#1 Posted : 24 May 2022 00:14:37(UTC)
I've seen one which does when the magnet is waved over the battery. The second wave turns it off for led lighting.
Offline Ausipeet
#2 Posted : 24 May 2022 04:31:01(UTC)
Ausipeet
This might be what you are looking for, they are called Magnetic reed switches. From what i have seen they are simple to install and easy to operate. Hope this has helped.
https://cs.trains.com/mrr/f/744/t/202698.aspx
Found this Photo on my PC hope this helps aswell.183499000_4522151917813478_7899496375562241074_n.jpg
construct as shown in Photo, to operate use a earth magnet and wave it over the unit that is installed in carriage to activate the lights to turn off repeat wave.
thanks 2 users liked this useful post by Ausipeet
#3 Posted : 24 May 2022 13:25:26(UTC)
Yes Pete! Thank's a million! Normally, the reed switches are only momentary contact. It must be a latching type reed switch.
The other way is a motion sensor switch, which I located, but I don't what other component it nees in order to operate, and the ones I found were within a 10 to 100 gram shock/horizontal motion activation. The 5 gram one was normally closed as still.
#4 Posted : 25 May 2022 13:13:54(UTC)
I may be wrong but seing my Faller car system and its tiny Reed contacts and small "adjust magnets" (163222) and liberation coils as on the Rolling road I wonder if this (bi-stable Reed functionality) cannot be obtained by adjusting a small piece of magnet next to a Reed contact so that it becomes bi-stable
See here my Faller rollende Landstraße and its adjust magnet (on the truck), the stop-magnet on the truck-carrying car and its liberation coils under the track.
This is a fine-tuned addition / substraction of magnetic fields which allows this functioning
#5 Posted : 25 May 2022 13:52:52(UTC)
Merci John, I hadn't researched the liberation coil.
This page was generated in 0.359 seconds.
