Offline phantomtracer
#1 Posted : 08 February 2009 04:51:20(UTC)
phantomtracer
I am planning on getting the ESU update for my CS1. Does anyone know if you will be able to run a DCC loc AND MFX at the same time?
Does the CS2 allow the simultaneous use of DCC and MFX?
Phil
#2 Posted : 08 February 2009 05:07:39(UTC)
phantomtracer
SORRY!
I just found my answer.
Yes, you can run them together!!!!
This will allow me to purchase a Proto 2000 F3 with DCC and convert it to 3 rail.
Phil
#3 Posted : 08 February 2009 05:50:55(UTC)
Views messages in topic : 18,778
The answer to both questions is Yes. DCC and mfx can be used together with both the CS2 and v3 CS1.
Offline Lars Westerlind
#4 Posted : 08 February 2009 10:29:57(UTC)
Lars Westerlind
I guess, you mean output commands. AFAIK know full DCC and MFX also is with backward info, and I doubt this is comptabile between DCC and MFX? But not impossible of course; does anyone know if also this would work?
/Lars
#5 Posted : 08 February 2009 17:45:41(UTC)
Don´t forget about ESU new Ecos II,which you can also using in both with DCC and mfx.
Offline hmsfix
#6 Posted : 14 February 2009 15:48:05(UTC)
hmsfix
[size=1" face="Verdana" id="quote]quote:Originally posted by phantomtracer
<br />Hi,
Phil
As far as I have understood, this should work. However, I have no experience with this yet, but I plan to try on my layout as well, as soon as i have replaced my CU by an ECOS or so. I would appreciate more infos. Very important point for all who model US themes...
Hans Martin
#7 Posted : 14 February 2009 18:08:03(UTC)
phantomtracer
Once the ESU update is available I plan on ordering it. I will post results ASAP. I just hope the ESU update comes out.
Phil
Offline perz
#8 Posted : 14 February 2009 18:20:01(UTC)
perz
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />I guess, you mean output commands. AFAIK know full DCC and MFX also is with backward info, and I doubt this is comptabile between DCC and MFX? But not impossible of course; does anyone know if also this would work?
/Lars
The mfx feedback is based on modulating the current draw of the decoder. This feedback takes place with full voltage applied, but during periods of "DC" to not get interference with the forward signalling.
The DCC feedback as specified by NMRA takes place during "cutout" periods where the command station does not drive the track. DCC feedback relies on stored energy in the decoder to transmit the feedback.
I can't see any reason why those two methods could not both be applied in the same system.
There is also another feedback method often used together with DCC. This method is used by Digitrax equipment. It uses a principle similar to mfx so there may be a potential for the two methods to disturb eachother.
#9 Posted : 14 February 2009 18:45:28(UTC)
Lars Westerlind
Thank's very much Perz, for clarifying. It all makes sense to me, including the note about Digitrax. If I understand it correctly, NMRA have choosen Lenz system, which AFAIU doesn't make sense using unless all equipment is changed at a time. I guess they have thought about something to avoid destroyal of equipment, but I guess it's difficult to convert parts of the layout. I think Digitrax claim it would be possible to have some segments with feedback, and others without.
And still, there I've not heard any good thinking (well, I've not actually searched for it) about how this feedback should be used in a good way. The only commersial system I know that is WORKING, that is, can cause functions to appear at the layout, without using a computer, is still AFAIK Lissy. Which of course is expensive, but still - has been working for years alaready.
Sorry for stealing thread. Enought from me now. /Lars
#10 Posted : 14 February 2009 23:59:58(UTC)
Perz, your succinct summary of mfx (modulation) v DCC (cutout) is fine "for the track" but when you make reference to the Digitrax contention I miss the point!
If you are referring to Digitrax LocoNet then this is a separate command bus. If its protocol is "mfx like" that seems irrelevant - it is on a different set of wires.
Up front, personally I am only interested in the DCC coexistence scenarios because of the potential interoperability problems to be expected.
But first I ask that there be clarification on what bi-direction communication is for. Trains or Trackside accessories ?
