Offline henna
#1 Posted : 10 September 2023 20:38:35(UTC)
henna
Hi, can somebody tell me how to change adress on the decoder on the locomotive with the CS3. I have adding a lot of locomotives to the CS3 and found that the 36080 and the 28590 have the same adress (24). I now want to change one of these adresses, prefably on the 36080. I have conected a piece of track to the "programming track"-connection on the CS3 but it doesn´t seem to change anything and I can´t find any answers in the large manual. Gratefull for any answers. Best regards Henrik
#2 Posted : 10 September 2023 21:59:51(UTC)
Hi Henna
The 36080 is a programmable FX decoder.
With a CS3, you must install your loco ALONE on the programming track (no Fx decoder programming on the main track.
1 & 2- Select Edit locos by pulling UP the red tab
3- Select the loco you wish (here an Fx loco)
4- In the fierld Address, click on it and then enter the new address WHILE POWER IS ON (Stop bar is NOT lit)
Validate
The locos headlight will blink on both sides
When finished BOTH the loco and the CS3 have a new address
Offline henna
#3 Posted : 11 September 2023 16:49:19(UTC)
henna
Hi and thank You very much Jean. Very helpfull information. Best regards
This page was generated in 0.510 seconds.
