Offline thing fish
#1 Posted : 23 February 2023 13:57:58(UTC)
thing fish
Turkey
Hi ya all,
I have a KÖF that has zincpest. I'm sure many of you have had the same misfortune. I wonder what I can do with this otherwise perfectly working loco? Build a new cab maybe?
C.
thanks 1 user liked this useful post by thing fish
#2 Posted : 23 February 2023 14:06:55(UTC)
I'm afraid sooner or later the frame will break, leading to gear problems. So a new cab may only be a short-term remedy.
Is it the green Trostberg Köf?
Offline thing fish
#3 Posted : 23 February 2023 14:28:03(UTC)
thing fish
Turkey
Yes it is ...
The frame is pretty solid though. The loco is pretty old I believe, zincpest on the cab became apparent maybe 10 years ago but the frame is still ok.
C.
Offline mbarreto
#4 Posted : 23 February 2023 14:33:06(UTC)
mbarreto
When it was made available I was interested in it but by some reason I don't remember I didn't buy t.
It is a pity yours is having that problem because it looks pretty nice (when healthy)!
Miguel
Miguel
Mostly Märklin H0.
Offline thing fish
#5 Posted : 23 February 2023 14:36:34(UTC)
thing fish
Turkey
Miguel,
You're absolutely right; they're really nice to have on your layout especially if you have a sizeable yard. Crying
Good thing you didn't buy it then, I believe the problem solved on other issues.
C.
thanks 2 users liked this useful post by thing fish
Online kiwiAlan
#6 Posted : 23 February 2023 14:41:07(UTC)
Yes it is ...
C.
I thought they tended to have problems with the chassis, not the body. maybe a photo of the problem would help?
A possibility would be to get a spare body for a recent one and paint it.
Offline thing fish
#7 Posted : 23 February 2023 14:46:22(UTC)
thing fish
Turkey
Probably my good luck ... Chasis is fine, it's only the body. Good advice though; I was thinking of using/fitting it on a plastic track laying machine kit ... I have one from Kibri laying around for some time.
C.
#8 Posted : 23 February 2023 15:07:07(UTC)
i bought the Trostberg version new. It's a shelf queen. The frame began warping siezing the gears. Thank's Kingsbridge! Same with the 37521 SBB seetal. I know a young modeler in Germany who only buys Piko now because of it. Doesn't mind they are plastic bodies.
Offline thing fish
#9 Posted : 23 February 2023 15:22:02(UTC)
thing fish
Turkey
Who can blame him? Marklin didn't even bother to listen ... no good for future business.
C.
#10 Posted : 23 February 2023 15:59:40(UTC)
Here we go again...
The Trostberg Köf came in 2001, Kingsbridge took over in 2006. Märklin went for "Made in China" long before Kingsbridge took command.
IMHO Piko usually give good value for the money, but they also had some zinkpest problems.
#11 Posted : 23 February 2023 16:01:12(UTC)
The great recession hit us all hard too. Marklin new management assumed control from Kingsbridge and that is a new company as far as accounting, warranties, etc. So it's like after the General Motors 2009 bankruptcy. The new GM didn't honor any prior claims of defective vehicles either. I warned them in 2008 that it would all come back and bite them, when my 2003 Impala with just 76,000 miles on it needed a catalytic convertor because it clogged. They told me it was the gasoline that did it. I always used at least 89 ron octane, which the owners manual called for. No ethanol.
Delphi parts went belly up first. A very large GM employer division. That's when sales of vehicles began plumeting. Especially Pontiac, Satrun, and Saab. Laid off employers don't order vehicles, and neither do the businesses and employees of them when laid off people stop spending there.
Offline rhfil
#12 Posted : 24 February 2023 22:19:40(UTC)
rhfil
Since zincpest is the result of oxidation wouldn't spraying the chassis with a clear lacquer seal the metal and prevent further oxidation?
#13 Posted : 24 February 2023 22:49:18(UTC)
It might slow it down rhfil, but like all oxidation, it's in the batch. Crars rusted out from the inside out in 3 or 4 years in the 70's because the steel alreasy had began oxidizing in transit, a lot form Pacific salt water when the big 3 were buying Japanese steel. New steel is mor pure, and much less prone to this.
By the time the pest or rust shows, it doesn't stop.
Online kiwiAlan
#14 Posted : 25 February 2023 00:12:13(UTC)
It is not just oxidation, it is that there are impurities in the alloy, and these impurities are the source of the reaction that destroys the alloy.
Offline dickinsonj
#15 Posted : 25 February 2023 01:48:30(UTC)
Alan is exactly right.
It is a sign of inferior materials and poor manufacturing practices, resulting in sub standard castings.
At that time Marklin may have well needed to cut costs but they should have enforced minimal quality standards. In this case they put their name on some inferior, nasty junk eroding their once good name.
A clear lesson of buyer beware - even with premium brands.
Offline AshleyH
#16 Posted : 25 February 2023 05:59:16(UTC)
AshleyH
To be fair to Marklin, and I say this as an owner of a crumbled 37521 Seetal Croc and several US Boxcars that are ticking time bombs, most major manufacturers were caught out by this problem in the early 2000s.
