#1 Posted : 21 September 2021 09:52:13(UTC)
I like to thank Peter Clapcott for providing a website link (Proops Brothers Ltd. UK) regarding micro drills, the drill set has arrived today with 19 micro drills at a total cost of £ 6.50, (order date 9th Sept.2021) free delivery to Australia, its cheaper than buying it from J-car.
thanks 6 users liked this useful post by river6109
Offline Ranjit
#2 Posted : 21 September 2021 11:43:11(UTC)
Ranjit
Hey John... What sizes of micro drill bits did you get, and what is the make and model number ?
Ranjit
#Get Vaccinated
#3 Posted : 21 September 2021 12:01:13(UTC)
Ranjit
Ranjit, thanks for your inquiry ut I don't know what brand they are, have a look at the website and go for micro drills, let me know how uyou get on
Offline Drongo
#4 Posted : 21 September 2021 12:24:15(UTC)
Drongo
Hi John, from my experience with these drill bits, I would have ordered at least 2 sets - they break so easily.
Greg
#5 Posted : 21 September 2021 12:30:16(UTC)
Greg
Greg, seeing it is free postage I always can do this when they start breaking, they are very tiny and I assume some of them are not bigger than 0.5mm but I wouldn't use them with a drill but rather drill them by hand., I had some from China a while ago and they did break easly, the ones from J-car were of a better quality and what I've seen the ones from the UK they look ok.
#6 Posted : 21 September 2021 12:44:21(UTC)
Yep. They are only meant for hand-drilling softer materials. Nothing harder than Aluminium in my opinion. They are more suited to plastic materials.
Offline Ranjit
#7 Posted : 21 September 2021 13:01:30(UTC)
Ranjit
Do you use a pin vise or a mini hand drill to use these micro drill bits ?
Ranjit
#Get Vaccinated
Offline Toosmall
#8 Posted : 21 September 2021 15:19:27(UTC)
Toosmall
In Australia, Sutton Tools, from a proper hardware/engineering supplier (Not the big blue store).
Page 17 smalls drills down to 0.34mm in packs of 10.
https://suttontools.s3-a...9_IPDCatalogueDrills.pdf
Use a pin vice and cutting fluid.
Offline Ranjit
#9 Posted : 21 September 2021 17:17:44(UTC)
Ranjit
Hi John...
Is it the "20 Piece Micro Metric HSS Twist Drills & 4 Way Pin Vice (M0278)" that you purchased from Proops Bros. for £ 6.50 ?
Ranjit
#Get Vaccinated
thanks 1 user liked this useful post by Ranjit
#10 Posted : 21 September 2021 17:30:36(UTC)
Hi John...
Ranjit
exactly
Offline Ranjit
#11 Posted : 21 September 2021 17:38:34(UTC)
Ranjit
Thank you, John ! Good night !
Ranjit
#Get Vaccinated
Offline Toosmall
#12 Posted : 22 September 2021 01:56:04(UTC)
Toosmall
The 1/8" shaft drill bits for a Dremel etc are really good for extra precision. Don't buy the Chinese rubbish.
If tapping very small threads, start with a taper tap, even if it's only through a sheet, use the correct cutting fluid for the metal, I can't stress enough that enough.
Very small threads are an absolute pain in the neck, you need to take it very slowly and unwind tap every eighth of a turn, even a sixteenth, and best to unwind and clear the hole completely and reapply cutting fluid..
If you are not in the mood for the task, leave it for another day as you will break the tap in the hole and then your problems start!
thanks 5 users liked this useful post by Toosmall
#13 Posted : 15 November 2021 18:56:25(UTC)
Hi John...
Ranjit
I have just been searching through their website and it looks like they don't have any micro drills any more ... Crying Crying Crying
#14 Posted : 15 November 2021 21:33:09(UTC)
That's cos Ranjit and River have bought them all!
Must be something to do with the letter 'R'.....
Offline Tom Jessop
#15 Posted : 15 November 2021 21:53:03(UTC)
Tom Jessop
Looks like i will have to hide my stash of Proops drills from other southern hemisphere inhabitants .
thanks 2 users liked this useful post by Tom Jessop
#16 Posted : 15 November 2021 22:07:06(UTC)
I also happily helped deplete stock BigGrin
After seeing John’s post #1 I bought two (different) sets from the brothers Proop for a good price. Postage at the grand cost of two dollars and arrived quite timely. I am very pleased with them.
Thanks again to John (and Peter)ThumpUp
PJ
Offline DTaylor91
#17 Posted : 16 November 2021 01:24:47(UTC)
DTaylor91
For those looking for durable micro-drill bits: I suggest searching for the type that are designed for drilling circuit boards. Use in a small drill press at LOW RPMs
#18 Posted : 16 November 2021 04:15:20(UTC)
these drills are ok with white metal and of course a handdrill which came with the order
Guest (4)
This page was generated in 0.868 seconds.