If it comes to locomotive decoder info like " name address capabilities current-speed" then these come from the moving train and therefore via the track (assuming we are not talking wireless).
Trackside - e.g. turnout position or occupancy detection does not need to come "through the track". A separate "bus" like s88/loconet is far more efficient.
So when ESU say they have a "Railcom ready" turnout decoder, does this imply a connection of track side data (that doesn't need to be "through the track") with the track circuit.
Seems like a waste and a complication - Or have I missed something?
Offline perz
#11 Posted : 15 February 2009 01:40:48(UTC)
perz
<br />Perz, your succinct summary of mfx (modulation) v DCC (cutout) is fine "for the track" but when you make reference to the Digitrax contention I miss the point!
No, I'm not referring to Digitrax LocoNet. I'm referring to their "transponder" technique.
Trains.
#12 Posted : 15 February 2009 09:48:53(UTC)
Lars Westerlind
IMHO, bi-direction communication is for trains, but I still want to hear, what benefit is intended? It sounds good, to have bi diectional communication, but is not enough.
Märklin use it for identifying locos to the central and set address+functions to the central automaticcally. The same task could be done on a tradiontal DCC programming track, which is also bi-directional (power drawn pattern is sensed by central).
But of course one would like the do things like
1. changing speed of a certain train when it reaches a certain place
2. trigger functions like putting on light, sounding the horn, at certain positions.
3. Trigger events like startinig other trains when one train is within a yard.
4. Issue functions like put on station light when a train enters.
5. More?
For this, it's not enought that the trains could speak. The position must also be identfied. I could think of
A. Separating the layout into lots of sections, and have detection circuits on power feed to all interesting section. Those detection would send the trains message together with its own identity on the system bus. Some problems like not very distinct position decisions, somewhat expensive power feed,
B. Variation, each booster sends a power distrinct identification to it's segement, which would allow the decer to know it's position. Would cause shorting problems when switching between districts.
C. Another signal could be used at layout positions; when a train gets there, it gets an IR signal, RFID identification or whatever which enables it to know it's position. One bad thing is that the detector typically is more complicated than the sender - and the detector must fit within the loco.
D. Letting the train have a transmitter which sends information beside the track, IR , RFID or such. At certain points, detectors are positioned which identify the train and sends signals directly on the system bus. This does not need any two way communication.
Uhlenbrock Lissy is of type D, with IR, which does not care about feedback. It's implementaion is with an intelligent (not cheap) receiver module, which is capable of issuing 1,2 and 4 above without help of other modules. I think perz has soemthing similar where the signal instead is handled by a computer, which of course may do anything.
I have still not seen or heard of any other complete system that can perform tasks 1-4 out of the box. OK, Lissy needs complicated configuration, which could be compared with computer programming. But then, are there any computer programs available that utilize Railcom or digitrax "Transponder"?
/Lars
#13 Posted : 15 February 2009 10:07:17(UTC)
Right thanks, I misunderstood
However the Digitrax transponder function is aimed at occupancy detection and needs a separate detector to listen , which in turn feeds the message back to the controller via loconet.
Given that neither the CECoS/CS1 or CS2 have loconet this becomes a mute point does it not ?
Are you saying it ALSO has the automatic registration capabilities similar to mFX when you put a decoder on the track for the first time?
Offline Murphy
#14 Posted : 15 February 2009 10:23:23(UTC)
Murphy
Hans Martin
Hans,
No consumer on our entire planet has experience yet with any DCC/Mfx Command Control Unit. The Ecos-II is on the brink of leaving the brochure state(if it indeed works). The rest are pure rumours.
#15 Posted : 15 February 2009 15:48:56(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by perz
Trains.
Wrong...!
Both of it does...!
See at Lenz news too...!
www.digital-plus.de
Offline digilox1
#16 Posted : 15 February 2009 20:38:05(UTC)
digilox1
[size=1" face="Verdana" id="quote]quote:This will allow me to purchase a Proto 2000 F3 with DCC and convert it to 3 rail.
Hi Phil,
don`t feel too enthusiastic about the principal mutual tolerance of mfx and DCC. I have quite a few locos equipped with QSI sound decoders and these are acting erratically when Motorola signals are sent to the rails.
