#1 Posted : 04 May 2024 04:52:04(UTC)
It would be interesting to know how long it will take the model world to introduce automatic coupling as the European rail companies are introducing or fixing more freight carriages with automatic coupling, it maybe the end of having all these different couplings most of them don't couple or are incompatible or may some individual manufacturer will come up with an automatic coupling mechanism,
by the way I've found the most reliable coupling for us is the Roco coupling, as it hooks on both sides
Offline mvd71
#2 Posted : 04 May 2024 10:18:07(UTC)
Ahhhh but which Roco coupling??
#3 Posted : 05 May 2024 03:52:25(UTC)
40397
Offline mvd71
#4 Posted : 05 May 2024 06:40:36(UTC)
40397
But I want the Fleischmann close coupler!RollEyes
Offline mbarreto
#5 Posted : 05 May 2024 21:49:45(UTC)
mbarreto
Roço couples well with Roco although it is not very short coupling.
Fleischmann close complete are really short but they are not soft in coupling and the unciupler Märklin traços are not really made for trem.
The new Märklin close couplers are, currently, my choice.
Miguel
Miguel
Mostly Märklin H0.
Offline mvd71
#6 Posted : 05 May 2024 22:20:06(UTC)
What are the new Märklin close couplers?
#7 Posted : 05 May 2024 23:00:08(UTC)
They are the 72000 (pack of 50) and 72010 (pack of 10) and 72025 (current conducting, pack of 10)
They look similar to the previous ones but are flater (they squeeze into less room which allows the buffers to be in the prototypical position
Here you can see a front view of the previous coupling on the left and the new one on the right
They are compatible with the previous ones (can be mixed w/o problems) AND they are compatible with the current-conducting ones
Apparently Märklin has also increased the vertical tolerence between couplings
thanks 7 users liked this useful post by JohnjeanB
Offline mvd71
#8 Posted : 06 May 2024 02:10:19(UTC)
Thanks Jean, that good to know.
Cheers…..
Offline Paul59
#9 Posted : 06 May 2024 09:49:39(UTC)
Paul59
I can't really see any manufacturer ever coming up with a decent automatic coupler that works well in all situations.
The current Marklin couplings work well so long as you have a large layout.
Unfortunately many people can't have large layouts either through cost or space restrictions. Small layouts mean that a lot more of the track is on curves and the coupling/uncoupling areas are more likely to be on a curve. The couplings don't work well on curves.
I can't really see a way of making a coupling that will work well on curves.
Strangely the only one I can think of that worked under these conditions was the earlier Triang ones. These were large and hideous looking but they worked under virtually any conditions. I guess they were designed for small 'train set' use.
These days with everyone obsessed with detail and realism the good operation of couplings has to take second place to the couplings appearance.
thanks 2 users liked this useful post by Paul59
#10 Posted : 06 May 2024 10:18:32(UTC)
Hi Paul
Agreed Märklin couplers don't work in curves, they are not so tolerant with differences in height and orientation and last, the coupling buckles should be sharpened to avoid a situation when both buckles raise and go past the "advance decoupling tongue".
It looks like a big grievances list but IMO they work quite well
Decoupling
Coupling
#11 Posted : 06 May 2024 11:26:20(UTC)
Roco offer at least three types of couplers, including a reproduction of the automatic couplers used by DB for their heavy ore trains.
You probably refer to the Roco Universal coupler. There also is the Roco Short coupler.
There must be more Roco couplers, including current-conducting couplers.
Offline mvd71
#12 Posted : 06 May 2024 11:48:51(UTC)
You are correct, Roco has a number of different couplers, including the Fleischmann coupler.
Offline Paul59
#13 Posted : 06 May 2024 12:10:40(UTC)
Paul59
An excellent couple of videos there Jean. I bet you had a lot of fun doing that.
The few wagons that I have with the newer close coupling work really well on straights both coupling and uncoupling and advanced uncoupling. Unfortunately I only have one siding that is straight enough to get the benefit.
