Offline mattj70
#1 Posted : 19 August 2022 18:33:10(UTC)
mattj70
I bought a 3793 with dip switches in coal tender, however I can't seem to open the tender up? In the booklet show rear top removes to see the dipswitches? However it is tight, I do not want to force it and break it?
Anyone know a trick to open it up?
Matt
Offline Dave Banks
#2 Posted : 19 August 2022 20:53:48(UTC)
Dave Banks
https://static.maerklin....33b0d84f371434542240.pdf
It appears to just clip in. See page 34 of this manual. But there is more to it Confused
In this Video around the 4:30 mark you will see the screws that hold the bogies need to be removed for the top to come off .
https://youtu.be/B65BVPLjBU0?t=297
Edited by user 20 August 2022 03:08:22(UTC)  | Reason: Not specified
D.A.Banks
Offline rhfil
#3 Posted : 19 August 2022 22:08:13(UTC)
rhfil
Sometimes you need to slide a piece of stiff paper like an index card down to keep the tabs apart while you squeeze the others. I have at times used up to four(cut one index card into quarters).
Offline bph
#4 Posted : 19 August 2022 23:24:07(UTC)
You must unscrew the two screws, that also hold the bogies in place on the tender.
3417 Exploded drawing.pdf (190kb) downloaded 52 time(s).
This page was generated in 0.340 seconds.