My QSIs are not of the actual breed, so my observations may not apply to newer versions of the QSIs and mfx is quite different from Motorola, anyway.
Some preliminary testing might prevent you from facing a negative surprise, though.
Manfred
Offline Sander van Wijk
#17 Posted : 15 February 2009 20:59:18(UTC)
Sander van Wijk
<br />IMHO, bi-direction communication is for trains, but I still want to hear, what benefit is intended? It sounds good, to have bi diectional communication, but is not enough.
5. More?
/Lars
Hi Lars, all,
Although I'm getting off-topic here, I'd like to add something to the discussion.
@ Lars: Your contribution is a very good elaboration on the possibilities of digital feedback. Reading your contribution makes me wonder; do you know of the DCC RailCom system, among others supported by ESU?
In their new items folder, they present the ESU ECoSdetector.
See: http://www.esu.eu/produk...osdetector/ecosdetector/
Which seems to be a really interesting system. In your classification, their system is having the features 1..4 listed and is technically like option A.
I for one am very interested in the practical application of the RailCom system, even though it requires a lokdecoder featuring RailCom. Consequently, I would have to convert a couple of my locomotives. Luckily, most of them would benefit significantly from a new decoder anyway.
Interesting discussion and sorry for going off-topic.
Sander
#18 Posted : 15 February 2009 23:24:14(UTC)
Lars Westerlind
No, I've not studied Railcom or ECoSdetector; I was hoping someoen else could tell the essence of different systems.
Just briefly looking into your link, the Ecosdetector seems to do the job agreed. 16 sections supervised, and identifications are reported on system bus; I guess events like "loco xxx entering section" could be used more or less to issue operations; the unit doesn't recognize direction, and not entry point, so Lissy is still somewhat beforehand (reports speed as well BTW), but this doesn't seem to be a big issue. I would expect Ecosdetector to be much easier to use and probably also cheaper, if everything will work as promised.
However, I can think of one really big problem still. Not many will convert all their own locos with a new Railcom decoder, especially not if they have special decoders (sound, function decoders, whatever, C-sine, piezos...). But perhaps there exist an add-on railcom transponder, which only takes the role of sending response. Or, is there a problem with having one traditional and one railcom transmitter in same segment?
/Lars
#19 Posted : 16 February 2009 07:44:36(UTC)
/Lars
I must rely on web translators for the ECosDetector manual, however it appears to be very much like the Digitrax equipment, which has a foundation of basic occupancy detection by way of detecting any current draw. To this you can add an intelligent detector capable of reading a decoders ID (if it has one)
Therefore to get started you do not NEED ID intelligence. I think the Decoder extension is just that, a simple led that turns on when a section is occupied. The ID , if available, can be built up to.
Please correct me if I have this wrong.
#20 Posted : 16 February 2009 17:23:33(UTC)
Sander van Wijk
Peter is spot on. The idea of the ECoSDetector is indeed to have a basic detection regardless of the type of decoder. 12 out of its 16 inputs are only capable to do this, however, the other four inputs are capable to both detect occupancy and in case of a RailCom decoder, ID the loco. Besides this functionality, the Detector is also capable of coding signals produced by four instance reed-contacts.
Up to now, there is unfortunately no separate RailCom transponder, perhaps there will be one in the future. In my particular case, I wouldn't mind replacing decoders as I only own about thirty locos, which, although all quite recent non-Hobby models, only a couple have sound and none has a SDS.
Sander
Offline jeehring
#21 Posted : 17 February 2009 18:31:41(UTC)
jeehring
5. More?
/Lars
5.programming a whole trip from departure to Arrival
6.doing it for 1, 2 or 3 , or several trains...
7.Assigning a "characteristic of priority" to some trains ( automatic choice of which train will stop on a cross)
8. .....doing all what you do with a PC, but in better condition of communication ( integrated)Smile
....don't you think that it needs a "special item" , a kind of " special box - with or without screen , depending on if the job can be treated easily on CS2's screen I.E. with keyboards or/and layout panel - a kind of "special box " to connect it to the CS2 ?