I work in a hobby shop, we have recently taken over the stock from a train shop that closed a few years back. There are vast quantities of new old stock.
There is a high failure rate of Heljan Class 47s, Hornby Class 31s, 50s and various steam locos that have turned to unusable junk after 20 years of storage.
Bachmann and ViTrains also have complete runs of certain locos destroyed by zincpest.
Manufacturing was taking place in a fast developing economy and corners were cut to make a fast buck, the same could well happen in India and Vietnam which are seen by many model companies as the ‘New China’.
thanks 2 users liked this useful post by AshleyH
#17 Posted : 25 February 2023 14:43:55(UTC)
All companies that tried "Made in China" back then.
It seems they all forgot to specify material purity and penalties in their contracts back then.
Offline NewComix
#18 Posted : 01 March 2023 20:36:02(UTC)
NewComix
to be fair: for a certain period Märklin replaced the zinc pest Trostberg Köf for free. You just had to send it back to Märklin and got a new one with a new decoder. But this more than a decade ago. What you can do with an existing zinc pest one: throw it to the bin. Sooner or later it will anyhow ‚destroy‘ itself.
kind regards
Jörg
thanks 1 user liked this useful post by NewComix
Offline thing fish
#19 Posted : 01 March 2023 20:37:55(UTC)
thing fish
Turkey
Originally Posted by: NewComix Go to Quoted Post
thow it to the bin. Sooner or later it will anyhow ‚destroy‘ itself.
Unfortunately our dough doesn't come that cheap ...
C.
#20 Posted : 02 March 2023 00:21:04(UTC)
It wasn't until about 2017 that my Trostberg Koff showed any sign of pest. I bought it in new in about 03 or 04. It had been boxed in my storage drawer for some time. At least Marklin did replace the ones affected within a certain time period.
Offline HO Collector
#21 Posted : 06 March 2023 16:18:22(UTC)
HO Collector
There is a Facebook group called (if remember correctly) Marklin ho/oo 1937-1984. The guys on there rebuild any old stuff to as new condition. One has a zinc posted model that he rebuilt by using banna paper from the Carrabian that he collects at his supermarket
. See if someone will be happy to take yours as a project.
thanks 1 user liked this useful post by HO Collector
Offline thing fish
#22 Posted : 06 March 2023 16:26:48(UTC)
thing fish
Turkey
Wow ... thanks for the info. Will certainly try to find the group.
#23 Posted : 06 March 2023 21:16:42(UTC)
Banana paper? It's used to make wallets, etc., and pliable items. It looks mto resemble cork.
#24 Posted : 13 November 2025 18:30:19(UTC)
Hi all- is there a list of Kof model susceptible to the zinc pest? Or a cutoff date I wouldn't need to worry?
I'm looking at buying one and didn't know how to tell if its a potential concern. (the loco is fine now, but I don't want any future issues)
Offline mvd71
#25 Posted : 13 November 2025 18:57:14(UTC)
The Kof loco also has issues with the plastic gears cracking. I’ve had to repair a couple for a friend. I would suggest not buying one at all, saves disappointment
#26 Posted : 13 November 2025 19:05:25(UTC)
I know two affected Köf II: The Trostberg-Köf and a PostMuseum-Shop-Köf.
I haven't heard of zincpest with Köf III or Köf IV from Märklin.
#27 Posted : 13 November 2025 19:06:52(UTC)
Yes, my 36805 Trostberg has pest. So I would avoid the 36800 series from the 90's.
#28 Posted : 13 November 2025 19:15:40(UTC)
Thanks all, this is a good start! (my 36805 crumbled as well sadly...)
As I recall, there were a few early models susceptible, but I don't know which beyond the now infamous 36805 green machine
#29 Posted : 13 November 2025 19:23:45(UTC)
I forgot about that- it happened to my SOB "Mandrilini" years ago. Thankfully an easy swap though
#30 Posted : 13 November 2025 23:20:40(UTC)
First thing I would do is to put on a mask. You can never be too careful when you are Köf-fing
AFAIR that was a model made for Maerklin by Brawa. I wonder if you can get a replacement chassis from them?
Offline GlennM
#31 Posted : 14 November 2025 06:02:18(UTC)
GlennM
I have one of the Marklin replaced Trostberg Kof, and so far no zink pest on the replaced version.
By the way I though there was a list on the Forum of all the models affected by zincpest as a lot has been written on the subject?
thanks 3 users liked this useful post by GlennM
#32 Posted : 14 November 2025 09:58:32(UTC)
First thing I would do is to put on a mask. You can never be too careful when you are Köf-fing ...
BigGrin Laugh LOL
#33 Posted : 14 November 2025 10:25:36(UTC)
Nope, that was the old 3680.
#34 Posted : 14 November 2025 14:19:33(UTC)
Right Tom HO! Kingsbridge Capital owned Marklin when the 36800 series were made.
#35 Posted : 15 November 2025 11:41:13(UTC)
HO Collector
Oxidation is a secondary reason. The major reason is impurity of the zink alloy when it was prepared prior to go in the mouldings .
Guest (5)
This page was generated in 0.800 seconds.
