Offline Mr. Ron
#1 Posted : 16 August 2022 00:47:11(UTC)
Mr. Ron
I would like to know how the 3-axle passenger cars, catalog #4067,7069 and 4080 go around curves. The center axle would have to move perpendicular to the length of the car while the 1st and 3rd axles would follow the track. I don't see how the center axle operates with this setup. Certainly, I have never seen it on an American railroad. Can someone tell me how the 3 axle car works?
Offline applor
#2 Posted : 16 August 2022 03:51:08(UTC)
applor
You already have it figured - the centre axle moves a little side to side. In reality this amount of movement is very small. On the model railroad it's not a problem - the shaft has enough length past the wheels where it attaches to the frame.
#3 Posted : 16 August 2022 13:41:29(UTC)
Hi Ron
I have seen 2 designs
- older cars 1950 and after have a side play on all axles, especially the one in the middle. Cars with blunt axles (before 52) or needle axles (smaller cylindrical extremity to reduce frition
- newer cars with conic axles & bearings: the center axle is moving sideways with its bearings and - on some rare models - are changing the orientation of the extremity axles
Here is a good example of a recent 3 axle car with sideways-moving axle and bearings (4206)
This page was generated in 0.234 seconds.
