Offline Santa Fe Rly
#1 Posted : 05 September 2023 06:07:33(UTC)
Santa Fe Rly
I operate a Marklin analogue layout with 1960s AC equipment. I also have a larger 2 rail layout controlled by NCE DCC and JMRI. A friend of mine operates similar equipment but has recently bought a secondhand BR 24 steam loco cat #36244. This loco refuses to move using his controller a Marklin #66471. My question is can I set up my NCE/JMRI Decoder Pro with 3 rail test track to check and reset if need be the decoder to operate on straight analogue as well as DCC as can be done with 2 rail decoders?
#2 Posted : 05 September 2023 15:07:33(UTC)
Maybe, the decoder definition for the msd and msd/3 decoders are in JMRI. So you should be able to use a DCC controller such as the NCE to access it.
You may find that the loco actually uses a simplified decoder as fitted to many of the Start Up series, and I don't know if these will work on DCC, I suspect they are only MM2/mfx capable.
#3 Posted : 06 September 2023 11:53:33(UTC)
Santa Fe Rly
Thanks for that when owner gets back to me I will give it a test.
Offline Wolfram_Stn
#4 Posted : 17 February 2024 15:45:12(UTC)
Wolfram_Stn
Five months later : did you be successful ?
I have some lack of time since my last decoder configuring with JMRI, but I did find them under "TRIX", not Märklin. Maybe this has changed since 2020.
#5 Posted : 17 February 2024 15:52:15(UTC)
This for the historical reason that Trix were using DCC decoders before Marklin started adding DCC capability to their decoders. So rather than get a new indentifier they continued using the Trix identifier for all Marklin and Trix decoders.
I don't know if the large scale decoders use Trix or LGB as their identifier.
This page was generated in 0.519 seconds.
