Offline gladop
#1 Posted : 10 March 2023 23:14:20(UTC)
gladop
Good Evening . At my disposal I have 5 pcs turnout with meganism 74491 and digital decoders 74461 and 6 pcs oniy with meganism 74491 . I have mobile station 2. I want to be able to operate the digital 74461 also with the control box 72710 or 72730. I do not know if it is possible and if so how to do this. If anyone knows please help. Thanks in advance.
#2 Posted : 11 March 2023 12:30:54(UTC)
Hi Gladop (First name?)
Welcome to this great forum
Here a Märklin digital HO fan from Paris France.
Here is the little I know
- you can't use a 72730 to operate a turnout. The 72730 is meant to cut power to side lines, lightings etc
- Using 72710 to operate your turnouts alone (in a conventional way) is standard operation recommended by Märklin
- Using 72710 to operate your turnouts in parallel with digital decoders 74461(in a digital way) is non standard operation not recommended by Märklin
- Using your MS2 to operate your turnouts alone with a digital decoders 74461 (in a digital way) is standard operation recommended by Märklin
So, shortly either a turnout is digital (commanded by the MS2) or analog commanded by a 72710 and 16 VAC power.
#3 Posted : 12 March 2023 10:17:27(UTC)
Hello gladop,
I am not sure if this helps, because I do not have digital control of tunouts.
But this article appeared in the 04.2022 issue of Märklin Magazine.
It explains 3 way of control.
(please ignore my pencil notes)
https://www.qldrail.net/altklost...alcontrolofsolenoids.pdf
This page was generated in 0.434 seconds.