I'm not knocking the manufacturers. I think uncoupling/coupling on curves is just not really an option. It's a shame but something we just have to put up with.
I really like your layout,
Paul
thanks 1 user liked this useful post by Paul59
Offline Jimmy Thompson
#14 Posted : 06 May 2024 12:40:16(UTC)
Jimmy Thompson
Well, I shall go ahead and "shove my oar in the water" of this "River" LOL
Caveat #1: I am Analogue
Caveat #2: There is this past thread (6 years ago)
https://www.marklin-users.net/fo...-couplers-availability-s
Are we talking about DIGITAL automatic coupling (87:1 Prototype) as shown here?
https://www.youtube.com/watch?v=wcxeEC-ga3o
Because I found this Roco item which may be the one to which Tom was referring:
https://www.roco.cc/ren/40411-di...llation-kit-nem-652.html
However, I can not begin to imagine the complexities Scared inherent in having something like this installed on hundreds of loks and rolling stock (let alone the "investment" thereunto pertaining...) and whether it will be universal enough to be included in and/or compatible with the MS and/or CS3 systems...(it seems the Roco is specific unto itself).
Also, unless I am reading more or less into this, at this point the Digital couplers really are for just loks? I am open to clarification, please. Would not every single car require some form of power pick-up to control the decoder or would the couplers be "current conducting"?
If I am incorrect, please forgive me, however, I do try to understand as much as I can about our hobby and love Cool
Thanks and apologies in advance Blushing
Jimmy T
Dr Dirt's Rule #1 and
#15 Posted : 17 August 2025 12:20:40(UTC)
Jimmy Thompson
I thought I would revive this thread as I am still confused Confused when talking about "Automatic" (because are not all couplers regardless of manufacturer in some definition "automatic" ?) and here is a link to add to my confusion from the good folks at PIKO
https://www.piko-shop.de/de/ware...us-wechselstrom-383.html
9 loks in AC Version with Digital (Automatic) Coupling -
(Whisper Mode On and as an added question of whether the Piko Digital Couplers are universally compatible, or only with Piko cars (but this bit a probably a deep, dark Rabbit Hole, so maybe later on this bit Blink Whisper Mode Off ))
I suspect that I am making this more difficult than it truly is Blushing , but that is why I am here...to learn from the experts! ThumpUp
Thanks!
Jimmy T
#16 Posted : 17 August 2025 15:32:06(UTC)
Hi Jimmy
Automatic couplings exist since decades (in 1935 for Märklin) of course more or less efficient and more or less compatible with other types
Then came "close couplings" in the late 70s (only 1986 for Märklin). They were of various type but ALL had in common that - when coupled - they would form a rigid bar to allow the elongation / close coupling mechanism to work
It looks like Piko is proposing something close to what Märklin calls a RELEX coupler.
REALITY CHECK
- yes these couplings are automatic BUT usually pose problems when trying to automatically couple with types of couplers / maintain coupling through track irregularities
- in fact, Piko's approach is a temporary fix until you replace the coupling by a fully compatible one (with yours).
- not only Piko but also Roco and Märklin are proposing these couplings for universal use or ease of use by children (Märklin Start-up line)
- using these universal couplings with other types (e.g. with Mârklin's KK) lead to issues with uncoupling track or Telex couplers
Offline rhfil
#17 Posted : 17 August 2025 15:40:11(UTC)
rhfil
"The Hand of God." One aspect of this hobby is that operation of a layout often requires "The Hand of God" to replicate real world operation. That is shown to be true in operation of couplers. Although consists can be built without outside interference because most couplers will combine when bumped together they mostly can not be similarly uncoupled. So "automatic" couplers are sometimes those that be coupled by bumping. To solve the problem Marklin has two options. The first is an "uncoupler track" 24997 which works quite well and can even be operated from a CS3. The second is a Telex coupler which works fairly well and is a controllable function. That is really the only coupler I would describe as fully automatic. However placing Telex couplers on every car would be very expensive and uncoupling an entire consist with an uncoupler track would be time consuming. I have used both to back a consist into a location and then release the engine. It works quite well but with the uncoupler track it requires exact placement and the same length of consist. The engine I have has Telex couplings on both the front and back so would work with any length consist.
thanks 3 users liked this useful post by rhfil
#18 Posted : 17 August 2025 18:01:18(UTC)
Fleischmann closecoupler is pretty robust, but as mentioned; not ideal for switching, as it needs quite a push to engage. It´s nice and short.
