15/11/2022 04:23:50(UTC)
The new BR 06 39662 Insider (H0-scale)
by bph 03/08/2022 18:00:31(UTC)
This page was generated in 0.289 seconds.
