Offline nick.r
#1 Posted : 01 June 2024 22:29:00(UTC)
nick.r
I have a 3153 which is a Delta locomotive.
I'm building a new layout, all digital of course and converting the locomotives one by one.
For right now however, my question is this:
Can I replace the existing motor (which is using 3 poles, ground, forward, backward) with a new 60941 motor (2 poles that get inverted) and keep the existing Delta decoder?
If the answer is yes, then how should I wire this up, with diodes maybe?
#2 Posted : 02 June 2024 00:15:05(UTC)
Hi Nick
Can I replace the existing motor with an HDLA, 5 pole DC motor?
On my Koll's Catalog it says that the BR 120 of the German DB in Beige Red has been manufactured in 1980-1984 and one shot in 1987.
So early models may still have the SFCM motor (Small Flat Collector Motor). The motor can be recognized by its round-section brushes (1 copper and 1 graphite) In this case the 60943 motor can be used
Later models using a DCM (Drum Collector motor) with 2 graphite brushes with square section. In this case the 60941 motor can be used.
Can I keep the existing Delta decoder?
Straight out of the box, no you can't and besides, the performance could be worse than with the original motor.
Another interesting possibility
- Keep the motor and use a 60906 decoder (MFX, DCC, MM2). It has 2 additional outputs additional to headlights outputs (x2). It has everything except load regulation.
Offline nick.r
#3 Posted : 02 June 2024 01:07:04(UTC)
nick.r
The original motor IS my problem.
I'll get myself another decoder as well then.
Thank you
Offline 60904
#4 Posted : 02 June 2024 23:07:19(UTC)
60904
Hi Nick
3153 has always had the DCM and no factory built in Delta. Never the SFCM. If you like to keep the original performance use 60906; otherwise change to 5 pole motor.
Martin
thanks 1 user liked this useful post by 60904
Offline nmbssncb
#5 Posted : 15 June 2024 18:20:46(UTC)
nmbssncb
Help needed on motor replacement selection (Digital)
by einotuominen 29/09/2022 18:47:42(UTC)
Decoder and motor replacement (Digital)
by luckas 20/06/2022 13:06:50(UTC)
Motor replacement for 8892 (Small scale)
by wildstix 12/05/2021 10:25:29(UTC)
Current Marklin motor replacement (General MRR)
by Bryan 26/09/2020 01:34:05(UTC)
216907 motor replacement (Digital)
by Hackcell 23/10/2015 21:05:07(UTC)
Motor replacement help (Small scale)
by EricBrian 05/01/2008 04:03:36(UTC)
This page was generated in 0.511 seconds.
