Offline mvd71
#1 Posted : 09 May 2023 06:33:55(UTC)
Can anyone advise when the DB changed passenger coach lighting from the old yellow lighting to the new flouro lighting that the warm white led represents?
Also, does anyone know of older coaches such as schürzenwagens had the lights replaced, or did the continue with the old style yellow lights through Tera 3?
Thanks in advance.
#2 Posted : 09 May 2023 08:14:30(UTC)
Hi, Mike,
I only remember seeing coaches with electric lights.
The yellow lights are gas lights. Light bulbs have warm-white light, neon lights are usually cold-white.
If coaches have replications of generators (dynamos) at the trucks, then I would assume they have electric lights.
This article says that experiments with electric lights in trains started 1881.
http://www.zeno.org/Roel...htung+der+Eisenbahnwagen
The first post here indicates that coaches used electric lights after about 1949.
http://www.maetrix.net/t...fuer-Eisenbahnwagen.html
This post indicates that gas lights were forbidden in Switzerland as of 1924:
https://lokifahrer.ch/Lu...agen/Personenwagen-1.htm
In 1923 a coach caught fire from the gas light after an accident.
Offline mvd71
#3 Posted : 09 May 2023 09:14:26(UTC)
Thanks Tom,
I guess the 12 ESU yellow light kits I have may have been a mistake! Would be nice if I could use them on the schürzenwagens.
Cheers….
#4 Posted : 09 May 2023 09:24:07(UTC)
The interior lights interact with the colour of the interior. Make a test with one of them. If it has the light-brown interiors then maybe the yellow lights will look quite good.
Lights should not be too bright for a Schürzenwagen IMHO.
Offline mvd71
#5 Posted : 09 May 2023 09:37:13(UTC)
I will have to order a few warm white kits for the era 3 commuter trains and d-zug trains.
I’ll try the yellow in the schurzenwagen and see how I get on.
While on the subject of lighting and interiors, do you have any photos of the inside of silberlinge sand mitteleinsteigwagen in the area behind the control cab?
Cheers…..
#6 Posted : 09 May 2023 20:09:47(UTC)
Cheers…..
As Tom (H0) said, the yellow tends to look like gas lighting, so would be used in very old coaches. But I reckon the warm white is supposed to be tungsten lamps, and the cool white represent fluorescent lamps.
This page was generated in 0.325 seconds.
