Offline Christo Swanepoel
#1 Posted : 17 November 2021 06:25:18(UTC)
Christo Swanepoel
Good morning Marklin family,
I bought an entire layout and it came with decoders and cs2. The turnout decoders are not lime the marklin ones. Could anyone help me please, I cannot get them to work on the cs2 test track16371266636221778782988058906838.jpg
Offline Graham HO
#2 Posted : 17 November 2021 09:10:01(UTC)
Graham HO
Interesting ‘home built’ device which has clearly worked at some stage. The Tactile switch button appears to be guarding a voltage/current supply to the chip - maybe you need to make sure this component is functioning by making sure it is held flat against a surface to engage the button - just a thought.
#3 Posted : 17 November 2021 09:16:52(UTC)
I have some Viessmann decoders that can be installed under the C track. They have a button to activate the programming mode.
The decoders I have support four addressing modes: They can use DCC or MM accessory addresses, but can also use DCC or MM loco addresses.
The decoder on your photo does not look like the ones I have.
With my decoder, the turnout starts switching left and right when I press the button. Maybe do some trial-and-error with it.
Is there any text on the decoder? Maybe on the other side?
Offline pederbc
#4 Posted : 17 November 2021 13:28:19(UTC)
pederbc
I believe the button is for learning the address. Prepare the address to use in your digital system. Press the button and then activate the switch with the prepared address. When in learning mode it will listen for an accessory address and store it in the decoder. Try it.
Best regards, Peder
#5 Posted : 17 November 2021 13:40:13(UTC)
Christo Swanepoel
Thank you guys,
Will try out the recommendations tonight and let you know
Thanks Christo
#6 Posted : 17 November 2021 13:45:57(UTC)
With the decoder I have you have to press the button once, twice, thrice, or four times, depending on the addressing mode you want.
#7 Posted : 17 November 2021 13:52:44(UTC)
No, it is a home made decoder, and the button has nothing to do with "guarding the power supply".
To set the address it will be a case of pushing the button to set it into 'program mode' and then push a red or green button on the controller (or the equivalent operation on a cs that will operate a point). This will then set the address the decoder will respond to.
Offline Copenhagen
#8 Posted : 17 November 2021 14:38:22(UTC)
Copenhagen
If it was bought as a complete set then the adresses of the turnouts should still be in the CS2 memory, and then it should be a matter of going through all turnouts until you find the ones that belong to each other? Don't have a CS2 myself.
Testing Marklin Turnout Decoders/Motors (Digital)
by Alex H 31/10/2025 18:28:13(UTC)
Marklin C track turnout decoders (Digital)
by Alex H 12/10/2023 09:20:42(UTC)
Turnout Decoders, Signals and MS2 Controlling (Digital)
by CanadianKid 02/07/2017 02:16:17(UTC)
Turnout decoders (Digital)
by oldchippie 07/07/2015 04:00:19(UTC)
Help programming the turnout decoders in 29483 start set (Digital)
by mascagni 02/02/2015 20:38:32(UTC)
by Mike M 26/07/2013 06:03:21(UTC)
74460 turnout decoders (Digital)
by shbrown2424 03/07/2013 15:39:14(UTC)
C Track Turnout decoders (H0-scale)
by sudibarba 26/07/2012 04:46:14(UTC)
Maerklin vs. Viessmann C-track Turnout Decoders (Digital)
by mascagni 27/07/2008 04:53:14(UTC)
k73/6073 turnout decoders for M-track turnouts (Digital)
by Katchina 12/02/2008 23:51:43(UTC)
Turnout Decoders & MS (Digital)
by David Dewar 17/12/2004 18:40:28(UTC)
This page was generated in 0.342 seconds.
