Offline petestra
#1 Posted : 15 May 2024 18:55:12(UTC)
Hello. I don't know if any others have encountered this problem with the new style Marklin wire plugs? I have experienced many falling
out of the many buses I have for wiring. With the amount of wiring I have, a friend recommended this product (see photo), which when dabbed on the plug ends around
the red plastic part, will give it a "gummy sticky feel" and hold them on much better. Peter.
thanks 3 users liked this useful post by petestra
#2 Posted : 15 May 2024 19:50:36(UTC)
Yes Pete. I liked the old plugs better. I mostly used them for lighting,so every time one is out, I suspect the bulb, or led, but the wire was hanging from the distribution strip.
Offline mvd71
#3 Posted : 15 May 2024 23:21:10(UTC)
The new style plugs are a narrower diameter than the old ones. If you use an old style distribution board they will always fall out. Glueing them in is not a smart move!
If you prefer the old style, then you can still buy them through Brawa https://www.brawa.de/en/...ories/connectors-sockets
#4 Posted : 15 May 2024 23:48:57(UTC)
I used the new strip and they still fall out when multiple plugs are joined.
Offline petestra
#5 Posted : 15 May 2024 23:50:42(UTC)
Hello and thanks for your comment. Perhaps I didn't describe this glue correctly. It is a gummy, sticky glue that can easily be removed from what
it is glued to and can be put back in without extra, new glue applied to the red plastic part of the plug end. I have used it for one year
now and no problems at all. BTW, I have many of the old style plugs too and their buses. Cheers, Peter.
#6 Posted : 16 May 2024 03:31:38(UTC)
I have never used the old style Märklin plugs.
I use the new style plugs and the distribution strip and have exactly your problems Peter.
I will try the gummy method.
I suspect that the denture adhesive used for false teeth (dentures) in the mouth will accomplish the task just as well.
And possibly even one of the hardware adhesives which never hardens.
Offline Bosse
#7 Posted : 16 May 2024 09:04:23(UTC)
Bosse
Hello. You take a knife and split the pin a little wide. MVH Bosse
thanks 2 users liked this useful post by Bosse
Offline mvd71
#8 Posted : 16 May 2024 11:18:43(UTC)
Exactly! ThumpUp
Offline Harvey
#9 Posted : 16 May 2024 14:42:14(UTC)
Harvey
I have both new and old style plugs and have not experienced any problems. I twist 2 (at most 2) wires and then insert to one plug. I also have plugged one into another and also not experienced any problems. Maybe once, I had to follow what was suggested - open the pin slightly. Rarely do they come loose from the distribution strip (may be due to the cats or myself moving around).
If old style plugs are needed by anyone, I do have quite a few and are no longer needed. Send me a message, if needed
Harvey
thanks 1 user liked this useful post by Harvey
#10 Posted : 16 May 2024 16:29:36(UTC)
I use the Brawa plugs and their distribution board which works fine and takes up less room.
Guest (10)
This page was generated in 0.543 seconds.
