#1 Posted : 11 April 2024 12:24:21(UTC)
Hi, I've been cleaning wheels and axles for a long time from carriages I've bought second hand, I either use my Demel drill with an cleaning wheel attachment or my new cordless mini Dremel type, the results are astonishing, this picture shows you the radical difference
#2 Posted : 11 April 2024 12:54:18(UTC)
Best tool for it John. The fam gave me one a few years ago for Christmas.
Offline bygger01
#3 Posted : 11 April 2024 15:30:47(UTC)
bygger01
Is John one of the family or what is it ??
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
#4 Posted : 11 April 2024 17:19:20(UTC)
Views messages in topic : 3,621
Hi John
This is indeed an excellent method for older Märklin rolling stock with needle bearing (1952-1980 or so) or plain bearing (1952 and before).
I would correct with this: it is a total disaster if you use your method on needle axles (conic end shape) on plastic bearings. You may ruin a bogie or a car that way very easily.
#5 Posted : 11 April 2024 18:45:11(UTC)
Mine is a Dremel with a slow speed and different buffing and emery wheels.
#6 Posted : 12 April 2024 14:12:37(UTC)
I also got a Dremel but the variable speed is gone on mine and we have another one in the train room but this one stays in the train room (is working 100 %)
#7 Posted : 12 April 2024 18:10:01(UTC)
That was heavy dirt on the wheels!! Blink
Offline mountainroads
#8 Posted : 12 April 2024 19:14:39(UTC)
mountainroads
Excellent idea. It's really tedious to do by hand scraping with a sharp instrument, and it's too easy to damage the wheels.
- MR
Offline rhfil
#9 Posted : 13 April 2024 16:16:23(UTC)
rhfil
There was a hobbyist who examined a number of different track cleaning solutions which included a microscopic examination of the surface of the track after the cleaning. The microscope revealed that a number of methods resulted in very small scratches of the track which not only attracted dust but created occasional electrostatic charges between the wheels and the track and carbon build up. I would think the same results would be relevant for wheels. I only use alcohol and a soft surface, lately felt furniture pads which I buy as small sheets and cut to the width of the outside of the track and the inside of the track to get at the center contacts.
#10 Posted : 13 April 2024 17:26:38(UTC)
I would not use anything metal to clean wheels. Dremel type tools provide felt pads which fit the tool and do a great job. You can see the dirt and oil on the pad. You do need a good supply of the pads but they are cheap.
thanks 4 users liked this useful post by David Dewar
#11 Posted : 14 April 2024 05:04:24(UTC)
This is what happens when you buy 2nd hand wagons
This page was generated in 0.410 seconds.