Because I believe a wireless channel should be abble to do the job...only 4 digit must be transmitted)
Offline dntower85
#22 Posted : 17 February 2009 18:32:08(UTC)
dntower85
<br />Right thanks, I misunderstood
Its my understanding that the Transpoder not only allows for occupancy detection but also but it also registers which decoder is on the detector.
From reading the digiTraxs info I think this is what is how it is designed but I have never seen any one or read any article on how to put it to use.
I would be good if marklin had an advanced s88 that could detect a mfx decoder then a computer program could always know what train was on the section of track. It would also give a reason to convert locs to mfx.
DT
Offline perz
#23 Posted : 18 February 2009 01:05:09(UTC)
perz
[size=1" face="Verdana" id="quote]quote:Originally posted by dntower85
<br />I would be good if marklin had an advanced s88 that could detect a mfx decoder then a computer program could always know what train was on the section of track. It would also give a reason to convert locs to mfx.
There are two reasons why I think there will not come such a product:
1. The principle of using modulation of the decoder current draw to locate the segment where a train is positioned is patented by a man named Ireland. Mr. Ireland has licensed this patent to Digitrax. So only Digitrax are allowed to use this principle. The Railcom DCC circumvents this by not using modulation of the current draw for the feedback, but instead use stored energy in the decoder to transmit during power "cutout" periods. The mfx feedback is non-infringing on that patent as long as it is not used for identification of the train position.
2. The principle is not so scalable, at least not if based on mfx. There are three different mfx commands that enable the feedback in the decoder (I use Rainer Müller's terminology here):
a) PING. This command is directed towards one single decoder at a time. The addressed decoder gives a simple (non-coded) response.
b) SUCH (German for "search"). This command is directed to all decoders but only non-registered decoders can respond. The response is non-coded.
c) READ. This command is directed towards one single decoder at a time. The addressed decoder gives a coded response, containing the data requested by the parameters to the READ command.
None of these commands actually control the trains, so they have to be mixed with train control commands. In practice only the PING command is meaningful for positioning. The time required for a PING to one lok is around 20 ms, and the PINGs can only take up a fraction of the available bandwidth. To be able to detect all trains you have to ping each train, one after eachother. The more trains you have, the longer time there will be between the PINGs to a specific train. With 10 - 20 trains the detection will be too slow to be really useful I think.
A possibility would have been to have a broadcast PING-like command. The SUCH command is like that, but it only adresses the loks that have not already been registered. To my knowledge there is no mfx command that can make all registered loks respond at once. There is a reason why such a command would not be such a good idea anyway. The mfx feedback draws quite a bit of power. My measurements indicated approximately 2.5 VA. Guess what will happen on a heavily loaded layout if suddenly each lok draws 2.5 VA extra!
In fact this can happen with the SUCH command, if none of the loks are registered, and the lok serial numbers are such that the probed bits coincide. I suspect that this phenomenon can be a source of many mfx registration failures. E.g. the MS sends out a SUCH and the combined current draw of all the responses causes a temporary overload that makes the decoders and the MS lose the power in the critical moment when both sides have to decide if the lok is registered or not.
I don't know how Digitrax and DCC Railcom have solved the scalability problem, or even if they have solved it.
#24 Posted : 18 February 2009 10:23:57(UTC)
Exactly !!
... I don't know how Digitrax and DCC Railcom have solved the scalability problem, or even if they have solved it.
And I still can't find anything about basic "mfx like" auto registration. Do they have this feature? Some current docs still make a big thing of 9999 addresses - WHY! haven't we got past this.
And Goofy wants to insist that accessories are also destined to hog DCC-Railcom bandwidth - again WHY? or maybe I should ask, To the detrimental of how much interference and scalability? (and power drain)
I'm with Lars and the Lissy concept of offloading the location detection bandwidth "direct" to the back end bus. Possibly backed up by basic non intelligent occupancy options with PC tracking for the non-Lissy equipped locos/trains.
DCC and MFX - why both?? (General MRR)
by baggio 19/12/2017 04:06:29(UTC)
This page was generated in 0.924 seconds.
