Offline rschaffr
#1 Posted : 09 April 2024 23:23:07(UTC)
rschaffr
I recently upgraded to a CS3. Since my homebrew software uses the 6051 command set, I currently have a 6051->6021->connect-6021 inserting the commands into the CAN bus to control the trains. I would like to use my Intellibox in place of the 6051/6021 due to the higher serial speeds, but it does not want to communicate through the connect-6021. Any suggestions. (It is nice to be back in the Marklin hobby. I took a couple of years off to devote my time to amateur radio, but am now back)
-Ron
Offline patnaik
#2 Posted : 11 April 2024 02:35:30(UTC)
patnaik
You can use a USB to serial adapter to connect your computer to the Intellibox. I used to do this in the past using the 6021 serial protocol.
Gopal
#3 Posted : 12 April 2024 00:25:01(UTC)
Welcome back Ron.
Software such as iTrains allows you to bridge multiple controllers, which could help with what you are trying to do.
Offline rschaffr
#4 Posted : 13 April 2024 14:32:25(UTC)
rschaffr
I really need to get tie IB working through the connector on the side. It mates up with the connect6021 but will not pass commands. I know it is connected because if I hit the run button it puts the CS3 in standby. My old 6021 works fine here but I want the additional control and speed that the IB offers.
-Ron
Offline patnaik
#5 Posted : 13 April 2024 17:17:29(UTC)
patnaik
Another option is to use a Raspberry Pi running JMRI as an intermediary between the IB and CS3. Not a clean solution, though. Probably best to punt on the IB and look for some used Marklin controllers.
Offline rschaffr
#6 Posted : 14 April 2024 04:23:37(UTC)
rschaffr
I am currently using a 6021/6051, but would like to gain the functionality and speed of the IB.
-Ron
This page was generated in 0.382 seconds.