I have problems with them on K-track, as they can catch the pukos when going over switches. I ususally lower the guilty part by cutting 1 millimeter off, and/or flattening the bottom with a soldering iron.
(I seem to remember that they actually exist in two versions, precisely because of this problem¿?)
The Roco short coupling is also good. But because it is so long, it looks quite ugly at the end of the trains. So as with the Fleischmann coupler I only use them in-between trains, and never at the front and rear. It´s fine, as most of my trains are rarely changed.
Not as reliable as the Fleishmann coupler. Also, the only movable piece it has, tends to fall off.
For both the Fleischmann and Roco couplers, they have the unusual benefit of being able to uncouple just by lifting a wagon vertically upwards!
The Roco universal coupler is my "go-to" solution for connecting all non-Märklin rolling stock to Märklin locos. They are not really short, but for most use it is "short enough".
I agree with river6109 that it is the most reliable coupling.
As with the other two mentioned couplings, they only couple with their own kind. So even when you THINK the universal coupler coupled with something else, you might be in for a suprice when the train hits the first curve; If it was the Roco universal that got its loop around the hook on the other coulping, it WILL uncouple, as its loop is open to one side!
Märklin close couplers are quite fiddly. They couple like cats and dogs; Somemtimes impossible to connect, at other times impossible to separate.
I have too many unfortunate random de-couplings. Even between newer original Märklin material. I am NOT totally happy with them.
The vast majority of my couplers are of this Märklin close coupler type, so I cant be sure if I would have the same amount of uncoupling-failures with the others.
Any "stutter" or sudden stop can leave the couplers pre-uncoupled. Only happens with Márklin close coupler!
The older (still most common) version of the Märklin close coupler is too high for almost all non-Märklin rolling stock; it will not clear the buffers on many newer stock. So you WILL have to use Roco or Fleischmann couplings, if you want the connection short.
In any other case they are good for coupling to older hook-and-loop style couplings, so they only coupling to truly "bridge the gap"!
I still do not own any of the newer version of the Märklin close coupler that JohnJeanB mention, but I hope to get some soon! On paper, this would be the perfect coupling. (the one that solves the most problems at the same time)
Lastly, we have the good old hook-and-loop couplers (including Märklin Relex couplers). These are excellent and reliable. They will usually couple across any brand. They are fine for shunting games too.
Only drawback; They do NOT couple close!
#19 Posted : 17 August 2025 18:40:03(UTC)
Another drawback: On rolling stock with coupler guide mechanism, they may even couple too close, leading to buffers hooking up. This can happen with long trains in curves, especially when going downhill.
#20 Posted : 17 August 2025 20:05:11(UTC)
Jimmy Thompson
I may begin to see where my puzzling comes in.Confused Blushing
It is actually Digital UNcoupling (Piko and apparently Roco and ESU) wherein one can, with the press of a button on the MS/CS/Whatever, UNcouple a lok from a train anywhere on the layout without the need for any in-/under-track mechanisms. We might even add in the word "Remote" to the digital function.
Piko's just happens to resemble those with which we are familiar...Roco and ESU are the more modern take...
Granted, one would not want to hit "That" button while traveling uphill...Ooops! runaway train
Sorry for my mass confusion as I obviously was way off Blushing and misinterpreted John's initial question, as he had just recently posted this:
https://www.marklin-users.net/fo...duces-automatic-coupling
Jimmy T
SBB Cargo introduces automatic coupling (Prototype)
by river6109 08/11/2019 02:27:17(UTC)
This page was generated in 0.593 seconds.
