Offline Puttputtmaru
#1 Posted : 21 February 2022 16:41:52(UTC)
Puttputtmaru
From what I see on most « how to » channels, you first paint your tracks and then clean the top with what ever methods they like to use.
I was thinking that it would save time and aggravation in the futur since you could scratch the track c;earning them, to use a narrow masking tape on the top side of the track to protect it.
Anyone tried this before, any down side to it?
#2 Posted : 21 February 2022 16:43:57(UTC)
I suspect the time involved in applying the masking tape would outweigh the time required for cleaning.
#3 Posted : 22 February 2022 12:02:09(UTC)
I just ran a finger inside a cloth on top of the rail, immediatly after painting it. -While the paint is still wet. So easy and fast.
If the paint is beginning to dry, then a wooden block inside the cloth instead of the finger, will also do the trick.
I painted the whole shebang with an airbrush.
Online JohnjeanB
#4 Posted : 22 February 2022 12:30:22(UTC)
Everyone its method. I use acrylic paint to cover the side of the rails. The excess paint on top of the rails is removed using a rubber (eraser like Staeddler) or a tissue.
Abrasive is not to be used excess in grade 1000 or 1500 water abrasive. Otherwise, it creates small grooves that help dirt to stick to the rail. Masking tape or adhesive, leave a residue that is helping to collect dirt.
#5 Posted : 22 February 2022 12:41:15(UTC)
Puttputtmaru
The Staedtler eraser seems like a good idea for a non abrasive way.
Specific dedicated track cleaning eraser, Wallthers and others, get mixed reviews as to the non abrasive nature of them.
I was thinking of using 99% isopropyl alcool to remove any glue left behind by masking tape but the Staedtler eraser might be less work.
#6 Posted : 22 February 2022 12:42:49(UTC)
Puttputtmaru
Now this is what I was looking for since I was planning to use an airbrush too. If I am too slow I will use the Staedtler eraser.
Offline CYHU
#7 Posted : 25 February 2022 19:05:16(UTC)
CYHU
I also clean rails with a cloth just after applying paint. But, at the end of the whole weathering process, I use a contact cleaner abrasive block.
More information (in French) on my website.Cool
Pierre.
#8 Posted : 25 February 2022 21:42:58(UTC)
Puttputtmaru
That is what I want to get away from. The idea of the Staedtler eraser seems less abrasive
Offline Dave Banks
#9 Posted : 27 February 2022 00:11:06(UTC)
Dave Banks
[img]UserPostedImage[/img]
I did every track by hand using a N0.1 paint brush & Humbrol "Matt 113" & wiped the top rail with thinners afterwards. Painting was done by holding the track upside down in the hand & painting it. It took months & many friends had a paint brush put in their hands when visiting OhMyGod
D.A.Banks
This page was generated in 0.583 seconds.
